Topic page layout issue on iOS 15
A layout issue on the topic page has been reported by Don on iOS 15.8.3, with problems including a non-blurred footer nav and a page that can be moved sideways. pmusaraj confirmed the issue, suspecting a regression from recent commits. Don investigated further and found that adding the -webkit- prefix fixed the footer nav issue. awesomerobot and david provided links to GitHub pull requests (#30910, #30913, and #30914) that should fix the layout issues on older iOS versions. The fixes have been confirmed to work by Don.
Hello :waving_hand:
I am on iPhone 6s iOS 15.8.3 and on the topic page the layout seems has some issue on meta :confused: I didn’t update my site yet so I don’t know it happens only on meta… I didn’t have time to check the commits yet…
And also noticed the footer nav is not blurred anymore…
I’ve noticed also I can move the whole page side ways. (It seems this is only happens in DiscourseHun and PWA)
It’s probably already discussed on meta, if yes please feel free to move this to the related topic. :slightly_smiling_face:
Thanks :slightly_smiling_face:
Seeing the same, feels like a regression from recent commits, no repro on a site deployed on a commit from 4 days ago. We will look into it. Thanks!
This I can’t repro on either Hub or PWA.
It seems it’s going to be a support problem. I connected my phone to the mac and inspect the PWA.
Checked caniuse and it seems it requires the -webkit- prefix on my iOS version.
Yep, adding -webkit- prefix fixed it.
This should fix it soon: UX: set mobile read state indicator to static size to avoid overflow by awesomerobot · Pull Request #30910 · discourse/discourse · GitHub
Seems maybe related to a font change? haven’t narrowed it down specifically
This will fix some more layout issues on older iOS versions:
https://github.com/discourse/discourse/pull/30913
And the prefix for backdrop-filter:
https://github.com/discourse/discourse/pull/30914
Thanks for the quick fixes. Works great now :blush:
