I’m actually concerned that someone might maliciously upload files and fill up my S3 bucket. It would be great if there was a setting to limit the number of uploads or the total file size per user per day.
제목에 대해 직접 답변드리자면,
이것은 테마 컴포넌트이기 때문에 사용자가 우회할 수 있으며, 특히 안전 모드를 활성화할 수 있는 경우 더욱 그렇습니다. 일종의 “소프트” 제한이라 할 수 있습니다.
또한 그룹을 지원하지 않지만, 이는 Contribute > Feature 요청으로 문의할 수 있습니다 ![]()
| Max image size KB | The maximum image upload size. This must be configured in nginx (client_max_body_size) / apache or proxy as well. Images larger than this and smaller than client_max_body_size will be resized to fit on upload. |
| Max attachment size KB | The maximum attachment files upload size. This must be configured in nginx (client_max_body_size) / apache or proxy as well. |
params:
version: tests-passed
## Maximum upload size (default: 10m)
upload_size: 20m
I want to know if I can limit the number of upload attempts or the total file size per user per day through that method?
I want to block malicious users, you know, but the component you recommended can only block regular users. ![]()
It’s not possible to set such a limitation without creating a custom plugin.
Do you suspect it already happened? Did you notice a sudden increase in uploads used space?
If not, what makes you think such an exploit could happen?
Maybe it helps to describe your problem more specifically. Which file extensions are allowed on your forum (Authorized extensions site setting)? By default, only images are allowed. Then requiring approval for posts containing images from users with a low trust level could help (Skip review media groups).
You can also identify such users in the “Top uploads” report in the admin area.
There isn’t any at the moment, maybe I’m being too pessimistic. However, as you mentioned, even if it’s a plugin, it can be disabled through safe mode. It seems that the only way to prevent it is through server or S3 bucket settings.
Thank you for your advice. However, if it’s a malicious user, can they disguise other files as image formats? And since there are no restrictions on the number or total size of images, can they still upload images without limit? Also, I still don’t understand whether the files will occupy my S3 bucket if they upload successfully but don’t publish a topic.
You can imagine thousands of ways of disrupting any software in which you can add data, so I wouldn’t worry about this imaginary problem and focus my attention on other things ![]()
Here’s some documentation regarding that.
You can also try removing trust_level_0 from the Embedded media post allowed groups site setting and adding it to another trust level group. Though I was still able to upload my image, I wasn’t able to post it with my test user.
Maybe you’re right. I shouldn’t let too many concerns stop me from taking action.I am a perfectionist, and too many worries always make me easily discouraged.
I think I’ll use this feature, even though I don’t really want to create too many obstacles for normal users. I just don’t want to be played with or taken advantage of by a very small number of evil users.
If I understand correctly, it works as I thought: the upload will occupy space in the S3 bucket, which really worries me. While there is an automatic cleanup feature that works well under normal circumstances, malicious users can easily bypass posting restrictions and keep uploading files.
Regarding safe-mode.
