Upcoming post stream changes - How to prepare themes and plugins
Discourse is transitioning from the legacy widget-based post stream to a modern Glimmer component system. The migration began in Q2 2025, with the new system enabled by default in the next update, effectively disabling the old widget rendering. Site administrators can test the new system by setting glimmer_post_stream_mode to auto, which will trigger console warnings for incompatible plugins or themes. The guide explains how to update customizations, including handling components like UserAvatarFlair that use @post instead of @user. While the Glimmer Post Stream is now the default, the experimental setting still warns against production use. The widget system will be fully removed in a future update, and developers are encouraged to migrate their plugins and themes to ensure compatibility.
We’re moving away from the legacy “widget” rendering system, replacing it with modern Glimmer components.
We’ve recently modernized the post stream using Glimmer components. This guide will walk you through migrating your plugins and themes from the old widget-based system to the new Glimmer implementation.
Don’t worry—this migration is more straightforward than it might seem at first glance. We’ve designed the new system to be more intuitive and powerful than the old widget system, and this guide will help you through the process.
Timeline
These are estimates subject to change
Q2 2025:
  • :white_check_mark: Core implementation finished
  • :white_check_mark: Start upgrading the official plugins and theme components
  • :white_check_mark: Enabled on Meta
  • :white_check_mark: Published upgrade advice (this guide)
Q3 2025:
  • :white_check_mark: Finish upgrading the official plugins and theme components
  • :white_check_mark: Set glimmer_post_stream_mode default to auto and enable console deprecation messages
  • :white_check_mark: Enable deprecation messages with an admin warning banner (planned for July 2025)
  • Third-party plugins and themes should be updated
Q4 2025:
  • :white_check_mark: Enable the new post stream by default
  • :white_check_mark: Remove the feature flag setting and legacy code
What does it mean for me?
If any of your plugins or themes use any ‘widget’ APIs to customize the post stream, you’ll need to update them to work with the new version.
How do I try the new post stream?
To try the new post stream, simply change the glimmer_post_stream_mode setting to auto in your site settings. This will enable the new post stream if you don’t have any incompatible plugins or themes.
When glimmer_post_stream_mode is set to auto, Discourse automatically detects incompatible plugins and themes and if it finds any, you’ll see helpful warning messages in the browser console that identify exactly which plugins or themes need updating, along with stack traces to help you locate the relevant code.
These messages will help you identify exactly which parts of your plugins or themes need to be updated to be compatible with the new Glimmer post stream.
If you encounter any issues using the new post stream, don’t worry, for now, you can still set the setting to disabled to return to the old system. If you have incompatible extensions installed, but still want to try it, as an admin you can set the option to enabled to force the new post stream. Just use this with caution—your site might not work properly depending on which customizations you have.
I have custom plugins or themes installed. Do I need to update them?
You’ll need to update your plugins or themes if they perform any of the following customizations:
  • Use decorateWidget, changeWidgetSetting, reopenWidget or attachWidgetAction on these widgets:
    • actions-summary
    • avatar-flair
    • embedded-post
    • expand-hidden
    • expand-post-button
    • filter-jump-to-post
    • filter-show-all
    • post-article
    • post-avatar-user-info
    • post-avatar
    • post-body
    • post-contents
    • post-date
    • post-edits-indicator
    • post-email-indicator
    • post-gap
    • post-group-request
    • post-links
    • post-locked-indicator
    • post-meta-data
    • post-notice
    • post-placeholder
    • post-stream
    • post
    • poster-name
    • poster-name-title
    • posts-filtered-notice
    • reply-to-tab
    • select-post
    • topic-post-visited-line
  • Use one of the API methods below:
    • addPostTransformCallback
    • includePostAttributes
:light_bulb: If you have extensions that use any of the customizations above, you’ll see a warning in the console identifying which plugin or component needs to be upgraded when you visit a topic page.
The deprecation ID is: discourse.post-stream-widget-overrides
:warning: If you use more than one theme in your instance, be sure to check all of them since the warnings will only appear for active plugins and currently used themes and theme-components.
What are the replacements?
The new Glimmer post stream gives you several ways to customize how posts appear:
  1. Plugin Outlets: For adding content at specific points in the post stream.
  2. Transformers: For customizing items, modifying data structures, or changing the behavior of components.
Replacing includePostAttributes with addTrackedPostProperties
If your plugin uses includePostAttributes to add properties to the post model, you’ll need to update it to use addTrackedPostProperties instead.
Before:
api.includePostAttributes('can_accept_answer', 'accepted_answer', 'topic_accepted_answer');
After:
api.addTrackedPostProperties('can_accept_answer', 'accepted_answer', 'topic_accepted_answer');
The addTrackedPostProperties function marks properties as tracked for post updates. This is important if your plugin adds properties to a post and uses them during rendering. It ensures the UI updates automatically when these properties change.
Common Migration Patterns
Using Plugin Outlets
Plugin outlets are your main tool for adding content at specific points in the post stream. Think of them as designated spots where you can inject your custom content.
They’re the key to migrating away from widget decorations.
The Glimmer Post Stream wraps often customized content in outlets. Use the plugin API functions renderBeforeWrapperOutlet and renderAfterWrapperOutlet to insert content before or after them.
1. Replacing widget decorations with Plugin Outlets
The most common customization is adding content to posts. In the widget system, you’d use decorateWidget. With Glimmer, you’ll use plugin outlets instead.
Before:
// Part of an initializer in a plugin
import { withPluginApi } from "discourse/lib/plugin-api";
// ... other imports
function customizeWidgetPost(api) {
  api.decorateWidget("post-contents:after-cooked", (helper) => {
    const post = helper.getModel();
    if (post.post_number === 1 && post.topic.accepted_answer) {
      return helper.attach("solved-accepted-answer", { post });
export default {
  initialize() {
    withPluginApi((api) => {
      // ... other customizations
      customizeWidgetPost(api);
After:
// Part of a .gjs initializer in a plugin
import Component from "@glimmer/component";
import SolvedAcceptedAnswer from "../components/solved-accepted-answer";
function customizePost(api) {
  api.renderAfterWrapperOutlet(
    "post-content-cooked-html",
    class extends Component {
      static shouldRender(args) {
        return args.post?.post_number === 1 && args.post?.topic?.accepted_answer;
      <template>
        <SolvedAcceptedAnswer
          @post={{@post}}
      </template>
export default {
  initialize() {
      customizePost(api);
2. Adding content after the Poster Name
If your plugin adds content after the poster name, you’ll use the renderAfterWrapperOutlet API with the post-meta-data-poster-name outlet.
Before:
  api.decorateWidget(`poster-name:after`, (dec) => {
    if (!isGPTBot(dec.attrs.user)) {
      return;
    return dec.widget.attach("persona-flair", {
      personaName: dec.model?.topic?.ai_persona_name,
export default {
  initialize() {
After:
    "post-meta-data-poster-name",
        return isGPTBot(args.post?.user);
      <template>
        <span class="persona-flair">{{@post.topic.ai_persona_name}}</span>
      </template>
export default {
  initialize() {
      customizePost(api);
3. Adding Content Before Post Content
// Part of a .gjs initializer in a theme
  api.renderBeforeWrapperOutlet(
    "post-article",
        return args.post?.topic?.pinned;
      <template>
        <div class="pinned-post-notice">
          This is a pinned topic
        </div>
      </template>
export default {
  initialize() {
      customizePost(api);
4. Adding Content After Post Content
    "post-article",
        return args.post?.wiki;
      // In a real component, you would use a template like this:
      <template>
        <div class="wiki-post-notice">
          This post is a wiki
        </div>
      </template>
export default {
  initialize() {
      customizePost(api);
Using Transformers
Transformers are a powerful way to customize Discourse components. They let you modify data or component behavior without having to override entire components.
Here are some of the most relevant value transformers for post stream customization:
Transformer Name Description Context
post-class Customize CSS classes applied to the main post element. { post }
post-meta-data-infos Customize the list of metadata components displayed for a post. This allows adding, removing, or reordering items like the post date, edit indicator, etc. { post, metaDataInfoKeys }
post-meta-data-poster-name-suppress-similar-name Decide whether to suppress displaying the user’s full name when it is similar to their username. Return true to suppress. { post, name }
post-notice-component Customize or replace the component used to render a post notice. { post, type }
post-show-topic-map Control the visibility of the topic map component on the first post. { post, isPM, isRegular, showWithoutReplies }
post-small-action-class Add custom CSS classes to a small action post. { post, actionCode }
post-small-action-custom-component Replace a standard small action post with a custom Glimmer component. { post, actionCode }
post-small-action-icon Customize the icon used for a small action post. { post, actionCode }
poster-name-class Add custom CSS classes to the poster’s name container. { user }
1. Adding a Custom Class to Posts
function customizePostClasses(api) {
  api.registerValueTransformer(
    "post-class",
    ({ value, context }) => {
      const { post } = context;
      // Add a custom class to posts from a specific user
      if (post.user_id === 1) {
        return [...value, "special-user-post"];
      return value;
export default {
  initialize() {
      customizePostClasses(api);
2. Adding Custom Post Metadata
The post-meta-data-infos transformer allows you to add custom components to the post metadata section.
function customizePostMetadata(api) {
  // Define a component to be used in the metadata section
  // The component should be created outside the transformer callback,
  // otherwise it can cause memory issues.
  const CustomMetadataComponent = <template>...</template>;
    "post-meta-data-infos",
    ({ value: metadata, context: { post, metaDataInfoKeys } }) => {
      // Only add the component for specific posts
      if (post.some_custom_property) {
        metadata.add(
          "custom-metadata-key",
          CustomMetadataComponent,
            // Position it before the date
            before: metaDataInfoKeys.DATE,
            // and after the reply tab
            after: metaDataInfoKeys.REPLY_TO_TAB,
export default {
  initialize() {
      customizePostMetadata(api);
Here’s a real-world example from the discourse-activity-pub plugin:
// Part of an initializer in the discourse-activity-pub plugin
import ActivityPubPostStatus from "../components/activity-pub-post-status";
import {
  activityPubPostStatus,
  showStatusToUser,
} from "../lib/activity-pub-utilities";
function customizePost(api, container) {
  const currentUser = api.getCurrentUser();
  const PostMetadataActivityPubStatus = <template>
    <div class="post-info activity-pub">
      <ActivityPubPostStatus @post={{@post}} />
    </div>
  </template>;
      const site = container.lookup("service:site");
      const siteSettings = container.lookup("service:site-settings");
      if (
        site.activity_pub_enabled &&
        post.activity_pub_enabled &&
        post.post_number !== 1 &&
        showStatusToUser(currentUser, siteSettings)
        const status = activityPubPostStatus(post);
        if (status) {
          metadata.add(
            "activity-pub-indicator",
            PostMetadataActivityPubStatus,
export default {
  initialize(container) {
      customizePost(api, container);
5. Inserting content before or after the cooked content of the post
If your plugin adds content after the text in the post, you’ll use the renderAfterWrapperOutlet API with the post-content-cooked-html outlet.
Before:
function customizeCooked(api) {
    if (post.wiki) {
      const banner = document.createElement("div");
      banner.classList.add("wiki-footer");
      banner.textContent = "This post is a wiki";
      element.prepend(banner);
export default {
  initialize() {
      customizeCooked(api);
After:
// Part of an initializer in a plugin (.gjs)
// Define a component to be used in the plugin outlet
class WikiBanner extends Component {
    return args.post.wiki;
  <template>
    <div class="wiki-footer">This post is a wiki</div>
  </template>
  // Use renderBeforeWrapperOutlet to add content before the post content
    WikiBanner
export default {
  initialize() {
      customizePost(api);
Supporting Both Old and New Systems During Transition
As a plugin or theme author, you may want to support both systems during the transition to ensure your extensions work with both the old and new post streams.
Here’s a pattern used by many official plugins:
// solved-button.js
import { withSilencedDeprecations } from "discourse/lib/deprecated";
import RenderGlimmer from "discourse/widgets/render-glimmer";
  // glimmer post stream customizations
      <template>
          @post={{@post}}
          @decoratorState={{@decoratorState}}
      </template>
  // wrap the old widget code silencing the deprecation warnings
  withSilencedDeprecations("discourse.post-stream-widget-overrides", () =>
// old widget code
    let post = helper.getModel();
    if (helper.attrs.post_number === 1 && post?.topic?.accepted_answer) {
      // Use RenderGlimmer to render a Glimmer component in the widget system
      return new RenderGlimmer(
        helper.widget,
        "div",
        <template><SolvedAcceptedAnswer @post={{@data.post}} /></template>
        null,
        { post }
export default {
    if (siteSettings.solved_enabled) {
        customizePost(api);
Real-World Examples
Here are links to actual migration pull requests from our official plugins. These show how we updated each type of customization:
Troubleshooting
My site looks broken after enabling the new post stream
  • Set glimmer_post_stream_mode back to disabled
  • Check the console for specific error messages
  • Update the problematic plugins/themes before trying again
I don’t see any warnings, but my customizations aren’t working
  • Check that your customizations target the widgets listed above
  • Make sure you’re testing on the topic page with topics where your customizations are visible
Need Help?
If you found a bug or your customization can’t be achieved using the new APIs we’ve introduced, please let us know below.
The Glimmer Post Stream is enabled on Meta.
If you discover any issues, please post them below.
During upgrading my components, I encountered some strange code:
Firstly, I am somewhat perplexed by @user={{@post}}. Could this be a typographical error?
Secondly, why are the PluginOutlet named post-avatar-flair and the UserAvatarFlair separate elements? Additionally, why isn’t post-avatar-flair a wrapper like other nearby outlets?
It’s working, so I don’t think it’s a typo. Perhaps in this location, the post object has all the attributes which the UserAvatarFlair component expects to find on the @user argument? I agree it’s weird looking!
Based on the PR description, it looks like those things were done for consistency with other similar ‘avatar-flair’ outlets (which were probably introduced before ‘wrapper plugin outlets’ were a thing)
We have just merged a pull request that enables the Glimmer Post Stream by default.
After the next update, compatible sites will automatically use the new Post Stream. Sites using incompatible extensions will fall back to the older version and display warnings in the browser console.
For now, you can manually enforce the use of the old Post Stream by setting glimmer_post_stream_mode to disabled.
If you encounter any issues, please report them below.
I think I get a warning due to this code that then links to this thread:
api.changeWidgetSetting('post-avatar', 'size', '120');
How would I update that for the new system?
Something like that:
api.registerValueTransformer("post-avatar-size", () => {
    return "120";
Nice, thanks.
I think that works. I put in that code and then tried to temporarily set all the force settings on for the glimmer mode and it looked like the avatar size and posts list worked on my site fine after that. After testing I turned off the overrides as it seems they are not recommended for use yet. But my site should now hopefully be ready for the switch-over.
Hi @Boost. :smiley:
What do you mean when you say the overrides are not recommended for use just yet? If your site is ready, it will switch to the Glimmer Post Stream automatically.
https://github.com/discourse/discourse/pull/35504
When you next update your Discourse installation, the Glimmer Post Stream will now be enabled by default even for sites that still have incompatible customizations.
In fact, the entire widget rendering system will now be disabled, so any widget-based customization won’t be rendered anymore.
For now, on incompatible sites, the admin can re-enable the old behavior by modifying the values of the following settings:
  • glimmer_post_stream_mode
  • deactivate_widgets_rendering
To enable the widget post stream again, both settings need to be changed.
This is the final phase before removing the old code from the Discourse code base, which is expected to happen in about a month. Subsequently, it won’t be possible to re-enable widgets anymore.
The option under experimental settings quite clearly warns against using it:
Enable the new ‘glimmer’ post stream implementation in ‘auto’ mode for the specified user groups. This implementation is under active development, and is not intended for production use. Do not develop themes/plugins against it until the implementation is finalized and announced.
So the wording is pretty strong in saying that it “is not intended for production use. Do not develop themes/plugins against it”
That’s the explanation for the option Glimmer post stream mode auto groups.
Good catch. We missed this.
The Glimmer Post Stream is now the default, and the widget version is considered legacy and already scheduled to be removed. I’ll update the setting description.
The PR removing the widget post-stream was merged.
