Another way to track nested data structures
@tracked state of an array or object within a glimmer component does not trigger updates when you change a member of the array/object.
This topic talks about some options to get your view to properly update. I wanted to add another way, as the options talked about there did not work for me.
How I solved this is: Rather than assign one element at a time, assign the whole array at once. This same strategy would work with an object or any other data structure.
In a glimmer component:
@tracked categories = [];
constructor() {
  super(...arguments);
  this.loadAllData();
async loadAllData() {
  const categories = []
  const waiting = this.siteSettings.county_fence_print_categories.split('|').map(async (cid, index) => {
    const data = await this.loadData(`/c/${cid}/l/latest.json?period=monthly`)
    return data.topic_list.topics
  // THIS IS THE LINE TO NOTICE
  // Because we use = directly on the array, it will trigger an update.
  // Whereas pushing to the array or setting elements by index would not trigger an update.
  this.categories = await Promise.all(waiting)
async loadData(url) {
  try {
    const data = await ajax(url);
    //console.log(`Got data for ${url}:`, data)
    return data
  } catch (error) {
    console.error(`Failed to get data for ${url}:`, error);
You could do this with a partial update as well. The important thing is for Javascript to detect that a different value is being assigned. So while .concat will work, because it’s generating a new array distinct from the old one:
this.categories = this.categories.concat(newValue)
Using .push will probably not work, because the resulting array is the same object ID as the original, thus Javascript thinks that nothing has changed.
this.categories.push(newValue)
If you are working with an object, an easy way to generate a new one is with Object.assign() - which creates a new, extended data structure, like .concat above.
This has long been the case for other frameworks such as Vue.js as well - you can find topics about this going back for 10 years. It has to do with the way it’s being implemented in Javascript, probably either getters/setters on the parent object or the observe API. But if it’s implemented with the observe API then there’s a little bit less of an excuse for this behavior, since it would be easy to toggle the subtree flag… Maybe they choose not to do this for performance concerns when watching a deeply nested structure? But I digress, these are implementation details of the underlying libraries. The workaround above should help you navigate this.
I wonder if TrackedArray would help here?
I did not dive more than that. I just remembered that Discourse code uses this here and there.
import { TrackedArray, TrackedObject } from "@ember-compat/tracked-built-ins";
Imagine if this were documented. :laughing:
But yes, that seems designed precisely for this scenario.
