AppEvents Triggers Reference
AppEvents
The AppEvent system in Discourse provides a pub/sub mechanism for handling UI updates and component interactions - and these events are triggered via calls of AppEvent.trigger.
This topic consolidates a list of all such event triggers and their arguments, along with line-of-code references to the Discourse source code.
How to figure out what happens on an event trigger
AppEvent is based on the Ember’s Evented class, and similarly, events are handled by the on method.
Once the specific AppEvent trigger is identified, you may search in the source code for the corresponding .on method with the event name as the first argument.
This method should have an event handler function passed in as the last argument for executing any necessary logic upon trigger of the event.
Taking the composer:open event, we can search for appEvents.on("composer:open". This could lead us to 1 or more places in the code where the event is handled. Each of these would execute a callback function whenever the event is triggered, for example:
    this.appEvents.on("composer:opened", this, this._findMessages);
You would then refer to the definition of the callback function this._findMessages to understand what happens when the composer:opened event is triggered. This callback function can take in arguments passed in from the trigger of the event to be processed within the scope of the function.
List of AppEvent Triggers
ace
ace:resize :link:
No arguments passed to this event.
Detailed List
/frontend/discourse/admin/components/admin-theme-editor.gjs#118 :link:
/plugins/discourse-data-explorer/assets/javascripts/discourse/controllers/admin-plugins/explorer/index.js#119 :link:
/plugins/discourse-data-explorer/assets/javascripts/discourse/controllers/admin-plugins/explorer/queries/details.js#137 :link:
bookmarks
bookmarks:changed :link:
Position Argument Type Always Present Description
1 bookmarkFormData.saveData property True -
2 this.bookmarkModel.attachedTo called_function True -
Detailed List
/frontend/discourse/app/components/bookmark-list.gjs#54 :link:
Position Argument Type Description
1 null null -
2 bookmark1.attachedTo called_function -
/frontend/discourse/app/components/bookmark-list.gjs#85 :link:
1 savedData1 variable -
/frontend/discourse/app/controllers/topic.js#1510 :link:
1 bookmarkFormData.saveData property -
2 bookmark.attachedTo called_function -
/frontend/discourse/app/lib/topic-bookmark-manager.js#57 :link:
2 this.bookmarkModel.attachedTo called_function -
/frontend/discourse/app/models/post.ts#1248 :link:
1 data variable -
2 objectArg2 object -
- objectArg2.target string -
- objectArg2.targetId property -
/frontend/discourse/app/models/post.ts#1268 :link:
1 null null -
/frontend/discourse/app/models/topic.ts#1289 :link:
1 null null -
/plugins/chat/assets/javascripts/discourse/lib/chat-message-interactor.js#374 :link:
/plugins/discourse-data-explorer/assets/javascripts/discourse/controllers/group/reports/show.js#121 :link:
calendar
calendar:create-invitee-status :link:
1 objectArg1 object True -
- objectArg1.status variable True -
- objectArg1.postId property True -
calendar:invitee-left-event :link:
- objectArg1.invitee variable True -
calendar:update-invitee-status :link:
card
card:close :link:
card:hide :link:
card:show :link:
1 username variable True -
2 target variable True -
3 event variable True -
chat
chat:message_interaction :link:
1 result1.interaction property True -
chat:modify-selection :link:
1 event variable True -
2 objectArg2 object True -
- objectArg2.type variable True -
- objectArg2.context property True -
chat:open-insert-link-modal :link:
chat:open-url :link:
1 url variable True -
Detailed List
/plugins/chat/assets/javascripts/discourse/routes/chat.js#66 :link:
1 url variable -
/plugins/chat/assets/javascripts/discourse/routes/chat.js#71 :link:
1 url variable -
chat:refresh-channel-members :link:
chat:rerender-header :link:
chat:toggle-close :link:
1 event variable False -
Detailed List
/plugins/chat/assets/javascripts/discourse/initializers/chat-keyboard-shortcuts.js#117 :link:
1 event variable -
/plugins/chat/assets/javascripts/discourse/routes/chat.js#76 :link:
chat:toggle-expand :link:
1 this.chatStateManager.isDrawerExpanded property True -
Detailed List
/plugins/chat/assets/javascripts/discourse/components/chat-drawer.gjs#163 :link:
1 this.chatStateManager.isDrawerExpanded property -
/plugins/chat/assets/javascripts/discourse/services/chat.js#437 :link:
composer
composer:add-files :link:
1 undefined undefined True -
- objectArg2.skipPlaceholder boolean True -
composer:cancel-upload :link:
composer:cancelled :link:
Detailed List
/frontend/discourse/app/services/composer.js#1654 :link:
/frontend/discourse/app/services/composer.js#1669 :link:
/frontend/discourse/app/services/composer.js#1686 :link:
composer:created-post :link:
composer:div-resizing :link:
composer:edited-post :link:
composer:find-similar :link:
composer:insert-block :link:
1 template.content property True -
Detailed List
/frontend/discourse/app/controllers/topic.js#535 :link:
1 quotedText variable -
/frontend/discourse/app/controllers/topic.js#777 :link:
1 quotedText.trim called_function -
/frontend/discourse/app/lib/lightbox/quote-image.js#89 :link:
1 quote variable -
/plugins/discourse-templates/assets/javascripts/discourse/services/d-templates.js#103 :link:
1 template.content property -
composer:insert-text :link:
1 document.activeElement.href property True -
- objectArg2.ensureSpace boolean True -
composer:open :link:
- objectArg1.model property True -
composer:opened :link:
composer:preview-toggled :link:
1 this.isPreviewVisible property True -
composer:replace-text :link:
1 match variable True -
2 replacement variable True -
composer:reply-reloaded :link:
1 this this True -
Detailed List
/frontend/discourse/app/models/composer.js#1011 :link:
1 this this -
/frontend/discourse/app/models/composer.js#1030 :link:
1 this this -
composer:resize-ended :link:
composer:resize-started :link:
composer:resized :link:
Detailed List
/frontend/discourse/app/components/composer-body.js#73 :link:
/frontend/discourse/app/components/composer-container.gjs#296 :link:
composer:saved :link:
composer:show-preview :link:
composer:toolbar-popup-menu-button-clicked :link:
1 menuItem variable True -
composer:typed-reply :link:
this.composerEventPrefix:all-uploads-complete :link:
this.composerEventPrefix:apply-surround :link:
1 [grid] string True -
2 [/grid] string True -
3 grid_surround string True -
4 objectArg4 object True -
- objectArg4.useBlockMode boolean True -
this.composerEventPrefix:closed :link:
this.composerEventPrefix:replace-text :link:
1 matchingPlaceholder1.index1 property True -
2 replacement1 variable True -
3 objectArg3 object False -
- objectArg3.regex variable False -
- objectArg3.index variable False -
Detailed List
/frontend/discourse/app/components/composer-editor.gjs#511 :link:
1 matchingPlaceholder1.index1 property -
2 replacement1 variable -
3 objectArg3 object -
- objectArg3.regex variable -
- objectArg3.index variable -
/frontend/discourse/app/components/composer-editor.gjs#537 :link:
1 match1 variable -
/frontend/discourse/app/components/composer-editor.gjs#597 :link:
2 string string -
this.composerEventPrefix:upload-cancelled :link:
1 file.id property True -
this.composerEventPrefix:upload-error :link:
1 file variable True -
this.composerEventPrefix:upload-started :link:
1 file.name property True -
this.composerEventPrefix:upload-success :link:
2 upload variable True -
this.composerEventPrefix:uploads-aborted :link:
Detailed List
/frontend/discourse/app/lib/uppy/composer-upload.js#132 :link:
/frontend/discourse/app/lib/uppy/composer-upload.js#181 :link:
this.composerEventPrefix:uploads-cancelled :link:
this.composerEventPrefix:uploads-preprocessing-complete :link:
this.composerEventPrefix:will-close :link:
this.composerEventPrefix:will-open :link:
composer-messages
composer-messages:close :link:
Detailed List
/frontend/discourse/app/services/composer.js#918 :link:
/plugins/discourse-templates/assets/javascripts/discourse/services/d-templates.js#70 :link:
composer-messages:create :link:
- objectArg1.extraClass string True -
- objectArg1.templateName string True -
- objectArg1.body called_function True -
Detailed List
/frontend/discourse/app/services/composer.js#794 :link:
1 objectArg1 object -
- objectArg1.extraClass string -
- objectArg1.templateName string -
- objectArg1.body called_function -
/frontend/discourse/app/services/composer.js#804 :link:
/frontend/discourse/app/services/composer.js#969 :link:
- objectArg1.body variable -
/frontend/discourse/app/services/composer.js#993 :link:
/frontend/discourse/app/services/composer.js#1002 :link:
/frontend/discourse/app/static/prosemirror/extensions/mention.js#251 :link:
composer-service
composer-service:last-validated-at-cleared :link:
composer-service:last-validated-at-updated :link:
- objectArg1.model variable True -
Detailed List
/frontend/discourse/app/services/composer.js#1073 :link:
- objectArg1.model variable -
/frontend/discourse/app/services/composer.js#1282 :link:
- objectArg1.model property -
count-updated
count-updated:user.username_lower:key :link:
1 value variable True -
cta
cta:shown :link:
d-editor
d-editor:preview-click-group-card :link:
1 event1.target property True -
2 event1 variable True -
d-editor:preview-click-user-card :link:
destroyed-custom-html
destroyed-custom-html:this.name :link:
discourse
discourse:focus-changed :link:
1 session.hasFocus property True -
discourse-ai
discourse-ai:bot-header-icon-clicked :link:
discourse-ai:bot-pm-created :link:
- objectArg1.id property True -
- objectArg1.slug property True -
- objectArg1.title variable True -
discourse-ai:force-conversations-sidebar :link:
discourse-ai:new-conversation-btn-clicked :link:
discourse-ai:stop-forcing-conversations-sidebar :link:
discourse-reactions
discourse-reactions:reaction-toggled :link:
- objectArg1.post variable True -
- objectArg1.reaction property True -
discourse-solved
discourse-solved:solution-toggled :link:
1 post1 variable True -
Detailed List
/plugins/discourse-solved/assets/javascripts/discourse/components/solved-accept-answer-button.gjs#28 :link:
1 post1 variable -
/plugins/discourse-solved/assets/javascripts/discourse/components/solved-unaccept-answer-button.gjs#28 :link:
1 post1 variable -
discourse-templates
discourse-templates:show :link:
- objectArg1.onInsertTemplate variable True -
do-not-disturb
do-not-disturb:changed :link:
1 this.do_not_disturb_until property True -
dom
dom:clean :link:
draft
draft:destroyed :link:
1 key variable True -
emoji-picker
emoji-picker:close :link:
flag
flag:created :link:
- objectArg1.message property True -
full-page-search
full-page-search:trigger-search :link:
group
group:join :link:
1 group1 variable True -
group:leave :link:
1 model1 variable True -
header
header:hide-topic :link:
header:keyboard-trigger :link:
- objectArg1.type string True -
- objectArg1.event variable False -
Detailed List
/frontend/discourse/app/services/keyboard-shortcuts.js#531 :link:
- objectArg1.type string -
- objectArg1.event variable -
/frontend/discourse/app/services/keyboard-shortcuts.js#540 :link:
/frontend/discourse/app/services/keyboard-shortcuts.js#547 :link:
/frontend/discourse/app/services/search.js#68 :link:
header:show-topic :link:
1 topic1 variable True -
header:update-topic :link:
1 composer.topic property True -
Detailed List
/frontend/discourse/app/controllers/topic.js#1843 :link:
1 topic variable -
/frontend/discourse/app/instance-initializers/subscribe-user-notifications.js#168 :link:
1 null null -
2 5000 integer -
/frontend/discourse/app/routes/topic.js#428 :link:
1 model variable -
/frontend/discourse/app/services/composer.js#1203 :link:
1 composer.topic property -
/plugins/discourse-assign/assets/javascripts/discourse/initializers/extend-for-assigns.js#502 :link:
1 topic variable -
inserted-custom-html
inserted-custom-html:this.name :link:
interface-color
interface-color:changed :link:
1 LIGHT_VALUE_FOR_COOKIE variable True -
Detailed List
/frontend/discourse/app/services/interface-color.js#95 :link:
1 LIGHT_VALUE_FOR_COOKIE variable -
/frontend/discourse/app/services/interface-color.js#113 :link:
1 DARK_VALUE_FOR_COOKIE variable -
/frontend/discourse/app/services/interface-color.js#127 :link:
/frontend/discourse/app/services/interface-color.js#136 :link:
keyboard
keyboard:move-selection :link:
- objectArg1.articles variable True -
- objectArg1.selectedArticle variable True -
notifications
notifications:changed :link:
Detailed List
/frontend/discourse/app/instance-initializers/subscribe-user-notifications.js#160 :link:
/plugins/chat/assets/javascripts/discourse/services/chat-tracking-state-manager.js#110 :link:
page
page:changed :link:
- objectArg1.url variable True -
- objectArg1.title called_function False -
- objectArg1.currentRouteName property False -
- objectArg1.replacedOnlyQueryParams variable False -
Detailed List
/frontend/discourse/app/lib/page-tracker.js#42 :link:
- objectArg1.url variable -
- objectArg1.title called_function -
- objectArg1.currentRouteName property -
- objectArg1.replacedOnlyQueryParams variable -
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#37 :link:
- objectArg1.url string -
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#53 :link:
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#93 :link:
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#124 :link:
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#141 :link:
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#153 :link:
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#172 :link:
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#201 :link:
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#218 :link:
/plugins/discourse-events/test/javascripts/integration/components/upcoming-events-list-test.gjs#239 :link:
page:compose-reply :link:
1 topic variable True -
page:like-toggled :link:
2 likeAction1 variable True -
page:topic-loaded :link:
policy
policy:changed :link:
- objectArg1.controller variable True -
- objectArg1.message variable True -
poll
poll:voted :link:
1 poll1 variable True -
2 this.post property True -
3 this.vote property True -
Detailed List
/plugins/poll/assets/javascripts/discourse/components/poll.gjs#190 :link:
1 poll1 variable -
2 this.post property -
3 this.vote property -
/plugins/poll/assets/javascripts/discourse/components/poll.gjs#448 :link:
1 poll1 variable -
post
post:created :link:
1 createdPost variable True -
post:highlight :link:
1 result.payload.post_number property True -
2 options variable False -
Detailed List
/frontend/discourse/app/lib/url.js#366 :link:
1 closest variable -
/frontend/discourse/app/routes/topic/from-params.js#99 :link:
/frontend/discourse/app/services/composer.js#1211 :link:
1 result.payload.post_number property -
2 options variable -
post:show-revision :link:
1 copy.postNumber property True -
2 copy.revisionNumber property True -
post-stream
post-stream:filter-replies :link:
- objectArg1.topic_id property True -
- objectArg1.post_number variable True -
- objectArg1.post_id variable True -
post-stream:filter-show-all :link:
1 this.args.streamFilters property True -
post-stream:filter-upwards :link:
post-stream:gap-expanded :link:
- objectArg1.post_id property True -
quote-button
quote-button:edit :link:
quote-button:quote :link:
reviewablenote
reviewablenote:created :link:
1 data1 variable True -
2 this.args.reviewable property True -
3 this.formApi property True -
search
search:search_result_view :link:
- objectArg1.page property True -
search-menu
search-menu:search_menu_opened :link:
sidebar-hamburger-dropdown
sidebar-hamburger-dropdown:rendered :link:
site-header
site-header:force-refresh :link:
this.eventPrefix
this.eventPrefix:insert-text :link:
1 markdown variable True -
Detailed List
/frontend/discourse/app/lib/textarea-text-manipulation.js#447 :link:
1 table variable -
/frontend/discourse/app/lib/textarea-text-manipulation.js#501 :link:
1 markdown variable -
topic
topic:created :link:
2 this this True -
topic:current-post-changed :link:
topic:current-post-scrolled :link:
- objectArg1.postIndex property True -
- objectArg1.percent called_function True -
topic:jump-to-post :link:
1 this.get called_function True -
Detailed List
/frontend/discourse/app/controllers/topic.js#1085 :link:
1 this.get called_function -
/frontend/discourse/app/controllers/topic.js#1478 :link:
1 postId variable -
topic:keyboard-trigger :link:
topic:scrolled :link:
1 offset variable True -
topic:timings-sent :link:
1 data variable True -
topic-entrance
topic-entrance:show :link:
- objectArg1.topic variable True -
- objectArg1.position called_function True -
Detailed List
/frontend/discourse/app/components/basic-topic-list.gjs#89 :link:
- objectArg1.topic variable -
- objectArg1.position called_function -
/frontend/discourse/app/components/featured-topic.gjs#14 :link:
- objectArg1.topic property -
/frontend/discourse/app/components/mobile-category-topic.gjs#19 :link:
topic-header
topic-header:trigger-this.args.type-card :link:
1 this.args.username property True -
2 e1.target property True -
3 e1 variable True -
upload-mixin
upload-mixin:this.config.id:all-uploads-complete :link:
upload-mixin:this.config.id:in-progress-uploads :link:
1 this.inProgressUploads property True -
upload-mixin:this.config.id:upload-cancelled :link:
upload-mixin:this.config.id:upload-success :link:
2 completeResponse variable True -
Detailed List
/frontend/discourse/app/lib/uppy/uppy-upload.js#252 :link:
1 file.name property -
2 completeResponse variable -
/frontend/discourse/app/lib/uppy/uppy-upload.js#273 :link:
2 upload variable -
upload-mixin:this.config.id:uploads-cancelled :link:
user-card
user-card:after-show :link:
- objectArg1.user variable True -
user-card:show :link:
- objectArg1.username variable True -
user-drafts
user-drafts:changed :link:
user-menu
user-menu:notification-click :link:
- objectArg1.notification property True -
- objectArg1.href property True -
user-menu:rendered :link:
user-menu:tab-click :link:
1 tab1.id property True -
user-reviewable-count
user-reviewable-count:changed :link:
1 count variable True -
user-status
user-status:changed :link:
other events
AI_RESULTS_TOGGLED :link:
- objectArg1.enabled boolean True -
Detailed List
/plugins/discourse-ai/assets/javascripts/discourse/components/ai-full-page-search.gjs#67 :link:
- objectArg1.enabled boolean -
/plugins/discourse-ai/assets/javascripts/discourse/components/ai-full-page-search.gjs#156 :link:
- objectArg1.enabled undefined -
/plugins/discourse-ai/assets/javascripts/discourse/components/ai-full-page-search.gjs#193 :link:
click-tracked :link:
1 href variable True -
desktop-notification-opened :link:
- objectArg1.url property True -
keyboard-visibility-change :link:
1 keyboardVisible variable True -
push-notification-opened :link:
REFRESH_USER_SIDEBAR_CATEGORIES_SECTION_COUNTS_APP_EVENT_NAME :link:
this.flagCreatedEvent :link:
1 flagModal.args.model.flagModel property True -
2 postAction variable True -
3 opts variable True -
This document is version controlled - suggest changes on github.
