上下文
此问题最初发现于:
……因此其内容如此。
然而,在 Markdown 表格中嵌入 HTML5 的方法是常见的:[1]
可复现示例
<p>这里有些东西让大家思考一下!</p>
<table>
<thead>
<tr>
<th></th>
<th>我的</th>
<th>我兄弟的</th>
</tr>
</thead>
<tbody>
<tr>
<th><code>kinfo</code></th>
<td>
~~~YAML
Operating System: Fedora Linux 42
KDE Plasma Version: 6.4.3
KDE Frameworks Version: 6.16.0
Qt Version: 6.9.1
Kernel Version: 6.15.7-200.fc42.x86_64 (64-bit)
Graphics Platform: Wayland
Processors: 12 × AMD Ryzen 5 7600X 6-Core Processor
Memory: 32 GiB of RAM (30.4 GiB usable)
Graphics Processor 1: AMD Radeon RX 5700
Graphics Processor 2: AMD Radeon Graphics
Manufacturer: ASRock
Product Name: X670E Taichi
</td>
<td>
~~~YAML
Qt Version: 6.9.1
Graphics Processor 1: AMD Radeon RX 7900 XTX
</td>
</tr>
<tr>
<th><code>sudo tree /boot/efi</code></th>
<td>
~~~tree
/boot/efi
├── EFI
│ ├── BOOT
│ │ ├── BOOTIA32.EFI
│ │ ├── BOOTX64.EFI
│ │ ├── fbia32.efi
│ │ └── fbx64.efi
│ └── fedora
│ ├── BOOTIA32.CSV
│ ├── BOOTX64.CSV
│ ├── gcdia32.efi
│ ├── gcdx64.efi
│ ├── grub.cfg
│ ├── grubia32.efi
│ ├── grubx64.efi
│ ├── mmia32.efi
│ ├── mmx64.efi
│ ├── shim.efi
│ ├── shimia32.efi
│ └── shimx64.efi
├── mach_kernel
├── System
│ └── Library
│ └── CoreServices
│ └── SystemVersion.plist
└── System Volume Information
8 directories, 18 files
</td>
<td>
~~~tree
/boot/efi
├── EFI
│ ├── BOOT
│ │ ├── BOOTX64.EFI
│ │ ├── fbia32.efi
│ │ └── fbx64.efi
│ └── fedora
│ ├── BOOTIA32.CSV
│ ├── BOOTX64.CSV
│ ├── gcdia32.efi
│ ├── gcdx64.efi
│ ├── grub.cfg
│ ├── grubia32.efi
│ ├── grubx64.efi
│ ├── mmia32.efi
│ ├── mmx64.efi
│ ├── shim.efi
│ ├── shimia32.efi
│ └── shimx64.efi
├── mach_kernel
├── System
│ └── Library
│ └── CoreServices
</td>
</tr>
<tr>
<th><code>cat /etc/default/grub</code></th>
<td>
~~~sh
GRUB_TIMEOUT="15"
# Original: GRUB_TIMEOUT=5
GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)"
# Original: Identical
GRUB_DEFAULT="saved"
GRUB_DISABLE_SUBMENU="true"
# Original: Unknown
GRUB_TERMINAL_OUTPUT="gfxterm"
# Original: GRUB_TERMINAL_OUTPUT="console"
GRUB_CMDLINE_LINUX=""
# Original: GRUB_CMDLINE_LINUX="rhgb quiet"
GRUB_DISABLE_RECOVERY="false"
# Original: GRUB_DISABLE_RECOVERY="true"
GRUB_ENABLE_BLSCFG="true"
# Original: Unknown
# Reason: https://discussion.fedoraproject.org/t/missing-boot-entries-with-grub-enable-blscfg-true/70805/3
GRUB_GFXMODE="2560x1440,auto"
# Original: None
GRUB_DISABLE_OS_PROBER="true"
# Original: None
# Reason: https://github.com/MaddieM4/os-prober/issues/5#issue-777438588
</td>
<td>
~~~sh
GRUB_TIMEOUT=25
GRUB_DEFAULT=saved
GRUB_DISABLE_SUBMENU=true
GRUB_ENABLE_BLSCFG=true
GRUB_GFXMODE=2560x1440,auto
</td>
</tr>
<tr>
<th><code>sudo fdisk -l /dev/nvme2n1</code></th>
<td>
~~~YAML
Disk /dev/nvme2n1: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: addlink M.2 PCIE G4x4 NVMe
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: gpt
Disk identifier: BDA1D2E0-E95A-4EB7-9502-BE9E43D64E3D
Device Start End Sectors Size Type
/dev/nvme2n1p1 2048 3907022847 3907020800 1.8T Linux filesystem
</td>
<td>
~~~YAML
Disklabel type: gpt
Disk identifier: 95F62691-D093-4072-8970-7D9108C0A5EE
/dev/nvme2n1p1 2048 206847 204800 100M EFI System
/dev/nvme2n1p2 206848 239615 32768 16M Microsoft reserved
/dev/nvme2n1p3 239616 3905492991 3905253376 1.8T Microsoft basic data
/dev/nvme2n1p4 3905492992 3907026943 1533952 749M Windows recovery environment
</td>
</tr>
<tr>
<th><code>sudo grub2-emu</code></th>
<td>
https://youtu.be/8JQsz23y2nA
<p>至少你们都知道它对我来说没有出现。我不认为<code>grub2-emu</code>曾经有效过,因为我在浏览器历史记录中有一条关于此问题的搜索记录,时间是 2025-01。</p>
</td>
<td>
注意到“Windows Boot Manager”了吗?!
</td>
</tr>
</tbody>
</table>
……渲染效果如下:
为了确认它在这里确实如此:
这里有些东西让大家思考一下!
我的 我兄弟的 kinfoOperating System: Fedora Linux 42 KDE Plasma Version: 6.4.3 KDE Frameworks Version: 6.16.0 Qt Version: 6.9.1 Kernel Version: 6.15.7-200.fc42.x86_64 (64-bit) Graphics Platform: Wayland Processors: 12 × AMD Ryzen 5 7600X 6-Core Processor Memory: 32 GiB of RAM (30.4 GiB usable) Graphics Processor 1: AMD Radeon RX 5700 Graphics Processor 2: AMD Radeon Graphics Manufacturer: ASRock Product Name: X670E TaichiOperating System: Fedora Linux 42 KDE Plasma Version: 6.4.3 KDE Frameworks Version: 6.16.0 Qt Version: 6.9.1 Kernel Version: 6.15.7-200.fc42.x86_64 (64-bit) Graphics Platform: Wayland Processors: 12 × AMD Ryzen 5 7600X 6-Core Processor Memory: 32 GiB of RAM (30.4 GiB usable) Graphics Processor 1: AMD Radeon RX 7900 XTX Graphics Processor 2: AMD Radeon Graphics Manufacturer: ASRock Product Name: X670E Taichisudo tree /boot/efi/boot/efi ├── EFI │ ├── BOOT │ │ ├── BOOTIA32.EFI │ │ ├── BOOTX64.EFI │ │ ├── fbia32.efi │ │ └── fbx64.efi │ └── fedora │ ├── BOOTIA32.CSV │ ├── BOOTX64.CSV │ ├── gcdia32.efi │ ├── gcdx64.efi │ ├── grub.cfg │ ├── grubia32.efi │ ├── grubx64.efi │ ├── mmia32.efi │ ├── mmx64.efi │ ├── shim.efi │ ├── shimia32.efi │ └── shimx64.efi ├── mach_kernel ├── System │ └── Library │ └── CoreServices │ └── SystemVersion.plist └── System Volume Information 8 directories, 18 files/boot/efi ├── EFI │ ├── BOOT │ │ ├── BOOTIA32.EFI │ │ ├── BOOTX64.EFI │ │ ├── fbia32.efi │ │ └── fbx64.efi │ └── fedora │ ├── BOOTIA32.CSV │ ├── BOOTX64.CSV │ ├── gcdia32.efi │ ├── gcdx64.efi │ ├── grub.cfg │ ├── grubia32.efi │ ├── grubx64.efi │ ├── mmia32.efi │ ├── mmx64.efi │ ├── shim.efi │ ├── shimia32.efi │ └── shimx64.efi ├── mach_kernel ├── System │ └── Library │ └── CoreServices │ └── SystemVersion.plist └── System Volume Information 8 directories, 18 filescat /etc/default/grubcat /etc/default/grub GRUB_TIMEOUT="15" # Original: GRUB_TIMEOUT=5 GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)" # Original: Identical GRUB_DEFAULT="saved" # Original: Identical GRUB_DISABLE_SUBMENU="true" # Original: Unknown GRUB_TERMINAL_OUTPUT="gfxterm" # Original: GRUB_TERMINAL_OUTPUT="console" GRUB_CMDLINE_LINUX="" # Original: GRUB_CMDLINE_LINUX="rhgb quiet" GRUB_DISABLE_RECOVERY="false" # Original: GRUB_DISABLE_RECOVERY="true" GRUB_ENABLE_BLSCFG="true" # Original: Unknown # Reason: https://discussion.fedoraproject.org/t/missing-boot-entries-with-grub-enable-blscfg-true/70805/3 GRUB_GFXMODE="2560x1440,auto" # Original: None GRUB_DISABLE_OS_PROBER="true" # Original: None # Reason: https://github.com/MaddieM4/os-prober/issues/5#issue-777438588GRUB_TIMEOUT=25 GRUB_DISTRIBUTOR="$(sed 's, release .*$,,g' /etc/system-release)" GRUB_DEFAULT=saved GRUB_DISABLE_SUBMENU=true GRUB_TERMINAL_OUTPUT="gfxterm" GRUB_CMDLINE_LINUX="" GRUB_DISABLE_RECOVERY="false" GRUB_ENABLE_BLSCFG=true GRUB_GFXMODE=2560x1440,autosudo fdisk -l /dev/nvme2n1Disk /dev/nvme2n1: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors Disk model: addlink M.2 PCIE G4x4 NVMe Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: BDA1D2E0-E95A-4EB7-9502-BE9E43D64E3D Device Start End Sectors Size Type /dev/nvme2n1p1 2048 3907022847 3907020800 1.8T Linux filesystemDisk /dev/nvme2n1: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors Disk model: addlink M.2 PCIE G4x4 NVMe Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: gpt Disk identifier: 95F62691-D093-4072-8970-7D9108C0A5EE Device Start End Sectors Size Type /dev/nvme2n1p1 2048 206847 204800 100M EFI System /dev/nvme2n1p2 206848 239615 32768 16M Microsoft reserved /dev/nvme2n1p3 239616 3905492991 3905253376 1.8T Microsoft basic data /dev/nvme2n1p4 3905492992 3907026943 1533952 749M Windows recovery environmentsudo grub2-emu至少你们都知道它对我来说没有出现。我不认为
grub2-emu曾经有效过,因为我在浏览器历史记录中有一条关于此问题的搜索记录,时间是 2025-01。注意到“Windows Boot Manager”了吗?!
