게시물/댓글 경계 밖으로 테이블이 렌더링됩니다
Context
This problem was originally discovered at:
…hence it content.
However, this method of embedding HTML5 inside Markdown tables is common: [1]
Reproducible Example
<p>Here's something to make y'all think!</p>
<table>
<thead>
<tr>
<th></th>
<th>Mine</th>
<th>My Brother's</th>
</tr>
</thead>
<tbody>
<tr>
<th><code>kinfo</code></th>
<td>
~~~YAML
Operating System: Fedora Linux 42
KDE Plasma Version: 6.4.3
KDE Frameworks Version: 6.16.0
Qt Version: 6.9.1
Kernel Version: 6.15.7-200.fc42.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 12 × AMD Ryzen 5 7600X 6-Core Processor
Memory: 32 GiB of RAM (30.4 GiB usable)
Graphics Processor 1: AMD Radeon RX 5700
Graphics Processor 2: AMD Radeon Graphics
Manufacturer: ASRock
Product Name: X670E Taichi
</td>
<td>
~~~YAML
Qt Version: 6.9.1
Graphics Processor 1: AMD Radeon RX 7900 XTX
</td>
</tr>
<tr>
<th><code>sudo tree /boot/efi</code></th>
<td>
~~~tree
/boot/efi
├── EFI
│   ├── BOOT
│   │   ├── BOOTIA32.EFI
│   │   ├── BOOTX64.EFI
│   │   ├── fbia32.efi
│   │   └── fbx64.efi
│   └── fedora
│       ├── BOOTIA32.CSV
│       ├── BOOTX64.CSV
│       ├── gcdia32.efi
│       ├── gcdx64.efi
│       ├── grub.cfg
│       ├── grubia32.efi
│       ├── grubx64.efi
│       ├── mmia32.efi
│       ├── mmx64.efi
│       ├── shim.efi
│       ├── shimia32.efi
│       └── shimx64.efi
├── mach_kernel
├── System
│   └── Library
│       └── CoreServices
│           └── SystemVersion.plist
└── System Volume Information
8 directories, 18 files
</td>
<td>
~~~tree
/boot/efi
├── EFI
│   ├── BOOT
│   │   ├── BOOTX64.EFI
│   │   ├── fbia32.efi
│   │   └── fbx64.efi
│   └── fedora
│       ├── BOOTIA32.CSV
│       ├── BOOTX64.CSV
│       ├── gcdia32.efi
│       ├── gcdx64.efi
│       ├── grub.cfg
│       ├── grubia32.efi
│       ├── grubx64.efi
│       ├── mmia32.efi
│       ├── mmx64.efi
│       ├── shim.efi
│       ├── shimia32.efi
│       └── shimx64.efi
├── mach_kernel
├── System
│   └── Library
│       └── CoreServices
</td>
</tr>
<tr>
<th><code>cat /etc/default/grub</code></th>
<td>
~~~sh
GRUB_TIMEOUT="15"
  # Original: GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)"
  # Original: Identical
GRUB_DEFAULT="saved"
GRUB_DISABLE_SUBMENU="true"
  # Original: Unknown
GRUB_TERMINAL_OUTPUT="gfxterm"
  # Original: GRUB_TERMINAL_OUTPUT="console"
GRUB_CMDLINE_LINUX=""
  # Original: GRUB_CMDLINE_LINUX="rhgb quiet"
GRUB_DISABLE_RECOVERY="false"
  # Original: GRUB_DISABLE_RECOVERY="true"
GRUB_ENABLE_BLSCFG="true"
  # Original: Unknown
  # Reason: https://discussion.fedoraproject.org/t/missing-boot-entries-with-grub-enable-blscfg-true/70805/3
GRUB_GFXMODE="2560x1440,auto"
  # Original: None
GRUB_DISABLE_OS_PROBER="true"
  # Original: None
  # Reason: https://github.com/MaddieM4/os-prober/issues/5#issue-777438588
</td>
<td>
~~~sh
GRUB_TIMEOUT=25
GRUB_DEFAULT=saved
GRUB_DISABLE_SUBMENU=true
GRUB_ENABLE_BLSCFG=true
GRUB_GFXMODE=2560x1440,auto
</td>
</tr>
<tr>
<th><code>sudo fdisk -l /dev/nvme2n1</code></th>
<td>
~~~YAML
Disk /dev/nvme2n1: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: addlink M.2 PCIE G4x4 NVMe
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: BDA1D2E0-E95A-4EB7-9502-BE9E43D64E3D
Device         Start        End    Sectors  Size Type
/dev/nvme2n1p1  2048 3907022847 3907020800  1.8T Linux filesystem
</td>
<td>
~~~YAML
Disklabel type: gpt
Disk identifier: 95F62691-D093-4072-8970-7D9108C0A5EE
/dev/nvme2n1p1       2048     206847     204800  100M EFI System
/dev/nvme2n1p2     206848     239615      32768   16M Microsoft reserved
/dev/nvme2n1p3     239616 3905492991 3905253376  1.8T Microsoft basic data
/dev/nvme2n1p4 3905492992 3907026943    1533952  749M Windows recovery environment
</td>
</tr>
<tr>
<th><code>sudo grub2-emu</code></th>
<td>
https://youtu.be/8JQsz23y2nA
<p>At least you all know it doesn't appear for me. I don't think <code>grub2-emu</code> has ever worked, because I have a search about this problem from 2025-01 in my browser history.</p>
</td>
<td>
![image|689x310](upload://krAW4TMsuOY98vWqIIs9Jhont9y.png)
Notice the "Windows Boot Manager"?!
</td>
</tr>
</tbody>
</table>
…renders as:
To confirm that it does so here:
Mine My Brother's
kinfo
Qt Version: 6.9.1
Qt Version: 6.9.1
sudo tree /boot/efi
/boot/efi
├── EFI
│   ├── BOOT
│   │   ├── BOOTX64.EFI
│   │   ├── fbia32.efi
│   │   └── fbx64.efi
│   └── fedora
│       ├── BOOTIA32.CSV
│       ├── BOOTX64.CSV
│       ├── gcdia32.efi
│       ├── gcdx64.efi
│       ├── grub.cfg
│       ├── grubia32.efi
│       ├── grubx64.efi
│       ├── mmia32.efi
│       ├── mmx64.efi
│       ├── shim.efi
│       ├── shimia32.efi
│       └── shimx64.efi
├── mach_kernel
├── System
│   └── Library
│       └── CoreServices
/boot/efi
├── EFI
│   ├── BOOT
│   │   ├── BOOTX64.EFI
│   │   ├── fbia32.efi
│   │   └── fbx64.efi
│   └── fedora
│       ├── BOOTIA32.CSV
│       ├── BOOTX64.CSV
│       ├── gcdia32.efi
│       ├── gcdx64.efi
│       ├── grub.cfg
│       ├── grubia32.efi
│       ├── grubx64.efi
│       ├── mmia32.efi
│       ├── mmx64.efi
│       ├── shim.efi
│       ├── shimia32.efi
│       └── shimx64.efi
├── mach_kernel
├── System
│   └── Library
│       └── CoreServices
GRUB_TIMEOUT="15"
  # Original: Unknown
  # Original: Unknown
  # Original: None
  # Original: None
GRUB_TIMEOUT=25
GRUB_DEFAULT=saved
Disklabel type: gpt
Disklabel type: gpt
sudo grub2-emu
At least you all know it doesn't appear for me. I don't think grub2-emu has ever worked, because I have a search about this problem from 2025-01 in my browser history.
Notice the “Windows Boot Manager”?!
  1. stackoverflow.com/revisions/60502719/3 ↩︎
이슈가 타당해 보이지만, #contribute:ux에 더 잘 맞는 것 같아서 해당 카테고리로 옮깁니다.
2개의 좋아요
Ah, love me some good old table-behaviour shenanigans.
Added a fix for it here
https://github.com/discourse/discourse/pull/34061
Still not elegant, but I don’t think we can achieve something more desirable than this (happy to be proven wrong), and at least all the content is now accessible.
2개의 좋아요
This topic was automatically closed after 5 days. New replies are no longer allowed.
