Using the AI bot via the Discourse API
Overview
Discourse AI exposes an admin/API endpoint for streaming an AI Agent reply over a raw chunked HTTP response.
  • Protocol: Raw chunked HTTP transfer encoding (NOT Server-Sent Events).
  • Implementation: Hijacks the Rack socket to stream newline-separated JSON objects.
  • Side Effects: This is not just a completion API; it creates real Discourse Private Message (PM) posts.
Endpoint Details
  • Location: plugins/discourse-ai/app/controllers/discourse_ai/admin/ai_agents_controller.rb:175-272
  • Route: POST /admin/plugins/discourse-ai/ai-agents/stream-reply.json
  • API Key Scope: ai:stream_completion (registered in plugins/discourse-ai/lib/ai_bot/entry_point.rb:283-286)
Request Headers
Api-Key: <your_api_key>
Api-Username: <your_username>
Content-Type: application/json
Request Body Parameters
Parameter Type Required Description
agent_id Integer Optional* Identifier for the agent.
agent_name String Optional* Alternative identifier for the agent.
query String Yes The user’s prompt/question.
username String Required if user_unique_id is omitted Used in case the chat PM needs to be associated with an existing user.
user_unique_id String Required if username is omitted Identifies the end-user. Creates/reuses a staged user keyed by custom field ai-stream-conversation-unique-id.
preferred_username String Optional* Username for the user (if user_unique_id is not used).
topic_id Integer Optional Continue an existing PM conversation.
custom_instructions String Optional Appended into the agent prompt context.
Note: You must identify the end-user by either username (existing Discourse user) or user_unique_id.
Response Format
The server returns a 200 OK response with Transfer-Encoding: chunked. The stream consists of newline-separated JSON objects.
HTTP Headers
HTTP/1.1 200 OK
Content-Type: text/plain; charset=utf-8
Cache-Control: no-cache, no-store, must-revalidate
Connection: close
X-Accel-Buffering: no
X-Content-Type-Options: nosniff
Stream Payload Structure
  1. Context Chunk: Provides metadata (topic ID, bot user ID, agent ID).
  2. Partial Chunks: Contains the streamed text fragments.
Example Stream:
{"topic_id":42,"bot_user_id":7,"agent_id":123}
{"partial":"Hello"}
{"partial":" there"}
The client should concatenate partial fields to build the final answer.
Workflow & Side Effects
The endpoint performs the following actions during execution:
  1. Creates a user post with the raw query.
  2. Streams the AI answer via the chunked response.
  3. Creates the final AI reply post with the accumulated answer.
  4. For new PMs, may auto-title the topic.
Custom Client-Executed Tools
You can provide tool definitions to allow the model to call external tools. The server pauses the stream when a tool is called, allowing the client to execute the tool and resume.
1. Initial Request with Tools
Include custom_tools in the request body:
  "agent_id": 123,
  "query": "What's the weather?",
  "user_unique_id": "external-user-42",
  "custom_tools": [
      "name": "client_weather",
      "description": "Gets weather from the client runtime",
      "parameters": [
          "name": "city",
          "description": "City to fetch weather for",
          "type": "string",
          "required": true
2. Tool Call Event
If the model calls a tool, the stream emits a tool_calls event and stops:
  "event": "tool_calls",
  "tool_calls": [
      "id": "tool_1",
      "parameters": { "city": "Austin" }
  "resume_token": "..."
The server persists conversation state in Redis at this point.
3. Resume with Tool Results
The client executes the tool and resumes the stream:
  "resume_token": "...",
  "tool_results": [
      "tool_call_id": "tool_1",
      "content": { "temperature_c": 23 }
The server reloads the saved prompt state, inserts the tool result, continues generation, and streams more partial chunks.
Tool Limits
  • Max custom tools: 20
  • Max tool results: 20
  • Max custom tool definition size: 10,000 bytes
  • Max tool result content size: 100 KB
  • Resume TTL: 15 minutes
  • Max resume rounds: 10
Implementation References
  • Controller: plugins/discourse-ai/app/controllers/discourse_ai/admin/ai_agents_controller.rb
  • Streamer: plugins/discourse-ai/lib/ai_bot/response_http_streamer.rb
  • Custom Tools Session: plugins/discourse-ai/lib/ai_bot/stream_reply_custom_tools_session.rb
Test Examples
See plugins/discourse-ai/spec/requests/admin/ai_agents_controller_spec.rb for comprehensive examples:
  • New streamed conversation: Lines 1248-1356
  • Custom tools + resume token: Lines 1358-1448
  • Parallel tool calls: Lines 1467-1590
Sample implementation
Ruby Script
require 'net/http'
require 'json'
require 'uri'
# Configuration
DISCOURSE_URL = '<your site URL>'
API_KEY = '<your API key>'
USERNAME = '<your username>'
AGENT_ID = -1 # Or use agent_name
QUERY = "Hello, how are you today?"
USER_UNIQUE_ID ='leave empty if want the PM to be sent to the USERNAME user'
# Helper to create the URI
uri = URI("#{DISCOURSE_URL}/admin/plugins/discourse-ai/ai-agents/stream-reply.json")
# Create the HTTP request
request = Net::HTTP::Post.new(uri)
request['Api-Key'] = API_KEY
request['Api-Username'] = USERNAME
request['Content-Type'] = 'application/json'
# Prepare the request body
body = {
  agent_id: AGENT_ID,
  query: QUERY,
  ## uncomment the below line if you want to use an existing user for the conversation. Also, `username` takes precedence over `user_unique_id` if passed.
  # username: USERNAME,
  ## use the below field along with `user_unique_id` in order to create a new staged user. When using this, skip passing the `username`.
  # preferred_username: USER_UNIQUE_ID
body[:user_unique_id] = USER_UNIQUE_ID unless USER_UNIQUE_ID.empty?
body = body.to_json
request.body = body
http = Net::HTTP.new(uri.hostname, uri.port)
http.use_ssl = (uri.scheme == 'https')
http.request(request) do |response|
    # Check if the response is successful
    if response.code == '200'
    puts "Stream started successfully."
    puts "Response headers: #{response.to_hash}"
    puts "Streaming content:"
    # Read the chunked response
    response.read_body do |chunk|
        # The response is newline-separated JSON objects
        chunk.each_line do |line|
        line = line.strip
        next if line.empty?
        begin
            json = JSON.parse(line)
            if json['topic_id']
            puts "--- Context Received ---"
            puts "Topic ID: #{json['topic_id']}"
            puts "Bot User ID: #{json['bot_user_id']}"
            puts "Agent ID: #{json['agent_id']}"
            elsif json['partial']
            # Stream the partial content
            print json['partial']
            elsif json['event'] == 'tool_calls'
            puts "--- Tool Call Received ---"
            puts JSON.pretty_generate(json)
            # Here you would handle tool execution and resume
            # For this example, we just print it
            # puts "<new word>"
        rescue JSON::ParserError => e
            puts "Error parsing JSON: #{e.message}"
            puts "Raw line: #{line}"
    puts "--- Stream Finished ---"
    else
    puts "Error: #{response.code} #{response.message}"
    puts "Response body: #{response.body}"
Notes
  • If you want the conversation to be in the name of a new staged user, pass the unique_user_id and preferred_username as the new desired username and skip the username field.
  • If you want to converse using an existing user, pass that user’s username and skip the unique_user_id and preferred_username fields.
This document is version controlled - suggest changes on github.
2 curtidas
