Locked out of a Discourse forum due to passkey bug?
I’m a member of https://www.trucknetuk.com/ which uses Discourse 3.5.0.beta3-dev.
I opted in to use my Thetis Pro passkey device, which worked fine until I had to re-install Windows. I’m now getting “This security key doesn’t look familiar”. I found that if I took the key before attempting login, then re-inserted when prompted, I got the following:
“An error occurred: A security key with the provided credential ID could not be found”.
I can see that the key for the site exists in Thetis Pro Key Manager app.
Note: I’ve tried it via Chrome, Firefox, mobile etc, as well as my laptop, with the same resulting message. And all other keys on the device work fine for other sites.
I tried contacting the site owner who just told me to do a password reset - not sure he understands passkeys! Yes, I can do a password reset, but it still needs passkeys to complete.
I also created a new account and a thread at Locked out as Passkeys seems broke and no backup / recovery options offered - FEEDBACK FORUM - Let Us Know! (INTERACTIVE) - Trucknet UK - but not much help there.
So, is there anything else I can do, or ask the forum admin to try, or somehow initiate a fallback? I don’t recall any way of creating a backup passkey using Windows Hello or Google Password Manager, which is what I normally do. Nor is there any other option that a physical key when clicking “cancel”.
Any ideas?! Thanks.
Hey, welcome to meta
I can’t help with why it happens. It’s interesting that it only happens with Discourse.
Have you tried authenticating with a login link? You don’t need a passkey to complete the process.
Thanks for getting back to me. Sorry, forgot to mention I tried this before.
I click the link in the email ( www.trucknetuk.com/session/email-login/XXXXXX), but I’m right back to this screen:
If I choose “Authenticate with security key” I get the “doesn’t look familiar” error. If I choose “try another way”, I get a page saying:
When you have your physical security key or compatible mobile device prepared press the Authenticate with Security Key button below.
However, there’s no such box shown, just a textarea to paste something in.
[EDIT] - sorry, due to the “only one image per post for new users” error, I’ll have to split this into another reply…
I took a guess and tried pasting both “user ID” and “credential ID” into the box, but in both cases it says:
The provided public key is invalid.
Just to prove I definitely have a valid key for the site, here’s the credential itself on the key:
This is getting intriguing!
(again, sorry for 3 replies, but it was due to “one per post” limit)
Hey @digitaltoast welcome! Just responding here that we’ve seen your issue and are discussing…
There are two types of security keys in Discourse: first factor (aka passkeys) and second factor. The passkey can be used to log in from the main login screen, before you have entered a password. The second factor key can only be used after entering a password, that’s why it is called a second factor, because it’s after a first authentication step.
I can see that in your account you have a second factor key, that’s why you are getting the “Authenticate with Security Key” prompt. I also see that you have a passkey too, from Windows. Can you try logging in with that? Do you still have that after resetting Windows?
If that doesn’t work, you can ask the administrator at TruckNet to reset the hugh_lorry account’s security keys. The admin would need to agree that you’re the rightful owner of the account. If they do and remove the key, then you can log in via email without a 2FA because there won’t be one anymore on that account.
OK, to clarify:
I can see the passkey right on the Thetis Pro physical USB passkey device, so I know I used that, not Windows Hello.
If I use the key, I get
"An error occurred: A security key with the provided credential ID could not be found."
Unlike other sites, there’s no option to choose anything other than a physical security key. Normally, when it says "insert your security key", if “cancel” is pressed then other options are offered, such as being able to use “Windows Hello” passkeys. But if I press cancel, it says:
"The security key authentication process either timed out or was cancelled."
The only way to get the 2FA screen is “login with email link” and then choose “two factor authentication”.
It then gives a rather confusing screen which says:
"When you have your physical security key or compatible mobile device prepared press the Authenticate with Security Key button below."
But there is no “Security Key button”, but a space to enter something, (<p class="second-factor__description">) and a “finish login” button below it.
I’m assuming that this is for a 6-digit 2FA from a code generator, but the only one I use is Authy, and it’s not in there. Whatever I put, the message is "The provided public key is invalid", which perhaps suggests an error on the hosted site rather than my end?
I went back as my temporary account and tried setting up passkeys and 2FA again, and I noticed that there are options to download backup codes, which I definitely would have done as I always do that for other sites. And I always note them in two places, and they’re not in either. I would have enabled 2FA around February 2024 when they switched from their old forums to Discourse - is it possible that option wasn’t on that page at that time?
That’s interesting - does that mean that you are actually able to see my account and credentials on the Trucknet site?
OK, understood. I’ll do that as a last resort, but if possible I’d like to try and work through this and help fix anything that may be a bug, or an edge case that might “get” someone else in the future, rather than working around it at this stage.
Thanks again!
EDIT: Just to add, if I try via my Pixel 6a mobile, using the same key via NFC, I get the error:
NotReadableError: An unknown error occurred while talking to the credential manager.
I can confirm that using this key via NFC works OK on other sites (Google, https://www.passkeys.io/ etc).
Any chance you can post a screenshot of this screen? From what I can tell, your account is in an unusual state. It feels like one part of the app has a record of the 2FA key, but not the other part. A bit hard to explain, but on the Discourse side there are two concepts: security keys and second factor methods (one of which is security keys, the others are TOTP and backup codes).
IIRC, yes, there was a short window where the UI for backup codes was not encouraging enough to users, in other words, I believe for a short period of time, the backup code generation was somewhat hidden.
