신규 설치 후 설정이 보이지 않음 (Discourse 3.4.0.beta3-dev 설치 로그 오류/GeoLite2-City.mmdb GeoLite2-ASN.mmdb)
After a brand new installation, there are no settings
discourse 3.4.0.beta3-dev安装后 日志报错/GeoLite2-City.mmdb  GeoLite2-ASN.mmdb
MaxMindDB (/var/www/discourse/vendor/data/GeoLite2-City.mmdb) could not be found: No such file or directory @ rb_sysopen - /var/www/discourse/vendor/data/GeoLite2-City.mmdb
5:25 pm
MaxMindDB (/var/www/discourse/vendor/data/GeoLite2-ASN.mmdb) could not be found: No such file or directory @ rb_sysopen - /var/www/discourse/vendor/data/GeoLite2-ASN.mmdb
5:25 pm
Message (2 copies reported)
Backtrace
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:130:in `block in warn'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `block in dispatch'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `each'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `dispatch'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:130:in `warn'
/var/www/discourse/lib/discourse_ip_info.rb:88:in `rescue in mmdb_load'
/var/www/discourse/lib/discourse_ip_info.rb:84:in `mmdb_load'
/var/www/discourse/lib/discourse_ip_info.rb:14:in `open_db'
/var/www/discourse/lib/discourse_ip_info.rb:10:in `initialize'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `new'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `block in instance'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `synchronize'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `instance'
/var/www/discourse/lib/discourse_ip_info.rb:175:in `get'
/var/www/discourse/app/serializers/concerns/user_auth_tokens_mixin.rb:13:in `location'
(eval at active_model_serializers-0.8.4/lib/active_model/serializer.rb:467):5:in `_fast_attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:455:in `attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:89:in `block in _serializable_array'
activerecord-7.1.5/lib/active_record/relation/delegation.rb:100:in `each'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:79:in `map'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:79:in `_serializable_array'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:73:in `serializable_array'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:53:in `as_json'
activesupport-7.1.5/lib/active_support/json/encoding.rb:23:in `encode'
activesupport-7.1.5/lib/active_support/core_ext/object/json.rb:42:in `to_json'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:63:in `to_json'
multi_json-1.15.0/lib/multi_json/adapters/oj.rb:56:in `dump'
multi_json-1.15.0/lib/multi_json/adapter.rb:25:in `dump'
multi_json-1.15.0/lib/multi_json.rb:139:in `dump'
/var/www/discourse/app/controllers/application_controller.rb:759:in `json_result'
/var/www/discourse/app/controllers/users_controller.rb:258:in `update'
actionpack-7.1.5/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-7.1.5/lib/abstract_controller/base.rb:224:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack-7.1.5/lib/abstract_controller/callbacks.rb:259:in `block in process_action'
activesupport-7.1.5/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
i18n-1.14.6/lib/i18n.rb:353:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:424:in `with_resolved_locale'
activesupport-7.1.5/lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport-7.1.5/lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack-7.1.5/lib/abstract_controller/callbacks.rb:258:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/rescue.rb:25:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/instrumentation.rb:74:in `block in process_action'
activesupport-7.1.5/lib/active_support/notifications.rb:206:in `block in instrument'
activesupport-7.1.5/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport-7.1.5/lib/active_support/notifications.rb:206:in `instrument'
actionpack-7.1.5/lib/action_controller/metal/instrumentation.rb:73:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/params_wrapper.rb:261:in `process_action'
activerecord-7.1.5/lib/active_record/railties/controller_runtime.rb:32:in `process_action'
actionpack-7.1.5/lib/abstract_controller/base.rb:160:in `process'
actionview-7.1.5/lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler-3.3.1/lib/mini_profiler/profiling_methods.rb:115:in `block in profile_method'
actionpack-7.1.5/lib/action_controller/metal.rb:227:in `dispatch'
actionpack-7.1.5/lib/action_controller/metal.rb:309:in `dispatch'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:51:in `block in serve'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:131:in `block in find_routes'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:124:in `each'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:124:in `find_routes'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:882:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack-2.2.10/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.10/lib/rack/conditional_get.rb:40:in `call'
rack-2.2.10/lib/rack/head.rb:12:in `call'
actionpack-7.1.5/lib/action_dispatch/http/permissions_policy.rb:36:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:399:in `call'
/var/www/discourse/lib/middleware/csp_script_nonce_injector.rb:12:in `call'
/var/www/discourse/config/initializers/008-rack-cors.rb:14:in `call'
rack-2.2.10/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.10/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
activesupport-7.1.5/lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack-7.1.5/lib/action_dispatch/middleware/callbacks.rb:28:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
logster-2.20.0/lib/logster/middleware/reporter.rb:40:in `call'
/var/www/discourse/lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:35:in `call_app'
/var/www/discourse/lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/request_id.rb:28:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:24:in `call'
rack-2.2.10/lib/rack/method_override.rb:24:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.2.10/lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler-3.3.1/lib/mini_profiler.rb:334:in `call'
/var/www/discourse/lib/middleware/processing_request.rb:12:in `call'
message_bus-4.3.8/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:360:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/remote_ip.rb:92:in `call'
railties-7.1.5/lib/rails/engine.rb:536:in `call'
railties-7.1.5/lib/rails/railtie.rb:226:in `public_send'
railties-7.1.5/lib/rails/railtie.rb:226:in `method_missing'
rack-2.2.10/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.10/lib/rack/urlmap.rb:58:in `each'
rack-2.2.10/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
Env
Backtrace
/var/www/discourse/lib/discourse_ip_info.rb:15:in `open_db'
Env
Please format your post like this:
text goes here
have you changed anything recently? installed or removed a plugin, for example?
Fast guess is your credentials in app.yml are wrong or wrongly formated — like you don’t have two spaces before those lines.
After a brand new installation, there were no settings and the backend log reported an error
Can you be more specific? Thank you
You have someting like this in app.yml, right?
  DISCOURSE_MAXMIND_ACCOUNT_ID: <numbers>
  DISCOURSE_MAXMIND_LICENSE_KEY: <long string>
Both must be right, of course, but be sure you have two spaces before those lines. Because if you don’t have, it doesn’t show any errors, but Maxmind doesn’t work because databases aren’t downloaded.
Sure, the reason may he something else, but those missing spaces do exacly that.
  ## The maxmind geolocation IP account ID and license key for IP address lookups
  ## see https://meta.discourse.org/t/-/173941 for details
  #DISCOURSE_MAXMIND_ACCOUNT_ID: 123456
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
You have MaxMind commented so it can’t work.
