Cambiamenti imminenti allo stream di post - Come preparare temi e plugin
We’re moving away from the legacy “widget” rendering system, replacing it with modern Glimmer components.
We’ve recently modernized the post stream using Glimmer components. This guide will walk you through migrating your plugins and themes from the old widget-based system to the new Glimmer implementation.
Don’t worry—this migration is more straightforward than it might seem at first glance. We’ve designed the new system to be more intuitive and powerful than the old widget system, and this guide will help you through the process.
Timeline
These are estimates subject to change
Q2 2025:
  • :white_check_mark: Core implementation finished
  • :white_check_mark: Start upgrading the official plugins and theme components
  • :white_check_mark: Enabled on Meta
  • :white_check_mark: Published upgrade advice (this guide)
Q3 2025:
  • :white_check_mark: Finish upgrading the official plugins and theme components
  • :white_check_mark: Set glimmer_post_stream_mode default to auto and enable console deprecation messages
  • :white_check_mark: Enable deprecation messages with an admin warning banner (planned for July 2025)
  • Third-party plugins and themes should be updated
Q4 2025:
  • :white_check_mark: Enable the new post stream by default
  • 17th November: Remove the feature flag setting and legacy code
What does it mean for me?
If any of your plugins or themes use any ‘widget’ APIs to customize the post stream, you’ll need to update them to work with the new version.
How do I try the new post stream?
To try the new post stream, simply change the glimmer_post_stream_mode setting to auto in your site settings. This will enable the new post stream if you don’t have any incompatible plugins or themes.
When glimmer_post_stream_mode is set to auto, Discourse automatically detects incompatible plugins and themes and if it finds any, you’ll see helpful warning messages in the browser console that identify exactly which plugins or themes need updating, along with stack traces to help you locate the relevant code.
These messages will help you identify exactly which parts of your plugins or themes need to be updated to be compatible with the new Glimmer post stream.
If you encounter any issues using the new post stream, don’t worry, for now, you can still set the setting to disabled to return to the old system. If you have incompatible extensions installed, but still want to try it, as an admin you can set the option to enabled to force the new post stream. Just use this with caution—your site might not work properly depending on which customizations you have.
I have custom plugins or themes installed. Do I need to update them?
You’ll need to update your plugins or themes if they perform any of the following customizations:
  • Use decorateWidget, changeWidgetSetting, reopenWidget or attachWidgetAction on these widgets:
    • actions-summary
    • avatar-flair
    • embedded-post
    • expand-hidden
    • expand-post-button
    • filter-jump-to-post
    • filter-show-all
    • post-article
    • post-avatar-user-info
    • post-avatar
    • post-body
    • post-contents
    • post-date
    • post-edits-indicator
    • post-email-indicator
    • post-gap
    • post-group-request
    • post-links
    • post-locked-indicator
    • post-meta-data
    • post-notice
    • post-placeholder
    • post-stream
    • post
    • poster-name
    • poster-name-title
    • posts-filtered-notice
    • reply-to-tab
    • select-post
    • topic-post-visited-line
  • Use one of the API methods below:
    • addPostTransformCallback
    • includePostAttributes
:light_bulb: If you have extensions that use any of the customizations above, you’ll see a warning in the console identifying which plugin or component needs to be upgraded when you visit a topic page.
The deprecation ID is: discourse.post-stream-widget-overrides
:warning: If you use more than one theme in your instance, be sure to check all of them since the warnings will only appear for active plugins and currently used themes and theme-components.
What are the replacements?
The new Glimmer post stream gives you several ways to customize how posts appear:
  1. Plugin Outlets: For adding content at specific points in the post stream.
  2. Transformers: For customizing items, modifying data structures, or changing the behavior of components.
Replacing includePostAttributes with addTrackedPostProperties
If your plugin uses includePostAttributes to add properties to the post model, you’ll need to update it to use addTrackedPostProperties instead.
Before:
api.includePostAttributes('can_accept_answer', 'accepted_answer', 'topic_accepted_answer');
After:
api.addTrackedPostProperties('can_accept_answer', 'accepted_answer', 'topic_accepted_answer');
The addTrackedPostProperties function marks properties as tracked for post updates. This is important if your plugin adds properties to a post and uses them during rendering. It ensures the UI updates automatically when these properties change.
Common Migration Patterns
Using Plugin Outlets
Plugin outlets are your main tool for adding content at specific points in the post stream. Think of them as designated spots where you can inject your custom content.
They’re the key to migrating away from widget decorations.
The Glimmer Post Stream wraps often customized content in outlets. Use the plugin API functions renderBeforeWrapperOutlet and renderAfterWrapperOutlet to insert content before or after them.
1. Replacing widget decorations with Plugin Outlets
The most common customization is adding content to posts. In the widget system, you’d use decorateWidget. With Glimmer, you’ll use plugin outlets instead.
Before:
// Part of an initializer in a plugin
import { withPluginApi } from "discourse/lib/plugin-api";
// ... other imports
function customizeWidgetPost(api) {
  api.decorateWidget("post-contents:after-cooked", (helper) => {
    const post = helper.getModel();
    if (post.post_number === 1 && post.topic.accepted_answer) {
      return helper.attach("solved-accepted-answer", { post });
export default {
  initialize() {
    withPluginApi((api) => {
      // ... other customizations
      customizeWidgetPost(api);
After:
// Part of a .gjs initializer in a plugin
import Component from "@glimmer/component";
import SolvedAcceptedAnswer from "../components/solved-accepted-answer";
function customizePost(api) {
  api.renderAfterWrapperOutlet(
    "post-content-cooked-html",
    class extends Component {
      static shouldRender(args) {
        return args.post?.post_number === 1 && args.post?.topic?.accepted_answer;
      <template>
        <SolvedAcceptedAnswer
          @post={{@post}}
      </template>
export default {
  initialize() {
      customizePost(api);
2. Adding content after the Poster Name
If your plugin adds content after the poster name, you’ll use the renderAfterWrapperOutlet API with the post-meta-data-poster-name outlet.
Before:
  api.decorateWidget(`poster-name:after`, (dec) => {
    if (!isGPTBot(dec.attrs.user)) {
      return;
    return dec.widget.attach("persona-flair", {
      personaName: dec.model?.topic?.ai_persona_name,
export default {
  initialize() {
After:
    "post-meta-data-poster-name",
        return isGPTBot(args.post?.user);
      <template>
        <span class="persona-flair">{{@post.topic.ai_persona_name}}</span>
      </template>
export default {
  initialize() {
      customizePost(api);
3. Adding Content Before Post Content
// Part of a .gjs initializer in a theme
  api.renderBeforeWrapperOutlet(
    "post-article",
        return args.post?.topic?.pinned;
      <template>
        <div class="pinned-post-notice">
          This is a pinned topic
        </div>
      </template>
export default {
  initialize() {
      customizePost(api);
4. Adding Content After Post Content
    "post-article",
        return args.post?.wiki;
      // In a real component, you would use a template like this:
      <template>
        <div class="wiki-post-notice">
          This post is a wiki
        </div>
      </template>
export default {
  initialize() {
      customizePost(api);
Using Transformers
Transformers are a powerful way to customize Discourse components. They let you modify data or component behavior without having to override entire components.
Here are some of the most relevant value transformers for post stream customization:
Transformer Name Description Context
post-class Customize CSS classes applied to the main post element. { post }
post-meta-data-infos Customize the list of metadata components displayed for a post. This allows adding, removing, or reordering items like the post date, edit indicator, etc. { post, metaDataInfoKeys }
post-meta-data-poster-name-suppress-similar-name Decide whether to suppress displaying the user’s full name when it is similar to their username. Return true to suppress. { post, name }
post-notice-component Customize or replace the component used to render a post notice. { post, type }
post-show-topic-map Control the visibility of the topic map component on the first post. { post, isPM, isRegular, showWithoutReplies }
post-small-action-class Add custom CSS classes to a small action post. { post, actionCode }
post-small-action-custom-component Replace a standard small action post with a custom Glimmer component. { post, actionCode }
post-small-action-icon Customize the icon used for a small action post. { post, actionCode }
poster-name-class Add custom CSS classes to the poster’s name container. { user }
1. Adding a Custom Class to Posts
function customizePostClasses(api) {
  api.registerValueTransformer(
    "post-class",
    ({ value, context }) => {
      const { post } = context;
      // Add a custom class to posts from a specific user
      if (post.user_id === 1) {
        return [...value, "special-user-post"];
      return value;
export default {
  initialize() {
      customizePostClasses(api);
2. Adding Custom Post Metadata
The post-meta-data-infos transformer allows you to add custom components to the post metadata section.
function customizePostMetadata(api) {
  // Define a component to be used in the metadata section
  // The component should be created outside the transformer callback,
  // otherwise it can cause memory issues.
  const CustomMetadataComponent = <template>...</template>;
    "post-meta-data-infos",
    ({ value: metadata, context: { post, metaDataInfoKeys } }) => {
      // Only add the component for specific posts
      if (post.some_custom_property) {
        metadata.add(
          "custom-metadata-key",
          CustomMetadataComponent,
            // Position it before the date
            before: metaDataInfoKeys.DATE,
            // and after the reply tab
            after: metaDataInfoKeys.REPLY_TO_TAB,
export default {
  initialize() {
      customizePostMetadata(api);
Here’s a real-world example from the discourse-activity-pub plugin:
// Part of an initializer in the discourse-activity-pub plugin
import ActivityPubPostStatus from "../components/activity-pub-post-status";
import {
  activityPubPostStatus,
  showStatusToUser,
} from "../lib/activity-pub-utilities";
function customizePost(api, container) {
  const currentUser = api.getCurrentUser();
  const PostMetadataActivityPubStatus = <template>
    <div class="post-info activity-pub">
      <ActivityPubPostStatus @post={{@post}} />
    </div>
  </template>;
      const site = container.lookup("service:site");
      const siteSettings = container.lookup("service:site-settings");
      if (
        site.activity_pub_enabled &&
        post.activity_pub_enabled &&
        post.post_number !== 1 &&
        showStatusToUser(currentUser, siteSettings)
        const status = activityPubPostStatus(post);
        if (status) {
          metadata.add(
            "activity-pub-indicator",
            PostMetadataActivityPubStatus,
export default {
  initialize(container) {
      customizePost(api, container);
5. Inserting content before or after the cooked content of the post
If your plugin adds content after the text in the post, you’ll use the renderAfterWrapperOutlet API with the post-content-cooked-html outlet.
Before:
function customizeCooked(api) {
    if (post.wiki) {
      const banner = document.createElement("div");
      banner.classList.add("wiki-footer");
      banner.textContent = "This post is a wiki";
      element.prepend(banner);
export default {
  initialize() {
      customizeCooked(api);
After:
// Part of an initializer in a plugin (.gjs)
// Define a component to be used in the plugin outlet
class WikiBanner extends Component {
    return args.post.wiki;
  <template>
    <div class="wiki-footer">This post is a wiki</div>
  </template>
  // Use renderBeforeWrapperOutlet to add content before the post content
    WikiBanner
export default {
  initialize() {
      customizePost(api);
Supporting Both Old and New Systems During Transition
As a plugin or theme author, you may want to support both systems during the transition to ensure your extensions work with both the old and new post streams.
Here’s a pattern used by many official plugins:
// solved-button.js
import { withSilencedDeprecations } from "discourse/lib/deprecated";
import RenderGlimmer from "discourse/widgets/render-glimmer";
  // glimmer post stream customizations
      <template>
          @post={{@post}}
          @decoratorState={{@decoratorState}}
      </template>
  // wrap the old widget code silencing the deprecation warnings
  withSilencedDeprecations("discourse.post-stream-widget-overrides", () =>
// old widget code
    let post = helper.getModel();
    if (helper.attrs.post_number === 1 && post?.topic?.accepted_answer) {
      // Use RenderGlimmer to render a Glimmer component in the widget system
      return new RenderGlimmer(
        helper.widget,
        "div",
        <template><SolvedAcceptedAnswer @post={{@data.post}} /></template>
        null,
        { post }
export default {
    if (siteSettings.solved_enabled) {
        customizePost(api);
Real-World Examples
Here are links to actual migration pull requests from our official plugins. These show how we updated each type of customization:
Troubleshooting
My site looks broken after enabling the new post stream
  • Set glimmer_post_stream_mode back to disabled
  • Check the console for specific error messages
  • Update the problematic plugins/themes before trying again
I don’t see any warnings, but my customizations aren’t working
  • Check that your customizations target the widgets listed above
  • Make sure you’re testing on the topic page with topics where your customizations are visible
Need Help?
If you found a bug or your customization can’t be achieved using the new APIs we’ve introduced, please let us know below.
8 Mi Piace
Lo stream Glimmer Post è abilitato su Meta.
Se scopri problemi, pubblicali qui sotto.
2 Mi Piace
Durante l’aggiornamento dei miei componenti, ho riscontrato del codice strano:
Innanzitutto, sono un po’ perplesso da @user={{@post}}. Potrebbe trattarsi di un errore di battitura?
In secondo luogo, perché il PluginOutlet chiamato post-avatar-flair e UserAvatarFlair sono elementi separati? Inoltre, perché post-avatar-flair non è un wrapper come altri outlet vicini?
Sta funzionando, quindi non penso sia un errore di battitura. Forse in questa posizione, l’oggetto post ha tutti gli attributi che il componente UserAvatarFlair si aspetta di trovare sull’argomento @user? Concordo che ha un aspetto strano!
Sulla base di la descrizione della PR, sembra che tali cose siano state fatte per coerenza con altri ‘avatar-flair’ simili (che sono stati probabilmente introdotti prima che i ‘wrapper plugin outlets’ fossero una cosa).
2 Mi Piace
Abbiamo appena unito una pull request che abilita Glimmer Post Stream per impostazione predefinita.
Dopo il prossimo aggiornamento, i siti compatibili utilizzeranno automaticamente il nuovo Post Stream. I siti che utilizzano estensioni incompatibili torneranno alla versione precedente e visualizzeranno avvisi nella console del browser.
Per ora, puoi forzare manualmente l’uso del vecchio Post Stream impostando glimmer_post_stream_mode su disabled.
Se riscontri problemi, segnalali qui sotto.
5 Mi Piace
11 post sono stati spostati in un nuovo argomento: Errore Discourse-events ‘this.router’
Penso di ricevere un avviso a causa di questo codice che poi rimanda a questo thread:
api.changeWidgetSetting('post-avatar', 'size', '120');
Come posso aggiornarlo per il nuovo sistema?
Qualcosa del genere:
api.registerValueTransformer("post-avatar-size", () => {
    return "120";
2 Mi Piace
Bello, grazie.
Penso che funzioni. Ho inserito quel codice e poi ho provato a impostare temporaneamente tutte le impostazioni di forza attive per la modalità glimmer e sembrava che la dimensione dell’avatar e l’elenco dei post funzionassero correttamente sul mio sito dopo. Dopo il test, ho disattivato le sovrascritture poiché sembra che non siano ancora raccomandate per l’uso. Ma il mio sito dovrebbe ora essere pronto per il passaggio.
1 Mi Piace
Ciao @Boost. :smiley:
Cosa intendi quando dici che le sovrascritture non sono ancora consigliate per l’uso? Se il tuo sito è pronto, passerà automaticamente allo stream di post Glimmer.
Al prossimo aggiornamento della tua installazione di Discourse, Glimmer Post Stream sarà abilitato per impostazione predefinita anche per i siti che hanno ancora personalizzazioni incompatibili.
Infatti, tutti i sistemi di rendering dei widget sono ora disabilitati, quindi qualsiasi personalizzazione basata su widget non verrà più renderizzata.
Per ora, sui siti incompatibili, l’amministratore può riabilitare il vecchio comportamento modificando i valori delle seguenti impostazioni:
  • glimmer_post_stream_mode
  • deactivate_widgets_rendering
Per riabilitare nuovamente il Glimmer Post Stream, entrambe le impostazioni devono essere modificate.
Questa è la fase finale prima della rimozione del vecchio codice dalla codebase di Discourse, che è prevista tra circa un mese. Successivamente, non sarà più possibile riabilitare i widget.
5 Mi Piace
L’opzione nelle impostazioni sperimentali avverte chiaramente contro il suo utilizzo:
Abilita la nuova implementazione del post stream ‘glimmer’ in modalità ‘auto’ per i gruppi di utenti specificati. Questa implementazione è in fase di sviluppo attivo e non è destinata all’uso in produzione. Non sviluppare temi/plugin basati su di essa finché l’implementazione non sarà finalizzata e annunciata.
Quindi la formulazione è piuttosto forte nel dire che “non è destinata all’uso in produzione. Non sviluppare temi/plugin basati su di essa”.
Questa è la spiegazione dell’opzione Modalità auto gruppi post stream Glimmer.
Ottima osservazione. Ci è sfuggito.
Il Glimmer Post Stream è ora l’impostazione predefinita e la versione widget è considerata legacy e già programmata per la rimozione. Aggiornerò la descrizione dell’impostazione.
3 Mi Piace
