cbreit
(cb)
2 בספטמבר, 2023, 1:37pm
1
Hey people,
When running a docker based install, and setting DISCOURSE_MAXMIND_LICENSE_KEY the image creation process aborts with this error:
/var/www/discourse/lib/discourse_ip_info.rb:48:in `mmdb_download': undefined method `path' for nil:NilClass (NoMethodError)
filename = File.basename(gz_file.path)
from /var/www/discourse/lib/tasks/maxminddb.rake:67:in `block (3 levels) in <main>'
from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `each'
from /var/www/discourse/lib/tasks/maxminddb.rake:65:in `block (2 levels) in <main>'
When leaving DISCOURSE_MAXMIND_LICENSE_KEY empty, everything works fine.
Tested with versions: stable and tests-passed
The Maxmind license works – so both URLs provide access to the .mmdb files:
Just a guess (I’m not a ruby guys; so please go easy on me) – maybe the ‘.mmdb’ extension causes problems in FileHelper.download(...) a couple of lines below :
require "resolv"
class DiscourseIpInfo
include Singleton
def initialize
open_db(DiscourseIpInfo.path)
def open_db(path)
@loc_mmdb = mmdb_load(File.join(path, "GeoLite2-City.mmdb"))
@asn_mmdb = mmdb_load(File.join(path, "GeoLite2-ASN.mmdb"))
@cache = LruRedux::ThreadSafeCache.new(2000)
def self.path
@path ||= File.join(Rails.root, "vendor", "data")
def self.mmdb_path(name)
File.join(path, "#{name}.mmdb")
Adding “.mmdb” to the links provided above causes an Invalid edition ID error.
Hope this helps narrowing down the issue.
Hello and welcome @cbreit
I think we’ve had a couple of reports of some rebuilds failing over a Maxmind key issue:
Update from 3.0.0.beta16 to 3.1.0.beta2 - #17 by vmsman
My Discourse is Down. Certificate Issue? - #27 by JammyDodger
This may be the extra info we need to figure out what’s going on. Thanks for digging.
pfaffman
(Jay Pfaffman)
3 בספטמבר, 2023, 10:27am
4
Are you sure that your license key is valid and entered correctly?
cbreit
(cb)
3 בספטמבר, 2023, 12:20pm
5
You’re welcome.
Just let me know if I shall try something or if you need additional info.
cbreit
(cb)
3 בספטמבר, 2023, 12:23pm
6
The key id definitely valid.
And it’s also entered correctly as the whole stuff is fully automated via Ansible.
The same key works at other locations in the playbook like a charm (and there are also no rate-limiting issues).
Feels like the URL is just not working.
DaVania
(Ivan Miransky)
9 בספטמבר, 2023, 3:41pm
7
Since I have been having the same problem and can confirm that when clearing out the license key, my rebuild problems magically goes away.
I have even over a couple of days, tried my best to dig into the problem.
I think I have it right, but I might aswell be wrong.
During build, it seems like the mmdb files are missing, perhaps due to them not being present in the base image, or more likely, that they are being deleted and/or not even downloaded prior to them being loaded, hence the build fails..
Come to think of it, mmdb_download being called points to code trying to download the file.
I’ve successfully downloaded the files manually (from the within the docker container) with wget, so the license is working as expected.
MarcP
(MarcP)
29 בפברואר, 2024, 6:08am
8
Just to bump this is still an issue, just had the exact same when adding the key and uncommenting the setting in app.yml.
Got this notice when updating from main branch today:
Downloading MaxMindDB... MaxMind IP database updates require a license Please set DISCOURSE_MAXMIND_LICENSE_KEY to one you generated at https://www.maxmind.com MaxMind IP database updates require a license Please set DISCOURSE_MAXMIND_LICENSE_KEY to one you generated at https://www.maxmind.com
But never setup a license key for this, and don’t know how to integrate those anyway.
Update still completed so this doesn’t seem to be causing any problem, but may be some kind of a minor error.
Firepup650
(Firepup Sixfifty)
1 במרץ, 2024, 4:30am
10
I think that’s expected without a maxmind key?
Flow
(Florian Schmaus)
9 במאי, 2024, 12:24pm
11
We run into the same issue. Adding DISCOURSE_MAXMIND_ACCOUNT_ID to the env fixed this for me.
Strike that, I first assumed that the container build successfully, but that was not the case.
pfaffman
(Jay Pfaffman)
9 במאי, 2024, 1:36pm
13
Did you rebuld recently? What error do you have?
Flow
(Florian Schmaus)
9 במאי, 2024, 2:30pm
14
Yes, this was today. The error OP posted.
pmusaraj
(Penar Musaraj)
9 במאי, 2024, 5:44pm
15
Can you post the exact error you are seeing? There was a related change merged in the last 24 hours, so I suspect you may have a slightly different problem to the OP (if you are on tests-passed):
https://github.com/discourse/discourse/commit/7079698cdfb6f0cd73cdfd305b15350634fcd56a
RBoy
(RBoy)
15 במאי, 2024, 7:45am
16
Continuing the conversion from over here .
I updated app.yml to include the account ID
Now I see an error when I rebuild (tests-passed):
MaxMindDB (GeoLite2-City) could not be downloaded: 400 Error
Message
Backtrace
/var/www/discourse/lib/tasks/maxminddb.rake:83:in `rescue in block (2 levels) in <main>'
/var/www/discourse/lib/tasks/maxminddb.rake:70:in `block (2 levels) in <main>'
Any ideas what this may be?
RBoy
(RBoy)
15 במאי, 2024, 8:00am
17
Also seeing these in the logs
Message
MaxMindDB (/var/www/discourse/vendor/data/GeoLite2-City.mmdb) could not be found: No such file or directory @ rb_sysopen - /var/www/discourse/vendor/data/GeoLite2-City.mmdb
Backtrace
/var/www/discourse/lib/discourse_ip_info.rb:88:in `rescue in mmdb_load'
/var/www/discourse/lib/discourse_ip_info.rb:84:in `mmdb_load'
/var/www/discourse/lib/discourse_ip_info.rb:14:in `open_db'
/var/www/discourse/lib/discourse_ip_info.rb:10:in `initialize'
/usr/local/lib/ruby/3.2.0/singleton.rb:127:in `new'
/usr/local/lib/ruby/3.2.0/singleton.rb:127:in `block in instance'
/usr/local/lib/ruby/3.2.0/singleton.rb:125:in `synchronize'
/usr/local/lib/ruby/3.2.0/singleton.rb:125:in `instance'
/var/www/discourse/lib/discourse_ip_info.rb:175:in `get'
/var/www/discourse/app/serializers/concerns/user_auth_tokens_mixin.rb:13:in `location'
(eval):5:in `_fast_attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:455:in `attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:89:in `block in _serializable_array'
activerecord-7.0.8.1/lib/active_record/relation/delegation.rb:88:in `each'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:79:in `map'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:79:in `_serializable_array'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:73:in `serializable_array'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:53:in `as_json'
activesupport-7.0.8.1/lib/active_support/json/encoding.rb:22:in `encode'
activesupport-7.0.8.1/lib/active_support/core_ext/object/json.rb:42:in `to_json'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:331:in `to_json'
multi_json-1.15.0/lib/multi_json/adapters/oj.rb:56:in `dump'
multi_json-1.15.0/lib/multi_json/adapter.rb:25:in `dump'
multi_json-1.15.0/lib/multi_json.rb:139:in `dump'
/var/www/discourse/app/controllers/application_controller.rb:554:in `render_json_dump'
/var/www/discourse/app/controllers/users_controller.rb:156:in `block (2 levels) in show'
actionpack-7.0.8.1/lib/action_controller/metal/mime_responds.rb:214:in `respond_to'
/var/www/discourse/app/controllers/users_controller.rb:149:in `show'
actionpack-7.0.8.1/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-7.0.8.1/lib/abstract_controller/base.rb:215:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack-7.0.8.1/lib/abstract_controller/callbacks.rb:234:in `block in process_action'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:118:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:423:in `block in with_resolved_locale'
i18n-1.14.5/lib/i18n.rb:351:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:423:in `with_resolved_locale'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:127:in `block in run_callbacks'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:138:in `run_callbacks'
actionpack-7.0.8.1/lib/abstract_controller/callbacks.rb:233:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/rescue.rb:23:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/instrumentation.rb:67:in `block in process_action'
activesupport-7.0.8.1/lib/active_support/notifications.rb:206:in `block in instrument'
activesupport-7.0.8.1/lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport-7.0.8.1/lib/active_support/notifications.rb:206:in `instrument'
actionpack-7.0.8.1/lib/action_controller/metal/instrumentation.rb:66:in `process_action'
actionpack-7.0.8.1/lib/action_controller/metal/params_wrapper.rb:259:in `process_action'
activerecord-7.0.8.1/lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack-7.0.8.1/lib/abstract_controller/base.rb:151:in `process'
actionview-7.0.8.1/lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler-3.3.1/lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
actionpack-7.0.8.1/lib/action_controller/metal.rb:188:in `dispatch'
actionpack-7.0.8.1/lib/action_controller/metal.rb:251:in `dispatch'
actionpack-7.0.8.1/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack-7.0.8.1/lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack-7.0.8.1/lib/action_dispatch/journey/router.rb:50:in `block in serve'
actionpack-7.0.8.1/lib/action_dispatch/journey/router.rb:32:in `each'
actionpack-7.0.8.1/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-7.0.8.1/lib/action_dispatch/routing/route_set.rb:852:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack-2.2.9/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.9/lib/rack/conditional_get.rb:27:in `call'
rack-2.2.9/lib/rack/head.rb:12:in `call'
actionpack-7.0.8.1/lib/action_dispatch/http/permissions_policy.rb:38:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:393:in `call'
/var/www/discourse/lib/middleware/csp_script_nonce_injector.rb:12:in `call'
/var/www/discourse/config/initializers/008-rack-cors.rb:14:in `call'
rack-2.2.9/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.9/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport-7.0.8.1/lib/active_support/callbacks.rb:99:in `run_callbacks'
actionpack-7.0.8.1/lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/debug_exceptions.rb:28:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/show_exceptions.rb:29:in `call'
logster-2.19.1/lib/logster/middleware/reporter.rb:40:in `call'
railties-7.0.8.1/lib/rails/rack/logger.rb:40:in `call_app'
railties-7.0.8.1/lib/rails/rack/logger.rb:27:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/remote_ip.rb:93:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/request_id.rb:26:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:24:in `call'
rack-2.2.9/lib/rack/method_override.rb:24:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.2.9/lib/rack/sendfile.rb:110:in `call'
actionpack-7.0.8.1/lib/action_dispatch/middleware/host_authorization.rb:131:in `call'
rack-mini-profiler-3.3.1/lib/mini_profiler.rb:191:in `call'
message_bus-4.3.8/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:277:in `call'
railties-7.0.8.1/lib/rails/engine.rb:530:in `call'
railties-7.0.8.1/lib/rails/railtie.rb:226:in `public_send'
railties-7.0.8.1/lib/rails/railtie.rb:226:in `method_missing'
rack-2.2.9/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.9/lib/rack/urlmap.rb:58:in `each'
rack-2.2.9/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/bin/unicorn:25:in `<main>'
Message
MaxMindDB (/var/www/discourse/vendor/data/GeoLite2-ASN.mmdb) could not be found: No such file or directory @ rb_sysopen - /var/www/discourse/vendor/data/GeoLite2-ASN.mmdb
Backtrace
/var/www/discourse/lib/discourse_ip_info.rb:15:in `open_db'
Running discourse Commits · discourse/discourse · GitHub
jomaxro
(Joshua Rosenfeld)
15 במאי, 2024, 6:27pm
18
I just ran into this myself on a self-hosted instance I have. Excerpts from the upgrade logs below.
Stopping 2 Unicorn worker(s), to free up memory
Stopping job queue to reclaim memory, master pid is 2132120
$ cd /var/www/discourse/plugins/docker_manager && git fetch --tags --prune-tags --prune --force
$ cd /var/www/discourse/plugins/docker_manager && git reset --hard HEAD@{upstream}
HEAD is now at dec486d Update translations (#213)
$ bundle install --retry 3 --jobs 4
Bundle complete! 137 Gemfile dependencies, 170 gems now installed.
Gems in the groups 'development' and 'test' were not installed.
Bundled gems are installed into `./vendor/bundle`
- dist/javascripts/squoosh/squoosh_resize.js: 4.53 kB (1.29 kB gzipped)
Done in 89.56s.
Purging temp files
Bundling assets
#<Thread:0x00007fe9902157b0 /var/www/discourse/lib/tasks/maxminddb.rake:62 run> terminated with exception (report_on_exception is true):
Skipping: break_string-cc617154cd957804f2f6a1f3bc68258c9cdca3d4b9a322bf777d145fed04790e.js already compressed
Skipping: service-worker-fadf8e4b5a6844dadaf6c3f1fb335fdd9dcb030f2bc22fcb96537679dfd2fa2d.js already compressed
Compressing: locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js
gzip -f -c -9 /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js > /var/www/discourse/public/assets/locales/i18n-3b40e842fd72b9bcc74ea83e094c823cd9ca535e4ecc5e78722e6f99d3656137.js.gz
Compressing Javascript and Generating Source Maps
precompile target: color_definitions Light (Light)
precompile target: color_definitions Light (air-light)
precompile target: color_definitions Light (air-dark)
precompile target: color_definitions Light (Base)
precompile target: desktop_theme Dark
precompile target: mobile_theme Dark
precompile target: color_definitions Dark (Simple Dark)
precompile target: color_definitions Dark (air-light)
precompile target: color_definitions Dark (air-dark)
precompile target: color_definitions Dark (Base)
Done compiling CSS: 2024-05-15 18:13:29 UTC
Docker Manager: FAILED TO UPGRADE
#<RuntimeError: RuntimeError>
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:210:in `run'
/var/www/discourse/plugins/docker_manager/lib/docker_manager/upgrader.rb:111:in `upgrade'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:19:in `block in <main>'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `fork'
/var/www/discourse/plugins/docker_manager/scripts/docker_manager_upgrade.rb:6:in `<main>'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/runner/runner_command.rb:43:in `load'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands/runner/runner_command.rb:43:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor/command.rb:28:in `run'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor/invocation.rb:127:in `invoke_command'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/thor-1.3.1/lib/thor.rb:527:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/command/base.rb:87:in `perform'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/command.rb:48:in `invoke'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/railties-7.0.8.1/lib/rails/commands.rb:18:in `<main>'
<internal:/usr/local/lib/ruby/site_ruby/3.2.0/rubygems/core_ext/kernel_require.rb>:37:in `require'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/bootsnap-1.18.3/lib/bootsnap/load_path_cache/core_ext/kernel_require.rb:30:in `require'
bin/rails:18:in `<main>'
Spinning up 2 Unicorn worker(s) that were stopped initially
I have been having the same issue for a while now and had to disable the MaxMind integration in order to rebuild.
I think the issue may have been fixed at least on tests-passed, but I’m on latest stable (3.2.2) so I assumed I would have to wait. However, there is a report of the same with 3.3.0, so perhaps this needs a closer look.
jomaxro
(Joshua Rosenfeld)
15 במאי, 2024, 6:47pm
22
I tried the following, and it seemed to work:
SSH’d into my server.
Edited app.yml to add DISCOURSE_MAXMIND_ACCOUNT_ID: REDACTED
Ran ./launcher rebuild app
The rebuild completed without apparent error. Site is up and running. Unfortunately, until there is another commit pushed to discourse_docker, I can’t test the update through the admin dashboard to see if that resolved it or not.
Edit: It appears that while the rebuild was successful, MaxMind is not functional.
I’ve tried that too, but including the DISCOURSE_MAXMIND_ACCOUNT_ID made no difference for me as the rebuild still doesn’t finish (with latest stable). Only skipping DISCOURSE_MAXMIND_LICENSE_KEY seems to work.
Log
Done compiling CSS: 2024-05-15 20:34:22 UTC
I, [2024-05-15T20:34:22.860678 #1] INFO -- : Checking 'Category Icons' for 'default'... up to date
Checking 'discourse-profile-custom-link' for 'default'... up to date
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile' failed with return #<Process::Status: pid 1399 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "tag"=>"precompile", "hook"=>"assets_precompile", "cmd"=>["su discourse -c 'SKIP_EMBER_CLI_COMPILE=1 bundle exec rake themes:update assets:precompile'"]}
