Как я могу это изменить? smtp
I want to edit this for METERS
I don’t know what “METERS” is (is it Metermail?), but you can change SMTP settings by editing your app.yml file.
The steps are also described here: Troubleshoot email on a new Discourse install
4 лайка
Which SMTP do you recommend for sending?
It depends on how many emails your forum will send each month. For a small forum, the free Mailgun plan might be enough with 100 emails per day, until you figure out if you need more.
2 лайка
Just a side note that Brevo gives 300 a day for free. No issues so far.
1 лайк
At least one user here had issues:
1 лайк
I think this getting off-topic. Let’s bring this to a new topic if you want :slightly_smiling_face:.
1 лайк
