Duídas variáveis rastreadas não atualizando-se
Tenho o seguinte código:
import Component from "@glimmer/component";
import { tracked } from '@glimmer/tracking';
import { action } from '@ember/object';
import { inject as service } from "@ember/service";
import { defaultHomepage } from "discourse/lib/utilities";
const xhr = new XMLHttpRequest();
xhr.open("GET", "/cakeday/anniversaries/today.json");
xhr.send();
xhr.responseType = "json";
xhr.onload = () => {
    if (xhr.readyState == 4 && xhr.status == 200) {
        let resp = xhr.response;
        let numberOfAnns = resp['total_rows_anniversaires'];
        let allAnns = resp['anniversaries']; // Is a list of dicts
        console.log(allAnns);
        let allAnnsUsernames = [];
        for (var annUserdata in allAnns) {
            console.log(allAnns[annUserdata]['username']);
            allAnnsUsernames.push(allAnns[annUserdata]['username']);
        var annsOfData = {'num_anns': numberOfAnns, 'anns_users': allAnnsUsernames};
return annsOfData;
export default apiInitializer("1.14.0", (api) => {
    //const banner_location = settings.banner_location
    api.renderInOutlet(
        settings.banner_location,
        class BdaysAnnsBanner extends Component {
            @tracked annsDataFinal = null;
            @tracked bdaysDataFinal = null;
            @tracked areBothBannersVisible = true;
            @tracked isAnnsVisible = null;
            @tracked isBdaysVisible = null;
            @service router;
            constructor() {
                super(...arguments);
                this.fetchAnnsData(); // Automatically fetch on initialization
                this.fetchBdaysData();
            // Asynchronously fetch the data and update tracked property
            @action
            async fetchAnnsData() {
                const response = await fetch("/cakeday/anniversaries/today.json");
                const json = await response.json();
                let numberOfAnns = parseInt(json['total_rows_anniversaries']);
                let allAnns = json['anniversaries']; // Is a list of dicts
                for (let annUserdata of allAnns) {
                    allAnnsUsernames.push(annUserdata['username']);
                this.annsDataFinal = {'num_anns': numberOfAnns, 'anns_users': allAnnsUsernames, 'visible': true, 'isFilled': true};
                this.updateBothBannersVisibility(this.annsDataFinal);
            @action
            async fetchBdaysData() {
                 // Declare bdaysDataFinal here
                let bdaysDataFinal;
                // Fetch birthdays data
                const response = await fetch("/cakeday/birthdays/today.json");
                // Run the logic to process the data
                let numberOfBdays = parseInt(json['total_rows_birthdays']);
                let allBdays = json['birthdays']; // Is a list of dicts
                let allBdaysUsernames = [];
                for (let bdayUserdata of allBdays) {
                    allBdaysUsernames.push(bdayUserdata['username']);
                this.bdaysDataFinal = {'num_bdays': numberOfBdays, 'bdays_users': allBdaysUsernames, 'visible': true, 'isFilled': true};
                this.updateBothBannersVisibility(this.bdaysDataFinal);
                //console.log(annsDataFinal);  // Just to verify the result
            @action
            updateBothBannersVisibility(bannerData) {
                console.log(bannerData.num_anns);
                // Check if it's anns or bdays
                if (bannerData.num_anns) { // It's anns
                    console.log('Anns:')
                    if (bannerData.num_anns == 0 && settings.hide_unused_data) {
                        console.log(`Anns+setting: ${bannerData.num_anns == 0 && settings.hide_unused_data}`);
                        this.isAnnsVisible = false;
                        console.log(`isAnnsV: ${this.isAnnsVisible}`);
                        //console.log(this.isBdaysVisible);
                } else { // It's bdays
                    console.log(bannerData.num_bdays);
                    if (bannerData.num_bdays == 0 && settings.hide_unused_data) {
                        console.log(`Bdays+setting: ${bannerData.num_bdays == 0 && settings.hide_unused_data}`);
                        this.isBdaysVisible = false;
                        console.log(`isBdaysV: ${this.isBdaysVisible}`);
                        //console.log(this.isAnnsVisible);
                // Uses an inequality. If not the same (true), banner is shown. If it is the same, inequality is not satisfied, and the banner will be hidden.
                this.areBothBannersVisible = !(this.isAnnsVisible === false && this.isBdaysVisible === false); // Or: this.areBothBannersVisible = this.isAnnsVisible || this.isBdaysVisible;
                console.log(this.areBothBannersVisible);
            // Getter for the data
            get annsData() {
                //return this.annsDataFinal;
                if (this.annsDataFinal !== null) {
                    if (this.annsDataFinal.num_anns == 0) {
                        if (settings.hide_unused_data) {
                            this.annsDataFinal.isFilled = false;
                            this.annsDataFinal.visible = false;
                        } else {
                    } else {
                        this.annsDataFinal.isFilled = true;
                        this.annsDataFinal.visible = true;
                    //this.updateBothBannersVisibility(this.annsDataFinal);
                    // If the data is not loaded yet, return null or any default value
            get bdaysData() {
                //return this.bdaysDataFinal;
                if (this.bdaysDataFinal !== null) {
                    if (this.bdaysDataFinal.num_bdays == 0) {
                            this.bdaysDataFinal.isFilled = false;
                            this.bdaysDataFinal.visible = false;
                        } else {
                            this.bdaysDataFinal.visible = true;
                    } else {
                        this.bdaysDataFinal.isFilled = true;
                    //this.updateBothBannersVisibility(this.bdaysDataFinal);
            get isHomepage() {
                const { currentRouteName } = this.router;
                return currentRouteName === `discovery.${defaultHomepage()}`;
            //console.log(this.areBothBannersVisible);
            <template>
                {{#if this.areBothBannersVisible}}
                    {{#if this.isHomepage}}
                        <div class='bdaysannsbanner' id='bdaysannsbanner'>
                            {{#if this.annsData.visible}}
                                <div class='anns'>
                                    {{#if this.annsData.isFilled}}
                                        <p>{{this.annsData.num_anns}} users are celebrating their anniversary!</p>
                                        <!-- Display the anniversaries data -->
                                        {{#each this.annsData.anns_users as |username|}}
                                            <span><a class='mention'>{{username}}</a></span>
                                        {{/each}}
                                    {{else}}
                                        <p>No one has their anniversary today!</p>
                                    {{/if}}
                                </div>
                            {{/if}}
                            <br />
                            {{#if this.bdaysData.visible}}
                                <div class='bdays'>
                                    {{#if this.bdaysData.isFilled}}
                                        <p>{{this.bdaysData.num_bdays}} users are celebrating their birthday!</p>
                                        <!-- Display the birthday data -->
                                        {{#each this.bdaysData.bdays_users as |username|}}
                                        {{/each}}
                                    {{else}}
                                        <p>No one is celebrating their birthday today!</p>
                                    {{/if}}
                                </div>
                            {{/if}}
                        </div>
                    {{/if}}
                {{/if}}
            </template>
A parte que não está funcionando são as variáveis this.isAnnsVisible e this.isBdaysVisible. Elas não parecem estar sendo atualizadas, o que faz com que o banner seja exibido.
É estranho que essas variáveis não estejam sendo atualizadas. Será que elas não estão sendo usadas corretamente?
Desculpe por reabrir este tópico, mas ainda não tenho ideia do porquê isso está acontecendo.
Meu código agora:
import { ajax } from "discourse/lib/ajax";
import { getOwner } from '@ember/application';
    api.renderInOutlet(
            @service router;
            constructor() {
                this.fetchAnnsData(); // Busca automaticamente na inicialização
            // Busca os dados de forma assíncrona e atualiza a propriedade rastreada
            @action
                console.log(json);
                let allAnns = json['anniversaries']; // É uma lista de dicionários
            @action
                 // Declara bdaysDataFinal aqui
                let bdaysDataFinal;
                // Busca os dados de aniversário
                // Executa a lógica para processar os dados
                let allBdays = json['birthdays']; // É uma lista de dicionários
                //console.log(annsDataFinal);  // Apenas para verificar o resultado
            @action
                // Verifica se é anns ou bdays
                if (bannerData.num_anns) { // É anns
                } else { // É bdays
                // Usa uma desigualdade. Se não for igual (true), o banner é exibido. Se for igual, a desigualdade não é satisfeita e o banner será ocultado.
                this.areBothBannersVisible = !(this.isAnnsVisible === false && this.isBdaysVisible === false); // Ou: this.areBothBannersVisible = this.isAnnsVisible || this.isBdaysVisible;
            // Getter para os dados
            get annsData() {
                        } else {
                    } else {
                    // Se os dados ainda não foram carregados, retorne null ou qualquer valor padrão
            get bdaysData() {
                            console.log(`this.isAnnsVisible: ${this.isAnnsVisible}`);
                            console.log(`this.isBdaysVisible: ${this.isBdaysVisible}`);
                        } else {
                    } else {
            get isHomepage() {
            <template>
                                <div class='anns'>
                                        <p>{{this.annsData.num_anns}} usuários estão celebrando seu aniversário!</p>
                                        <!-- Exibe os dados de aniversário -->
                                        {{/each}}
                                    {{else}}
                                        <p>Ninguém tem aniversário hoje!</p>
                                    {{/if}}
                                </div>
                            {{/if}}
                            <br />
                                <div class='bdays'>
                                        <p>{{this.bdaysData.num_bdays}} usuários estão celebrando seu aniversário!</p>
                                        {{/each}}
                                    {{else}}
                                        <p>Ninguém está celebrando seu aniversário hoje!</p>
                                    {{/if}}
                                </div>
                            {{/if}}
                        </div>
                    {{/if}}
                {{/if}}
            </template>
Meu repositório:
Ainda não tenho certeza, mas…
este await é desnecessário.
a resposta já deve ser um objeto, então não tenho certeza por que você precisa do .json() etc.? Você provavelmente pode simplificar isso muito
você não precisa passar isso, pois as variáveis rastreadas estão no escopo em todo o Componente, então apenas chame-o e refira-se a ele na ação.
Algumas dicas de estilo:
  • não sobrecarregue seu código compartilhado com console.logs, isso dificulta a visualização da floresta pelas árvores
  • use indentação de dois espaços, não 4, que é um padrão do discourse. Veja seu template
  • considere mover isso para um arquivo .gjs dedicado
  • você pode clicar nos números no github e obter um link compartilhável que visualiza o código, se precisar.
avançado:
  • configure Prettier e ESlint … o primeiro para estilo e o segundo para estilo e pode ajudá-lo a capturar alguns bugs.
Não é isso, é?
Você não precisa ir tão longe, mas essa é uma opção.
É o suficiente para fazer manualmente no início.
Provavelmente isso não funciona.
Eu não acho que o EmberJS observe propriedades aninhadas.
Você deve criar, rastrear e testar propriedades no mesmo nível.
Portanto, crie uma propriedade rastreada chamada, digamos, annsDataVisible, atualize seu valor e use-a em sua instrução if.
Você também pode reatribuir o objeto inteiro a cada vez em vez de apenas um valor de um atributo filho, o que pode acionar uma repintura.
