502 bad gateway with clean rebuild and no plugins except discourse docker
Continuing the discussion from Can't rebuild, clang-11 is missing:
I was getting a failed rebuild when I had the lines for chatbot embeddings in the app.yml.
So I removed these lines in the hooks for building pgembedding and now the rebuild completes, but for some reason I’m getting a 502 bad gateway when I load the site.
I’ve tried removing all plugins except for Discourse Docker and again, rebuild completes but I’m getting the 502 bad gateway.
I tried ./launcher cleanup and still, rebuild completes but 502 bad gateway.
Any ideas what’s happening?
Update:
I noticed in the logs that it seemed to have trouble connecting to 127.0.0.1:3000 so I did ./launcher enter app and tried the following:
And I got this:
*   Trying 127.0.0.1:3000...
* connect to 127.0.0.1 port 3000 failed: Connection refused
*   Trying ::1:3000...
* Immediate connect fail for ::1: Cannot assign requested address
* Failed to connect to localhost port 3000: Connection refused
* Closing connection 0
curl: (7) Failed to connect to localhost port 3000: Connection refused
I imagine this is causing the problem, but not sure why the server can’t connect to port 3000.
Any ideas?
The Rails server hasn’t come up for some reason.
That’s why there is nothing on port 3000.
Check why with this (and share):
/var/discourse/shared/standalone/log/rails# tail production.log
(or if you need more, say: /var/discourse/shared/standalone/log/rails# tail -n 200 production.log)
Here are the results of that command:
Summary
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:356:in `logging'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:268:in `process'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:175:in `block in call_loop'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:331:in `with_socket_timeout'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:174:in `call_loop'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/subscribe.rb:44:in `subscription'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/subscribe.rb:14:in `subscribe'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis.rb:288:in `_subscription'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/commands/pubsub.rb:20:in `block in subscribe'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis.rb:265:in `block in synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis.rb:265:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/commands/pubsub.rb:19:in `subscribe'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/message_bus-4.3.8/lib/message_bus/backends/redis.rb:291:in `global_subscribe'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/message_bus-4.3.8/lib/message_bus.rb:768:in `global_subscribe_thread'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/message_bus-4.3.8/lib/message_bus.rb:739:in `block in new_subscriber_thread'
/var/www/discourse/plugins/discourse-chat-matrix/gems/3.2.2/gems/logging-2.3.1/lib/logging/diagnostic_context.rb:474:in `block in create_with_logging_context'
Deprecation notice: Array types for custom fields are deprecated, use type :json instead (removal in Discourse 3.3.0)
At /var/www/discourse/lib/plugin/instance.rb:573:in `block in register_topic_custom_field_type`
At /var/www/discourse/lib/plugin/instance.rb:594:in `block in register_user_custom_field_type`
At /var/www/discourse/lib/plugin/instance.rb:580:in `block in register_post_custom_field_type`
Deprecation notice: add_to_serializer should not be used to directly override include_*? methods. Use the include_condition keyword argument instead
At /var/www/discourse/plugins/discourse-custom-wizard/plugin.rb:187:in `block in activate!`
At /var/www/discourse/plugins/discourse-custom-wizard/plugin.rb:197:in `block in activate!`
At /var/www/discourse/lib/plugin/instance.rb:566:in `block in register_category_custom_field_type`
At /var/www/discourse/plugins/pm-auto-responder-for-admins/plugin.rb:16:in `block in activate!`
Error connecting to Redis on localhost:6379 (Errno::EADDRNOTAVAIL) subscribe failed, reconnecting in 1 second. Call stack /var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:398:in `rescue in establish_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:379:in `establish_connection'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:115:in `block in connect'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:344:in `with_reconnect'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:114:in `connect'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:409:in `ensure_connected'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:269:in `block in process'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/client.rb:161:in `call'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/rack-mini-profiler-3.3.0/lib/mini_profiler/profiling_methods.rb:89:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis.rb:270:in `block in send_command'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis.rb:269:in `synchronize'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis.rb:269:in `send_command'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/redis-4.8.1/lib/redis/commands/strings.rb:191:in `get'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/message_bus-4.3.8/lib/message_bus/backends/redis.rb:388:in `process_global_backlog'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/message_bus-4.3.8/lib/message_bus/backends/redis.rb:277:in `block in global_subscribe'
/var/www/discourse/vendor/bundle/ruby/3.2.0/gems/message_bus-4.3.8/lib/message_bus/backends/redis.rb:289:in `global_subscribe'
  Rendered layouts/email_template.html.erb (Duration: 8.3ms | Allocations: 607)
Seems it’s also not connecting to redis on localhost:6379?
Update:
It seems to have the same symptoms as your issue here:
But your solution:
doesn’t work for me as I only have the Discourse Docker plugin enabled.
Sorry, very tied up atm.
Could you try to restart the container and immediately after perform that command?
It’s OK, I’m just glad you’re helping at all as I can imagine you have a lot of different projects you’re juggling.
I did ./launcher restart app and then did /var/discourse/shared/standalone/log/rails# tail -n 200 production.log and I’m pretty sure I got almost the same output:
Output of tail -n 200 production.log
@jimkleiber Jim, I don’t believe tells us a lot unfortunately.
Very strange.
Can you try to bring up a fresh VPS with a backup? … that might expedite a resolution.
