После чистой установки Discourse 3.4.0.beta3-dev отсутствуют настройки: в логах ошибка GeoLite2-City.mmdb, GeoLite2-ASN.mmdb
После чистой установки настроек нет
После установки discourse 3.4.0.beta3-dev в логах ошибки /GeoLite2-City.mmdb  GeoLite2-ASN.mmdb
MaxMindDB (/var/www/discourse/vendor/data/GeoLite2-City.mmdb) не найден: No such file or directory @ rb_sysopen - /var/www/discourse/vendor/data/GeoLite2-City.mmdb
17:25
MaxMindDB (/var/www/discourse/vendor/data/GeoLite2-ASN.mmdb) не найден: No such file or directory @ rb_sysopen - /var/www/discourse/vendor/data/GeoLite2-ASN.mmdb
17:25
Сообщение (2 сообщения)
Трассировка стека
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:130:in `block in warn'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `block in dispatch'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `each'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:231:in `dispatch'
activesupport-7.1.5/lib/active_support/broadcast_logger.rb:130:in `warn'
/var/www/discourse/lib/discourse_ip_info.rb:88:in `rescue in mmdb_load'
/var/www/discourse/lib/discourse_ip_info.rb:84:in `mmdb_load'
/var/www/discourse/lib/discourse_ip_info.rb:14:in `open_db'
/var/www/discourse/lib/discourse_ip_info.rb:10:in `initialize'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `new'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `block in instance'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `synchronize'
/usr/local/lib/ruby/3.3.0/singleton.rb:124:in `instance'
/var/www/discourse/lib/discourse_ip_info.rb:175:in `get'
/var/www/discourse/app/serializers/concerns/user_auth_tokens_mixin.rb:13:in `location'
(eval at active_model_serializers-0.8.4/lib/active_model/serializer.rb:467):5:in `_fast_attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:468:in `rescue in attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:455:in `attributes'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:480:in `_serializable_hash'
active_model_serializers-0.8.4/lib/active_model/serializer.rb:359:in `serializable_hash'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:89:in `block in _serializable_array'
activerecord-7.1.5/lib/active_record/relation/delegation.rb:100:in `each'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:79:in `map'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:79:in `_serializable_array'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:73:in `serializable_array'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:53:in `as_json'
activesupport-7.1.5/lib/active_support/json/encoding.rb:23:in `encode'
activesupport-7.1.5/lib/active_support/core_ext/object/json.rb:42:in `to_json'
active_model_serializers-0.8.4/lib/active_model/array_serializer.rb:63:in `to_json'
multi_json-1.15.0/lib/multi_json/adapters/oj.rb:56:in `dump'
multi_json-1.15.0/lib/multi_json/adapter.rb:25:in `dump'
multi_json-1.15.0/lib/multi_json.rb:139:in `dump'
/var/www/discourse/app/controllers/application_controller.rb:759:in `json_result'
/var/www/discourse/app/controllers/users_controller.rb:258:in `update'
actionpack-7.1.5/lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack-7.1.5/lib/abstract_controller/base.rb:224:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/rendering.rb:165:in `process_action'
actionpack-7.1.5/lib/abstract_controller/callbacks.rb:259:in `block in process_action'
activesupport-7.1.5/lib/active_support/callbacks.rb:121:in `block in run_callbacks'
/var/www/discourse/app/controllers/application_controller.rb:424:in `block in with_resolved_locale'
i18n-1.14.6/lib/i18n.rb:353:in `with_locale'
/var/www/discourse/app/controllers/application_controller.rb:424:in `with_resolved_locale'
activesupport-7.1.5/lib/active_support/callbacks.rb:130:in `block in run_callbacks'
activesupport-7.1.5/lib/active_support/callbacks.rb:141:in `run_callbacks'
actionpack-7.1.5/lib/abstract_controller/callbacks.rb:258:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/rescue.rb:25:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/instrumentation.rb:74:in `block in process_action'
activesupport-7.1.5/lib/active_support/notifications.rb:206:in `block in instrument'
activesupport-7.1.5/lib/active_support/notifications/instrumenter.rb:58:in `instrument'
activesupport-7.1.5/lib/active_support/notifications.rb:206:in `instrument'
actionpack-7.1.5/lib/action_controller/metal/instrumentation.rb:73:in `process_action'
actionpack-7.1.5/lib/action_controller/metal/params_wrapper.rb:261:in `process_action'
activerecord-7.1.5/lib/active_record/railties/controller_runtime.rb:32:in `process_action'
actionpack-7.1.5/lib/abstract_controller/base.rb:160:in `process'
actionview-7.1.5/lib/action_view/rendering.rb:40:in `process'
rack-mini-profiler-3.3.1/lib/mini_profiler/profiling_methods.rb:115:in `block in profile_method'
actionpack-7.1.5/lib/action_controller/metal.rb:227:in `dispatch'
actionpack-7.1.5/lib/action_controller/metal.rb:309:in `dispatch'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:49:in `dispatch'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:32:in `serve'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:51:in `block in serve'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:131:in `block in find_routes'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:124:in `each'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:124:in `find_routes'
actionpack-7.1.5/lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack-7.1.5/lib/action_dispatch/routing/route_set.rb:882:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:64:in `call'
rack-2.2.10/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.10/lib/rack/conditional_get.rb:40:in `call'
rack-2.2.10/lib/rack/head.rb:12:in `call'
actionpack-7.1.5/lib/action_dispatch/http/permissions_policy.rb:36:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:399:in `call'
/var/www/discourse/lib/middleware/csp_script_nonce_injector.rb:12:in `call'
/var/www/discourse/config/initializers/008-rack-cors.rb:14:in `call'
rack-2.2.10/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.10/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/cookies.rb:689:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
activesupport-7.1.5/lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack-7.1.5/lib/action_dispatch/middleware/callbacks.rb:28:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/debug_exceptions.rb:29:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/show_exceptions.rb:31:in `call'
logster-2.20.0/lib/logster/middleware/reporter.rb:40:in `call'
/var/www/discourse/lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:35:in `call_app'
/var/www/discourse/lib/freedom_patches/rails_rack_logger_from_rails_7_2.rb:22:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/request_id.rb:28:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:24:in `call'
rack-2.2.10/lib/rack/method_override.rb:24:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/executor.rb:14:in `call'
rack-2.2.10/lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler-3.3.1/lib/mini_profiler.rb:334:in `call'
/var/www/discourse/lib/middleware/processing_request.rb:12:in `call'
message_bus-4.3.8/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:360:in `call'
actionpack-7.1.5/lib/action_dispatch/middleware/remote_ip.rb:92:in `call'
railties-7.1.5/lib/rails/engine.rb:536:in `call'
railties-7.1.5/lib/rails/railtie.rb:226:in `public_send'
railties-7.1.5/lib/rails/railtie.rb:226:in `method_missing'
rack-2.2.10/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.10/lib/rack/urlmap.rb:58:in `each'
rack-2.2.10/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
Окружение
Трассировка стека
/var/www/discourse/lib/discourse_ip_info.rb:15:in `open_db'
Окружение
Пожалуйста, оформляйте ваш пост следующим образом:
текст здесь
Вы что-то меняли недавно? Например, устанавливали или удаляли плагин?
Скорее всего, ваши учётные данные в app.yml указаны неверно или имеют неправильный формат — например, вам не хватает двух пробелов перед этими строками.
После новой установки настройки отсутствовали, а в журнале бэкенда была зафиксирована ошибка.
Можете уточнить? Спасибо.
У вас в app.yml что-то вроде этого, верно?
  DISCOURSE_MAXMIND_ACCOUNT_ID: <numbers>
  DISCOURSE_MAXMIND_LICENSE_KEY: <long string>
Конечно, оба значения должны быть правильными, но убедитесь, что перед этими строками есть два пробела. Иначе ошибок не будет, но MaxMind не заработает, потому что базы данных не будут загружены.
Конечно, причина может быть и в чём-то другом, но именно отсутствие этих пробелов приводит к такой проблеме.
  ## Идентификатор аккаунта и лицензионный ключ MaxMind для геолокации по IP-адресу
  ## подробности см. по адресу https://meta.discourse.org/t/-/173941
  #DISCOURSE_MAXMIND_ACCOUNT_ID: 123456
  #DISCOURSE_MAXMIND_LICENSE_KEY: 1234567890123456
  - exec: echo "Начало пользовательских команд"
  ## Если вы хотите установить адрес электронной почты в поле «От» для первой регистрации, раскомментируйте и измените:
  ## После получения первого письма о регистрации закомментируйте строку обратно. Она должна выполниться только один раз.
  - exec: echo "Конец пользовательских команд"
Вы закомментировали MaxMind, поэтому он не может работать.
