AppEvents
The AppEvent system in Discourse provides a pub/sub mechanism for handling UI updates and component interactions - and these events are triggered via calls of AppEvent.trigger.
This topic consolidates a list of all such event triggers and their arguments, along with line-of-code references to the Discourse source code.
How to figure out what happens on an event trigger
AppEvent is based on the Ember’s Evented class, and similarly, events are handled by the on method.
Once the specific AppEvent trigger is identified, you may search in the source code for the corresponding .on method with the event name as the first argument.
This method should have an event handler function passed in as the last argument for executing any necessary logic upon trigger of the event.
Taking the composer:open event, we can search for appEvents.on("composer:open". This could lead us to 1 or more places in the code where the event is handled. Each of these would execute a callback function whenever the event is triggered, for example:
this.appEvents.on("composer:opened", this, this._findMessages);
You would then refer to the definition of the callback function this._findMessages to understand what happens when the composer:opened event is triggered. This callback function can take in arguments passed in from the trigger of the event to be processed within the scope of the function.
List of AppEvent Triggers
ace
ace:resize
No arguments passed to this event.
Detailed List
/frontend/discourse/admin/components/admin-theme-editor.gjs#118
/plugins/discourse-data-explorer/assets/javascripts/discourse/controllers/admin-plugins/explorer/index.js#119
/plugins/discourse-data-explorer/assets/javascripts/discourse/controllers/admin-plugins/explorer/queries/details.js#137
bookmarks
bookmarks:changed
| Position | Argument | Type | Always Present | Description |
| 1 | bookmarkFormData.saveData | property | True | - |
| 2 | this.bookmarkModel.attachedTo | called_function | True | - |
Detailed List
/frontend/discourse/app/components/bookmark-list.gjs#54
| Position | Argument | Type | Description |
| 1 | null | null | - |
| 2 | bookmark1.attachedTo | called_function | - |
/frontend/discourse/app/components/bookmark-list.gjs#85
| 1 | savedData1 | variable | - |
/frontend/discourse/app/controllers/topic.js#1510
| 1 | bookmarkFormData.saveData | property | - |
| 2 | bookmark.attachedTo | called_function | - |
/frontend/discourse/app/lib/topic-bookmark-manager.js#57
| 2 | this.bookmarkModel.attachedTo | called_function | - |
/frontend/discourse/app/models/post.ts#1248
| 1 | data | variable | - |
| 2 | objectArg2 | object | - |
| - | objectArg2.target | string | - |
| - | objectArg2.targetId | property | - |
/frontend/discourse/app/models/post.ts#1268
/frontend/discourse/app/models/topic.ts#1289
/plugins/chat/assets/javascripts/discourse/lib/chat-message-interactor.js#374
/plugins/discourse-data-explorer/assets/javascripts/discourse/controllers/group/reports/show.js#121
calendar
calendar:create-invitee-status
| 1 | objectArg1 | object | True | - |
| - | objectArg1.status | variable | True | - |
| - | objectArg1.postId | property | True | - |
calendar:invitee-left-event
| - | objectArg1.invitee | variable | True | - |
calendar:update-invitee-status
card
card:close
card:hide
card:show
| 1 | username | variable | True | - |
| 2 | target | variable | True | - |
| 3 | event | variable | True | - |
chat
chat:message_interaction
| 1 | result1.interaction | property | True | - |
chat:modify-selection
| 1 | event | variable | True | - |
| 2 | objectArg2 | object | True | - |
| - | objectArg2.type | variable | True | - |
| - | objectArg2.context | property | True | - |
chat:open-insert-link-modal
chat:open-url
| 1 | url | variable | True | - |
Detailed List
/plugins/chat/assets/javascripts/discourse/routes/chat.js#66
| 1 | url | variable | - |
/plugins/chat/assets/javascripts/discourse/routes/chat.js#71
chat:refresh-channel-members
chat:rerender-header
chat:toggle-close
| 1 | event | variable | False | - |
Detailed List
/plugins/chat/assets/javascripts/discourse/initializers/chat-keyboard-shortcuts.js#117
| 1 | event | variable | - |
/plugins/chat/assets/javascripts/discourse/routes/chat.js#76
chat:toggle-expand
| 1 | this.chatStateManager.isDrawerExpanded | property | True | - |
Detailed List
/plugins/chat/assets/javascripts/discourse/components/chat-drawer.gjs#163
| 1 | this.chatStateManager.isDrawerExpanded | property | - |
/plugins/chat/assets/javascripts/discourse/services/chat.js#437
composer
composer:add-files
| 1 | undefined | undefined | True | - |
| - | objectArg2.skipPlaceholder | boolean | True | - |
composer:cancel-upload
composer:cancelled
Detailed List
/frontend/discourse/app/services/composer.js#1654
/frontend/discourse/app/services/composer.js#1669
/frontend/discourse/app/services/composer.js#1686
composer:created-post
composer:div-resizing
composer:edited-post
composer:find-similar
composer:insert-block
| 1 | template.content | property | True | - |
Detailed List
/frontend/discourse/app/controllers/topic.js#535
| 1 | quotedText | variable | - |
/frontend/discourse/app/controllers/topic.js#777
| 1 | quotedText.trim | called_function | - |
/frontend/discourse/app/lib/lightbox/quote-image.js#89
| 1 | quote | variable | - |
/plugins/discourse-templates/assets/javascripts/discourse/services/d-templates.js#103
| 1 | template.content | property | - |
composer:insert-text
| 1 | document.activeElement.href | property | True | - |
| - | objectArg2.ensureSpace | boolean | True | - |
composer:open
| - | objectArg1.model | property | True | - |
composer:opened
composer:preview-toggled
| 1 | this.isPreviewVisible | property | True | - |
composer:replace-text
| 1 | match | variable | True | - |
| 2 | replacement | variable | True | - |
composer:reply-reloaded
| 1 | this | this | True | - |
Detailed List
/frontend/discourse/app/models/composer.js#1011
| 1 | this | this | - |
/frontend/discourse/app/models/composer.js#1030
composer:resize-ended
composer:resize-started
composer:resized
Detailed List
/frontend/discourse/app/components/composer-body.js#73
/frontend/discourse/app/components/composer-container.gjs#296
composer:saved
composer:show-preview
composer:toolbar-popup-menu-button-clicked
| 1 | menuItem | variable | True | - |
composer:typed-reply
this.composerEventPrefix:all-uploads-complete
this.composerEventPrefix:apply-surround
| 1 | [grid] | string | True | - |
| 2 | [/grid] | string | True | - |
| 3 | grid_surround | string | True | - |
| 4 | objectArg4 | object | True | - |
| - | objectArg4.useBlockMode | boolean | True | - |
this.composerEventPrefix:closed
this.composerEventPrefix:replace-text
| 1 | matchingPlaceholder1.index1 | property | True | - |
| 2 | replacement1 | variable | True | - |
| 3 | objectArg3 | object | False | - |
| - | objectArg3.regex | variable | False | - |
| - | objectArg3.index | variable | False | - |
Detailed List
/frontend/discourse/app/components/composer-editor.gjs#511
| 1 | matchingPlaceholder1.index1 | property | - |
| 2 | replacement1 | variable | - |
| 3 | objectArg3 | object | - |
| - | objectArg3.regex | variable | - |
| - | objectArg3.index | variable | - |
/frontend/discourse/app/components/composer-editor.gjs#537
| 1 | match1 | variable | - |
/frontend/discourse/app/components/composer-editor.gjs#597
| 2 | string | string | - |
this.composerEventPrefix:upload-cancelled
| 1 | file.id | property | True | - |
this.composerEventPrefix:upload-error
| 1 | file | variable | True | - |
this.composerEventPrefix:upload-started
| 1 | file.name | property | True | - |
this.composerEventPrefix:upload-success
| 2 | upload | variable | True | - |
this.composerEventPrefix:uploads-aborted
Detailed List
/frontend/discourse/app/lib/uppy/composer-upload.js#132
/frontend/discourse/app/lib/uppy/composer-upload.js#181
this.composerEventPrefix:uploads-cancelled
this.composerEventPrefix:uploads-preprocessing-complete
this.composerEventPrefix:will-close
this.composerEventPrefix:will-open
composer-messages
composer-messages:close
Detailed List
/frontend/discourse/app/services/composer.js#918
/plugins/discourse-templates/assets/javascripts/discourse/services/d-templates.js#70
composer-messages:create
| - | objectArg1.extraClass | string | True | - |
| - | objectArg1.templateName | string | True | - |
| - | objectArg1.body | called_function | True | - |
Detailed List
/frontend/discourse/app/services/composer.js#794
| 1 | objectArg1 | object | - |
| - | objectArg1.extraClass | string | - |
| - | objectArg1.templateName | string | - |
| - | objectArg1.body | called_function | - |
/frontend/discourse/app/services/composer.js#804
/frontend/discourse/app/services/composer.js#969
| - | objectArg1.body | variable | - |
/frontend/discourse/app/services/composer.js#993
/frontend/discourse/app/services/composer.js#1002
/frontend/discourse/app/static/prosemirror/extensions/mention.js#251
composer-service
composer-service:last-validated-at-cleared
composer-service:last-validated-at-updated
| - | objectArg1.model | variable | True | - |
Detailed List
/frontend/discourse/app/services/composer.js#1073
| - | objectArg1.model | variable | - |
/frontend/discourse/app/services/composer.js#1282
| - | objectArg1.model | property | - |
count-updated
count-updated:user.username_lower:key
| 1 | value | variable | True | - |
cta
cta:shown
d-editor
d-editor:preview-click-group-card
| 1 | event1.target | property | True | - |
| 2 | event1 | variable | True | - |
d-editor:preview-click-user-card
destroyed-custom-html
destroyed-custom-html:this.name
discourse
discourse:focus-changed
| 1 | session.hasFocus | property | True | - |
discourse-ai
discourse-ai:bot-header-icon-clicked
discourse-ai:bot-pm-created
| - | objectArg1.id | property | True | - |
| - | objectArg1.slug | property | True | - |
| - | objectArg1.title | variable | True | - |
discourse-ai:force-conversations-sidebar
discourse-ai:new-conversation-btn-clicked
discourse-ai:stop-forcing-conversations-sidebar
discourse-reactions
discourse-reactions:reaction-toggled
| - | objectArg1.post | variable | True | - |
| - | objectArg1.reaction | property | True | - |
discourse-solved
discourse-solved:solution-toggled
| 1 | post1 | variable | True | - |
Detailed List
/plugins/discourse-solved/assets/javascripts/discourse/components/solved-accept-answer-button.gjs#28
| 1 | post1 | variable | - |
/plugins/discourse-solved/assets/javascripts/discourse/components/solved-unaccept-answer-button.gjs#28
discourse-templates
discourse-templates:show
| - | objectArg1.onInsertTemplate | variable | True | - |
do-not-disturb
do-not-disturb:changed
| 1 | this.do_not_disturb_until | property | True | - |
dom
dom:clean
draft
draft:destroyed
| 1 | key | variable | True | - |
emoji-picker
emoji-picker:close
flag
flag:created
| - | objectArg1.message | property | True | - |
full-page-search
full-page-search:trigger-search
group
group:join
| 1 | group1 | variable | True | - |
group:leave
| 1 | model1 | variable | True | - |
header
header:hide-topic
header:keyboard-trigger
| - | objectArg1.type | string | True | - |
| - | objectArg1.event | variable | False | - |
Detailed List
/frontend/discourse/app/services/keyboard-shortcuts.js#531
| - | objectArg1.type | string | - |
| - | objectArg1.event | variable | - |
/frontend/discourse/app/services/keyboard-shortcuts.js#540
/frontend/discourse/app/services/keyboard-shortcuts.js#547
/frontend/discourse/app/services/search.js#68
header:show-topic
| 1 | topic1 | variable | True | - |
header:update-topic
| 1 | composer.topic | property | True | - |
Detailed List
/frontend/discourse/app/controllers/topic.js#1843
| 1 | topic | variable | - |
/frontend/discourse/app/instance-initializers/subscribe-user-notifications.js#168
| 2 | 5000 | integer | - |
/frontend/discourse/app/routes/topic.js#428
| 1 | model | variable | - |
/frontend/discourse/app/services/composer.js#1203
| 1 | composer.topic | property | - |
/plugins/discourse-assign/assets/javascripts/discourse/initializers/extend-for-assigns.js#502
inserted-custom-html
inserted-custom-html:this.name
interface-color
interface-color:changed
| 1 | LIGHT_VALUE_FOR_COOKIE | variable | True | - |
Detailed List
/frontend/discourse/app/services/interface-color.js#95
| 1 | LIGHT_VALUE_FOR_COOKIE | variable | - |
/frontend/discourse/app/services/interface-color.js#113
| 1 | DARK_VALUE_FOR_COOKIE | variable | - |
/frontend/discourse/app/services/interface-color.js#127
/frontend/discourse/app/services/interface-color.js#136
keyboard
keyboard:move-selection
| - | objectArg1.articles | variable | True | - |
| - | objectArg1.selectedArticle | variable | True | - |
notifications
notifications:changed
Detailed List
/frontend/discourse/app/instance-initializers/subscribe-user-notifications.js#160
/plugins/chat/assets/javascripts/discourse/services/chat-tracking-state-manager.js#110
page
page:changed
| - | objectArg1.url | variable | True | - |
| - | objectArg1.title | called_function | False | - |
| - | objectArg1.currentRouteName | property | False | - |
| - | objectArg1.replacedOnlyQueryParams | variable | False | - |
Detailed List
/frontend/discourse/app/lib/page-tracker.js#42
| - | objectArg1.url | variable | - |
| - | objectArg1.title | called_function | - |
| - | objectArg1.currentRouteName | property | - |
| - | objectArg1.replacedOnlyQueryParams | variable | - |
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#37
| - | objectArg1.url | string | - |
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#53
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#93
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#124
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#141
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#153
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#172
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#201
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#218
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#239
page:compose-reply
| 1 | topic | variable | True | - |
page:like-toggled
| 2 | likeAction1 | variable | True | - |
page:topic-loaded
policy
policy:changed
| - | objectArg1.controller | variable | True | - |
| - | objectArg1.message | variable | True | - |
poll
poll:voted
| 1 | poll1 | variable | True | - |
| 2 | this.post | property | True | - |
| 3 | this.vote | property | True | - |
Detailed List
/plugins/poll/assets/javascripts/discourse/components/poll.gjs#190
| 1 | poll1 | variable | - |
| 2 | this.post | property | - |
| 3 | this.vote | property | - |
/plugins/poll/assets/javascripts/discourse/components/poll.gjs#448
post
post:created
| 1 | createdPost | variable | True | - |
post:highlight
| 1 | result.payload.post_number | property | True | - |
| 2 | options | variable | False | - |
Detailed List
/frontend/discourse/app/lib/url.js#366
| 1 | closest | variable | - |
/frontend/discourse/app/routes/topic/from-params.js#99
/frontend/discourse/app/services/composer.js#1211
| 1 | result.payload.post_number | property | - |
| 2 | options | variable | - |
post:show-revision
| 1 | copy.postNumber | property | True | - |
| 2 | copy.revisionNumber | property | True | - |
post-stream
post-stream:filter-replies
| - | objectArg1.topic_id | property | True | - |
| - | objectArg1.post_number | variable | True | - |
| - | objectArg1.post_id | variable | True | - |
post-stream:filter-show-all
| 1 | this.args.streamFilters | property | True | - |
post-stream:filter-upwards
post-stream:gap-expanded
| - | objectArg1.post_id | property | True | - |
quote-button
quote-button:edit
quote-button:quote
reviewablenote
reviewablenote:created
| 1 | data1 | variable | True | - |
| 2 | this.args.reviewable | property | True | - |
| 3 | this.formApi | property | True | - |
search
search:search_result_view
| - | objectArg1.page | property | True | - |
search-menu
search-menu:search_menu_opened
sidebar-hamburger-dropdown
sidebar-hamburger-dropdown:rendered
site-header
site-header:force-refresh
this.eventPrefix
this.eventPrefix:insert-text
| 1 | markdown | variable | True | - |
Detailed List
/frontend/discourse/app/lib/textarea-text-manipulation.js#447
| 1 | table | variable | - |
/frontend/discourse/app/lib/textarea-text-manipulation.js#501
| 1 | markdown | variable | - |
topic
topic:created
| 2 | this | this | True | - |
topic:current-post-changed
topic:current-post-scrolled
| - | objectArg1.postIndex | property | True | - |
| - | objectArg1.percent | called_function | True | - |
topic:jump-to-post
| 1 | this.get | called_function | True | - |
Detailed List
/frontend/discourse/app/controllers/topic.js#1085
| 1 | this.get | called_function | - |
/frontend/discourse/app/controllers/topic.js#1478
| 1 | postId | variable | - |
topic:keyboard-trigger
topic:scrolled
| 1 | offset | variable | True | - |
topic:timings-sent
| 1 | data | variable | True | - |
topic-entrance
topic-entrance:show
| - | objectArg1.topic | variable | True | - |
| - | objectArg1.position | called_function | True | - |
Detailed List
/frontend/discourse/app/components/basic-topic-list.gjs#89
| - | objectArg1.topic | variable | - |
| - | objectArg1.position | called_function | - |
/frontend/discourse/app/components/featured-topic.gjs#14
| - | objectArg1.topic | property | - |
/frontend/discourse/app/components/mobile-category-topic.gjs#19
topic-header
topic-header:trigger-this.args.type-card
| 1 | this.args.username | property | True | - |
| 2 | e1.target | property | True | - |
| 3 | e1 | variable | True | - |
upload-mixin
upload-mixin:this.config.id:all-uploads-complete
upload-mixin:this.config.id:in-progress-uploads
| 1 | this.inProgressUploads | property | True | - |
upload-mixin:this.config.id:upload-cancelled
upload-mixin:this.config.id:upload-success
| 2 | completeResponse | variable | True | - |
Detailed List
/frontend/discourse/app/lib/uppy/uppy-upload.js#252
| 1 | file.name | property | - |
| 2 | completeResponse | variable | - |
/frontend/discourse/app/lib/uppy/uppy-upload.js#273
| 2 | upload | variable | - |
upload-mixin:this.config.id:uploads-cancelled
user-card
user-card:after-show
| - | objectArg1.user | variable | True | - |
user-card:show
| - | objectArg1.username | variable | True | - |
user-drafts
user-drafts:changed
user-menu
user-menu:notification-click
| - | objectArg1.notification | property | True | - |
| - | objectArg1.href | property | True | - |
user-menu:rendered
user-menu:tab-click
| 1 | tab1.id | property | True | - |
user-reviewable-count
user-reviewable-count:changed
| 1 | count | variable | True | - |
user-status
user-status:changed
other events
AI_RESULTS_TOGGLED
| - | objectArg1.enabled | boolean | True | - |
Detailed List
/plugins/discourse-ai/assets/javascripts/discourse/components/ai-full-page-search.gjs#67
| - | objectArg1.enabled | boolean | - |
/plugins/discourse-ai/assets/javascripts/discourse/components/ai-full-page-search.gjs#156
| - | objectArg1.enabled | undefined | - |
/plugins/discourse-ai/assets/javascripts/discourse/components/ai-full-page-search.gjs#193
click-tracked
| 1 | href | variable | True | - |
desktop-notification-opened
| - | objectArg1.url | property | True | - |
keyboard-visibility-change
| 1 | keyboardVisible | variable | True | - |
push-notification-opened
REFRESH_USER_SIDEBAR_CATEGORIES_SECTION_COUNTS_APP_EVENT_NAME
this.flagCreatedEvent
| 1 | flagModal.args.model.flagModel | property | True | - |
| 2 | postAction | variable | True | - |
| 3 | opts | variable | True | - |
This document is version controlled - suggest changes on github.
