Dashboard Report - Topic View Stats
The Dashboard Report - Topic View Stats discussion provides an SQL query for collecting and aggregating topic view statistics within a given date range. As explained by SaraDev, the query filters data by date range (:start_date and :end_date) and category (using :category_id), and sums up anonymous views, logged-in views, and total views. The results are ranked by total views and limited to the top 100 topics, returning columns such as topic_id, topic_title, total_anonymous_views, total_logged_in_views, and total_views. The query utilizes the topic_view_stats database table, which was added to Discourse in May 2024, and will not show data prior to this.
This is an SQL version of the Dashboard Report for Topic View Stats.
This report collects and aggregates topic view statistics, including anonymous and logged-in views, within a given date range. It also allows filtering by categories and optionally includes subcategories.
:discourse: This query and thetopic_view_stats database table was added to Discourse in May 2024, and will not show any data prior to this.
-- [params]
-- date :start_date
-- date :end_date
-- int :category_id = 0
-- boolean :include_subcategories = false
WITH category_filter AS (
  SELECT
    id
  FROM categories
  WHERE
    (:category_id = 0 OR id = :category_id)
    OR (:include_subcategories AND parent_category_id = :category_id)
SELECT
  topic_view_stats.topic_id,
  topics.title AS topic_title,
  SUM(topic_view_stats.anonymous_views) AS total_anonymous_views,
  SUM(topic_view_stats.logged_in_views) AS total_logged_in_views,
  SUM(topic_view_stats.anonymous_views + topic_view_stats.logged_in_views) AS total_views
FROM topic_view_stats
INNER JOIN topics ON topics.id = topic_view_stats.topic_id
WHERE
  topic_view_stats.viewed_at BETWEEN :start_date AND :end_date
  AND (
    :category_id = 0
    OR topics.category_id IN (SELECT id FROM category_filter)
GROUP BY topic_view_stats.topic_id, topics.title
ORDER BY total_views DESC
LIMIT 100
SQL Query Explanation
Parameters
  • :start_date (date): The beginning date of the range for the analysis (inclusive).
  • :end_date (date): The ending date of the range for the analysis (inclusive).
  • :category_id (integer, optional): Filter topics by category. Use:
    • 0 to include all categories.
    • Any specific category ID to filter by that category.
  • :include_subcategories (boolean, optional): Choose whether to include subcategories of the specified category.
    • false: Only the selected category.
    • true: Also include subcategories.
Category filtering
The category_filter Common Table Expression (CTE) retrieves the selected category ID(s) based on the :category_id parameter. If the parameter is 0, all categories are included. If subcategories are to be included, it finds categories where the parent_category_id matches the specified :category_id.
Retrieve topic stats
Topic view statistics are aggregated from the topic_view_stats table, joined with the topics table to retrieve topic titles.
Apply date and category filters
The query filters the topic_view_stats data:
  • By the provided date range (:start_date and :end_date).
  • By category, matching against the IDs in the category_filter.
Calculate total views
The query sums up:
  • anonymous_views: Views from anonymous users.
  • logged_in_views: Views from logged-in users.
  • Total views as the sum of both.
Ranking and limiting:
The query ranks topics by total_views and limits the result to the top 100 topics.
Query Results
The query returns the following columns:
Column Name Description
topic_id The unique identifier for the topic.
topic_title The title of the topic.
total_anonymous_views The total views from anonymous users.
total_logged_in_views The total views from logged-in users.
total_views The total views (anonymous + logged-in).
Example Results
topic_id topic_title total_anonymous_views total_logged_in_views total_views
12345 “Example Topic 1” 500 300 800
67890 “Example Topic 2” 450 350 800
