API при создании пользователя больше не возвращает user_id
I have a script that runs daily to create new users via the API. Up until a few days ago, when the post would complete, the response included the user_id of the newly created user. Now the API no longer does so? But the API docs indicate that it should.
https://docs.discourse.org/#tag/Users/operation/createUser
4 лайка
Is the user being created?
My guess is that for some reason the user isn’t being created and that’s why it’s not returning the user_id.
The users are getting created. I have confirmed. And the API gives back this status but it’s missing the user_id
    "success": true,
    "active": true,
    "message": "Your account is activated and ready to use."
2 лайка
Yeah. That seems like a bug, then. I looked for explanations in Commits · discourse/discourse · GitHub but didn’t find one.
To confirm the issue, I created a user through the API on 3.4.0.beta3-dev and it returned user_id in the response.
	"success": true,
	"active": true,
	"message": "Your account is activated and ready to use.",
	"user_id": 3
I did it again after upgrading to 3.4.0.beta4-dev and user_id is then missing:
	"success": true,
	"active": true,
2 лайка
So you’ve narrowed down where the errant commit is.
1 лайк
Just a hunch
probably related to DEV: Change hide_email_address_taken default to true (#30293) · discourse/discourse@c1c7ea8 · GitHub explained here:
I guess it would be desirable to override this behavior when it’s a request made using an admin API key?
6 лайков
Thank you! Changing that setting did restore the API result so that I get the user_id in the result after creating a user.
3 лайка
Hello,
Same here…
Is it something currently ongoing for the devs? Because it may be tricky to remember that this settings counteract the docs :stuck_out_tongue:
