Zwei verfolgte Variablen aktualisieren sich nicht
Ich habe den folgenden Code:
import Component from "@glimmer/component";
import { tracked } from '@glimmer/tracking';
import { action } from '@ember/object';
import { inject as service } from "@ember/service";
import { defaultHomepage } from "discourse/lib/utilities";
const xhr = new XMLHttpRequest();
xhr.open("GET", "/cakeday/anniversaries/today.json");
xhr.send();
xhr.responseType = "json";
xhr.onload = () => {
    if (xhr.readyState == 4 && xhr.status == 200) {
        let resp = xhr.response;
        let numberOfAnns = resp['total_rows_anniversaries'];
        let allAnns = resp['anniversaries']; // Is a list of dicts
        console.log(allAnns);
        let allAnnsUsernames = [];
        for (var annUserdata in allAnns) {
            console.log(allAnns[annUserdata]['username']);
            allAnnsUsernames.push(allAnns[annUserdata]['username']);
        var annsOfData = {'num_anns': numberOfAnns, 'anns_users': allAnnsUsernames};
return annsOfData;
export default apiInitializer("1.14.0", (api) => {
    //const banner_location = settings.banner_location
    api.renderInOutlet(
        settings.banner_location,
        class BdaysAnnsBanner extends Component {
            @tracked annsDataFinal = null;
            @tracked bdaysDataFinal = null;
            @tracked areBothBannersVisible = true;
            @tracked isAnnsVisible = null;
            @tracked isBdaysVisible = null;
            @service router;
            constructor() {
                super(...arguments);
                this.fetchAnnsData(); // Automatically fetch on initialization
                this.fetchBdaysData();
            // Asynchronously fetch the data and update tracked property
            @action
            async fetchAnnsData() {
                const response = await fetch("/cakeday/anniversaries/today.json");
                const json = await response.json();
                let numberOfAnns = parseInt(json['total_rows_anniversaries']);
                let allAnns = json['anniversaries']; // Is a list of dicts
                for (let annUserdata of allAnns) {
                    allAnnsUsernames.push(annUserdata['username']);
                this.annsDataFinal = {'num_anns': numberOfAnns, 'anns_users': allAnnsUsernames, 'visible': true, 'isFilled': true};
                this.updateBothBannersVisibility(this.annsDataFinal);
            @action
            async fetchBdaysData() {
                 // Declare bdaysDataFinal here
                let bdaysDataFinal;
                // Fetch birthdays data
                const response = await fetch("/cakeday/birthdays/today.json");
                // Run the logic to process the data
                let numberOfBdays = parseInt(json['total_rows_birthdays']);
                let allBdays = json['birthdays']; // Is a list of dicts
                let allBdaysUsernames = [];
                for (let bdayUserdata of allBdays) {
                    allBdaysUsernames.push(bdayUserdata['username']);
                this.bdaysDataFinal = {'num_bdays': numberOfBdays, 'bdays_users': allBdaysUsernames, 'visible': true, 'isFilled': true};
                this.updateBothBannersVisibility(this.bdaysDataFinal);
                //console.log(annsDataFinal);  // Just to verify the result
            @action
            updateBothBannersVisibility(bannerData) {
                console.log(bannerData.num_anns);
                // Check if it's anns or bdays
                if (bannerData.num_anns) { // It's anns
                    console.log('Anns:')
                    if (bannerData.num_anns == 0 && settings.hide_unused_data) {
                        console.log(`Anns+setting: ${bannerData.num_anns == 0 && settings.hide_unused_data}`);
                        this.isAnnsVisible = false;
                        console.log(`isAnnsV: ${this.isAnnsVisible}`);
                        //console.log(this.isBdaysVisible);
                } else { // It's bdays
                    console.log(bannerData.num_bdays);
                    if (bannerData.num_bdays == 0 && settings.hide_unused_data) {
                        console.log(`Bdays+setting: ${bannerData.num_bdays == 0 && settings.hide_unused_data}`);
                        this.isBdaysVisible = false;
                        console.log(`isBdaysV: ${this.isBdaysVisible}`);
                        //console.log(this.isAnnsVisible);
                // Uses an inequality. If not the same (true), banner is shown. If it is the same, inequality is not satisfied, and the banner will be hidden.
                this.areBothBannersVisible = !(this.isAnnsVisible === false && this.isBdaysVisible === false); // Or: this.areBothBannersVisible = this.isAnnsVisible || this.isBdaysVisible;
                console.log(this.areBothBannersVisible);
            // Getter for the data
            get annsData() {
                //return this.annsDataFinal;
                if (this.annsDataFinal !== null) {
                    if (this.annsDataFinal.num_anns == 0) {
                        if (settings.hide_unused_data) {
                            this.annsDataFinal.isFilled = false;
                            this.annsDataFinal.visible = false;
                        } else {
                    } else {
                        this.annsDataFinal.isFilled = true;
                        this.annsDataFinal.visible = true;
                    //this.updateBothBannersVisibility(this.annsDataFinal);
                    // If the data is not loaded yet, return null or any default value
            get bdaysData() {
                //return this.bdaysDataFinal;
                if (this.bdaysDataFinal !== null) {
                    if (this.bdaysDataFinal.num_bdays == 0) {
                            this.bdaysDataFinal.isFilled = false;
                            this.bdaysDataFinal.visible = false;
                        } else {
                            this.bdaysDataFinal.visible = true;
                    } else {
                        this.bdaysDataFinal.isFilled = true;
                    //this.updateBothBannersVisibility(this.bdaysDataFinal);
            get isHomepage() {
                const { currentRouteName } = this.router;
                return currentRouteName === `discovery.${defaultHomepage()}`;
            //console.log(this.areBothBannersVisible);
            <template>
                {{#if this.areBothBannersVisible}}
                    {{#if this.isHomepage}}
                        <div class='bdaysannsbanner' id='bdaysannsbanner'>
                            {{#if this.annsData.visible}}
                                <div class='anns'>
                                    {{#if this.annsData.isFilled}}
                                        <p>{{this.annsData.num_anns}} users are celebrating their anniversary!</p>
                                        <!-- Display the anniversaries data -->
                                        {{#each this.annsData.anns_users as |username|}}
                                            <span><a class='mention'>{{username}}</a></span>
                                        {{/each}}
                                    {{else}}
                                        <p>No one has their anniversary today!</p>
                                    {{/if}}
                                </div>
                            {{/if}}
                            <br />
                            {{#if this.bdaysData.visible}}
                                <div class='bdays'>
                                    {{#if this.bdaysData.isFilled}}
                                        <p>{{this.bdaysData.num_bdays}} users are celebrating their birthday!</p>
                                        <!-- Display the birthday data -->
                                        {{#each this.bdaysData.bdays_users as |username|}}
                                        {{/each}}
                                    {{else}}
                                        <p>No one is celebrating their birthday today!</p>
                                    {{/if}}
                                </div>
                            {{/if}}
                        </div>
                    {{/if}}
                {{/if}}
            </template>
Die nicht funktionierenden Teile sind die Variablen this.isAnnsVisible und this.isBdaysVisible. Sie scheinen sich nicht zu aktualisieren, was dazu führt, dass das Banner angezeigt wird.
Es ist seltsam, dass diese Variablen nicht aktualisiert werden. Könnte es sein, dass sie nicht richtig verwendet werden?
Es tut mir leid, dass ich das hochhole, aber ich habe immer noch keine Ahnung, warum das passiert.
Mein Code jetzt:
import { ajax } from "discourse/lib/ajax";
import { getOwner } from '@ember/application';
    api.renderInOutlet(
            @service router;
            constructor() {
            @action
                console.log(json);
            @action
                let bdaysDataFinal;
            @action
            get annsData() {
                        } else {
                    } else {
            get bdaysData() {
                            console.log(`this.isAnnsVisible: ${this.isAnnsVisible}`);
                            console.log(`this.isBdaysVisible: ${this.isBdaysVisible}`);
                        } else {
                    } else {
            get isHomepage() {
            <template>
                                <div class='anns'>
                                        <p>{{this.annsData.num_anns}} Benutzer feiern ihr Jubiläum!</p>
                                        {{/each}}
                                    {{else}}
                                        <p>Niemand hat heute sein Jubiläum!</p>
                                    {{/if}}
                                </div>
                            {{/if}}
                            <br />
                                <div class='bdays'>
                                        <p>{{this.bdaysData.num_bdays}} Benutzer feiern Geburtstag!</p>
                                        {{/each}}
                                    {{else}}
                                        <p>Niemand feiert heute Geburtstag!</p>
                                    {{/if}}
                                </div>
                            {{/if}}
                        </div>
                    {{/if}}
                {{/if}}
            </template>
Mein Repo:
Ich bin mir noch nicht ganz sicher, aber …
dieses await ist unnötig.
Die Antwort sollte bereits ein Objekt sein, daher bin ich mir nicht sicher, warum Sie .json() usw. benötigen? Sie können dies wahrscheinlich stark vereinfachen.
Sie müssen dies nicht übergeben, da die verfolgten Variablen im gesamten Komponentenbereich liegen. Rufen Sie es einfach auf und beziehen Sie sich im Aktionsaufruf darauf.
Einige Stil-Tipps:
  • Überhäufen Sie Ihren gemeinsam genutzten Code nicht mit Konsolenprotokollen. Das erschwert es, den Wald vor lauter Bäumen zu sehen.
  • Verwenden Sie eine Einrückung von zwei Leerzeichen, nicht von 4, was ein Discourse-Standard ist. Sehen Sie sich Ihre Vorlage an.
  • Erwägen Sie, dies in eine dedizierte .gjs-Datei zu verschieben.
  • Sie können auf die Zahlen in GitHub klicken und erhalten einen teilbaren Link, der den Code in der Vorschau anzeigt, wenn Sie ihn benötigen.
Fortgeschritten:
  • Richten Sie Prettier und ESlint ein … Ersteres für den Stil und Letzteres sowohl für den Stil als auch zur Fehlererkennung.
Das ist es nicht, oder?
Sie müssen nicht so weit gehen, aber das ist eine Option.
Es reicht, wenn Sie es zunächst manuell tun.
So etwas funktioniert wahrscheinlich nicht.
Ich glaube nicht, dass EmberJS verschachtelte Eigenschaften beobachtet.
Sie sollten Eigenschaften auf derselben Ebene erstellen, verfolgen und testen.
Erstellen Sie also eine verfolgte Eigenschaft namens annsDataVisible, aktualisieren Sie deren Wert und verwenden Sie diese in Ihrer if-Anweisung.
Sie können das gesamte Objekt auch jedes Mal neu zuweisen, anstatt nur den Wert eines untergeordneten Attributs, was einen Neuanstrich auslösen könnte.
