Регрессия входа в Google, возможно, после недавних изменений
[image redacted]
I think Google’s not working after the forum update.
3 лайка
I moved this to a new topic @Monikas. To clarify, you noticed this issue after a recent rebuild of the site?
Can you also look under justnainai.com/logs, this kind of user-facing error message usually has an accompanying log entry.
3 лайка
I don’t know what this error means.
I’ve moved my forums in the last week using backups + app.yml overrides and then I switched smtp from Microsoft Mail 360 to Google Mail and then there’s also the panel I used to build it using 1Panel using the “OpenResty Web Platform based on NGINX and LuaJIT” in there and then using reverse proxies. Here’s the source code for the reverse proxy and its configuration file.
error.txt (614.2 KB)
I also used cloudflare and followed the configuration in the forums to set up the
Search results for ‘cloudflare’ - Discourse Meta
The certificate uses the Origin Server in cloudflare
I don’t have any firewalls up.
Website Configuration
server {
    listen 80 ;
    listen 443 ssl http2 ;
    server_name www.justnainai.com;
    index index.php index.html index.htm default.php default.htm default.html;
    proxy_set_header Host $host;
    proxy_set_header X-Forwarded-For $proxy_add_x_forwarded_for;
    proxy_set_header X-Forwarded-Host $server_name;
    proxy_set_header X-Real-IP $remote_addr;
    proxy_http_version 1.1;
    proxy_set_header Upgrade $http_upgrade;
    proxy_set_header Connection $http_connection;
    access_log /www/sites/www.justnainai.com/log/access.log main;
    error_log /www/sites/www.justnainai.com/log/error.log;
    location ^~ /.well-known/acme-challenge {
        allow all;
        root /usr/share/nginx/html;
    include /www/sites/www.justnainai.com/proxy/*.conf;
    if ($scheme = http) {
        return 301 https://$host$request_uri;
    ssl_certificate /www/sites/www.justnainai.com/ssl/fullchain.pem;
    ssl_certificate_key /www/sites/www.justnainai.com/ssl/privkey.pem;
    ssl_protocols TLSv1.3 TLSv1.2;
    ssl_ciphers ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA256:!aNULL:!eNULL:!EXPORT:!DSS:!DES:!RC4:!3DES:!MD5:!PSK:!KRB5:!SRP:!CAMELLIA:!SEED;
    ssl_prefer_server_ciphers on;
    ssl_session_cache shared:SSL:10m;
    ssl_session_timeout 10m;
    error_page 497 https://$host$request_uri;
    proxy_set_header X-Forwarded-Proto https;
    add_header Strict-Transport-Security "max-age=31536000";
Reverse proxy original
location ^~ / {
proxy_pass http://127.0.0.1:50080;
proxy_set_header REMOTE-HOST $remote_addr;
proxy_set_header X-Forwarded-Proto $scheme;
add_header X-Cache $upstream_cache_status;
add_header Cache-Control no-cache;
proxy_ssl_server_name off;
proxy_ssl_name $proxy_host;
add_header Strict-Transport-Security “max-age=31536000”;
(google_oauth2) Authentication failure! access_denied: OmniAuth::Strategies::OAuth2::CallbackError, access_denied
BUG
activesupport-7.2.2/lib/active_support/broadcast_logger.rb:134:in `block in error'
activesupport-7.2.2/lib/active_support/broadcast_logger.rb:231:in `block in dispatch'
activesupport-7.2.2/lib/active_support/broadcast_logger.rb:231:in `each'
activesupport-7.2.2/lib/active_support/broadcast_logger.rb:231:in `dispatch'
activesupport-7.2.2/lib/active_support/broadcast_logger.rb:134:in `error'
omniauth-1.9.2/lib/omniauth/strategy.rb:163:in `log'
omniauth-1.9.2/lib/omniauth/strategy.rb:486:in `fail!'
omniauth-oauth2-1.7.3/lib/omniauth/strategies/oauth2.rb:89:in `callback_phase'
omniauth-1.9.2/lib/omniauth/strategy.rb:238:in `callback_call'
omniauth-1.9.2/lib/omniauth/strategy.rb:189:in `call!'
omniauth-1.9.2/lib/omniauth/strategy.rb:169:in `call'
omniauth-1.9.2/lib/omniauth/builder.rb:45:in `call'
/var/www/discourse/lib/middleware/omniauth_bypass_middleware.rb:43:in `call'
rack-2.2.10/lib/rack/tempfile_reaper.rb:15:in `call'
rack-2.2.10/lib/rack/conditional_get.rb:27:in `call'
rack-2.2.10/lib/rack/head.rb:12:in `call'
actionpack-7.2.2/lib/action_dispatch/http/permissions_policy.rb:38:in `call'
/var/www/discourse/lib/content_security_policy/middleware.rb:12:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:397:in `call'
/var/www/discourse/lib/middleware/csp_script_nonce_injector.rb:12:in `call'
/var/www/discourse/config/initializers/008-rack-cors.rb:14:in `call'
rack-2.2.10/lib/rack/session/abstract/id.rb:266:in `context'
rack-2.2.10/lib/rack/session/abstract/id.rb:260:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/cookies.rb:704:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/callbacks.rb:31:in `block in call'
activesupport-7.2.2/lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack-7.2.2/lib/action_dispatch/middleware/callbacks.rb:30:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/debug_exceptions.rb:31:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/show_exceptions.rb:32:in `call'
logster-2.20.0/lib/logster/middleware/reporter.rb:40:in `call'
railties-7.2.2/lib/rails/rack/logger.rb:41:in `call_app'
railties-7.2.2/lib/rails/rack/logger.rb:29:in `call'
/var/www/discourse/config/initializers/100-quiet_logger.rb:20:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:29:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/request_id.rb:33:in `call'
/var/www/discourse/lib/middleware/enforce_hostname.rb:24:in `call'
rack-2.2.10/lib/rack/method_override.rb:24:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/executor.rb:16:in `call'
rack-2.2.10/lib/rack/sendfile.rb:110:in `call'
rack-mini-profiler-3.3.1/lib/mini_profiler.rb:191:in `call'
/var/www/discourse/lib/middleware/processing_request.rb:12:in `call'
message_bus-4.3.8/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:360:in `call'
actionpack-7.2.2/lib/action_dispatch/middleware/remote_ip.rb:96:in `call'
railties-7.2.2/lib/rails/engine.rb:535:in `call'
railties-7.2.2/lib/rails/railtie.rb:226:in `public_send'
railties-7.2.2/lib/rails/railtie.rb:226:in `method_missing'
rack-2.2.10/lib/rack/urlmap.rb:74:in `block in call'
rack-2.2.10/lib/rack/urlmap.rb:58:in `each'
rack-2.2.10/lib/rack/urlmap.rb:58:in `call'
unicorn-6.1.0/lib/unicorn/http_server.rb:634:in `process_client'
unicorn-6.1.0/lib/unicorn/http_server.rb:739:in `worker_loop'
unicorn-6.1.0/lib/unicorn/http_server.rb:547:in `spawn_missing_workers'
unicorn-6.1.0/lib/unicorn/http_server.rb:143:in `start'
unicorn-6.1.0/bin/unicorn:128:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `load'
/var/www/discourse/vendor/bundle/ruby/3.3.0/bin/unicorn:25:in `<main>'
(microsoft_office365) Authentication failure! access_denied: OmniAuth::Strategies::OAuth2::CallbackError, access_denied | The user has denied access to the scope requested by the client application.
BUG2
omniauth-1.9.2/lib/omniauth/strategy.rb:192:in `call!'
app.yml
templates:
  - "templates/cloudflare.template.yml"
expose:
  - "50080:80"
  - "50443:443"
params:
  #db_shared_buffers: "256MB"
  #db_work_mem: "40MB"
  #version: tests-passed
env:
  LC_ALL: en_US.UTF-8
  LANG: en_US.UTF-8
  LANGUAGE: en_US.UTF-8
  #UNICORN_WORKERS: 3
  DISCOURSE_HOSTNAME: 'www.justnainai.com'
  DISCOURSE_DEVELOPER_EMAILS: ''
  DISCOURSE_MAX_REQS_PER_IP_PER_10_SECONDS: 400
  DISCOURSE_MAX_ASSET_REQS_PER_IP_PER_10_SECONDS: 800
  DISCOURSE_SMTP_ADDRESS: smtp.gmail.com
  DISCOURSE_SMTP_PORT: 587
  DISCOURSE_SMTP_USER_NAME: ''
  DISCOURSE_SMTP_PASSWORD: ''
  DISCOURSE_SMTP_ENABLE_START_TLS: true
  DISCOURSE_SMTP_AUTHENTICATION: login
volumes:
  - volume:
      guest: /shared
  - volume:
      guest: /var/log
OAuth2::ConnectionError (FinalDestination: all resolved IPs were disallowed)
And I recently started this error on the forums and 4797 of them are not showing up in the logs at once.
Just tested on my local computer.
Didn’t see google login have issue.
1 лайк
This indicates a networking issue on your new host, I suspect the problems started happening when you moved. Something in your stack is blocking requests to the auth servers… unfortunately, I can’t help any further, but I tested on a site we host, and Google auth works correctly.
3 лайка
