I noticed all the new posts published in the blog after the installation and activation of wp-discourse plugin, have a 404 header.
Last post with a normal 200 header -> https://denki.es/136/mercedes-benz-prueba-sus-camiones-electricos-dejandoselos-gratis-a-20-clientes-durante-un-ano
Next post, already has a 404 header -> El primer coche eléctrico que participó en un Rally Dakar lo condujo un español en Denki (you can also check the header information here: https://securityheaders.io/?q=https%3A%2F%2Fdenki.es%2F217%2Fcomo-abrir-el-maletero-de-un-tesla-model-s-o-model-x-sin-tener-la-llave&followRedirects=on )
If you check, the 404 header post is the first one using Discourse - hence the normal wordpress comments code is not being used.
I tried de-activating the wp-discourse plugin, the posts still use 404 header. Tried de-activating all plugins, the new posts still have a 404 header (even newly published test posts). Tried using Wordpress default theme, with all plugins de-activated or activated… in both situations, all new posts have 404 header. Previous posts keep 200 header. Also tried to use default options for permalinks, same result. Swtiched back to my fancy permalinks, again same result… all new posts use 404 header.
I publish this here because the only cue I have on this issue, is the date; all the 404 header posts started being published exactly the moment after the wp-discourse plugin was installed. It might not be related but it’d be too much of a coincidence. I didn’t install anything else. Please note I’m using the beta version compatible with php 5.3.3.
any ideas… ?
