Вход в аккаунт с использованием публичного ключа
Discourse Login No username, no email, no password.
Public keys do not require a password.
Since 2FA must be maintained on both the app and the website, it can prevent bot registration and avoid forgetting the public key.
Sign Up —> Generate Public key —> Bind 2FA TOTP
2FA is your password, 2FA as the first factor.
Login using public key+2FA.
Generate Public key
k41d9dfe789b8881c165e50f035aad1f286f88f2b33d97d10c198a4df37ae16f756f8a6b3520f2899eb19c321ef357e3fccaf6af627527c10b7cce9af7be4dc9
What do I need
I have registered more than 10 Discourse forums on Win10 browser and Android, such as F-droid, etc.
But I have forgotten my username and password, and my mail has been banned by the mail provider.
What benefit would this provide over the Passkey standard?
1 лайк
Passkey No one uses it, it is not conducive to backup and recovery,
Passkey is not universal, and is overly dependent on the browser.
Everyone I know uses it.
Wait… what :flushed:
What am I missing this time?
1 лайк
Passkey You must have an email to log in to enable it.
If I don’t forget my password, and my email has been banned by the operator. How can I log in!
Public key + 2FA can solve this problem very well. You must bind 2FA during the registration process.
Public key is the username
You’ll need to get a good handle on terminology and a clear design to propose anything concrete.
For instance, by “2FA” you probably mean “TOTP”?
And “username is public key” leaves a ton to be interpreted.
In the meanwhile, you could POC your proposed scheme by implementing it as a DiscourseConnect (or SAML or oAuth…) provider.
Also, in what scenario does this proposal make things better for the end user?
1 лайк
No, it is not.
But the real issue is that:
Don’t use spam-accounts. That is the real reason. But in situation like that you should try to connect the admin and explain that. Or create new account and try to get those connected.
2 лайка
Just throwing my 2 cents in here, I use passkeys:
All major browsers support passkeys AFAIK?
2 лайка
