In a thread titled “502 bad gateway” under the Installation category, stokedcrf reported encountering a 502 error after a possible Discourse update, despite running ./launcher rebuild app and ./discourse-setup, both of which failed. Seeking help, stokedcrf shared a log snippet showing a failure during db:migrate, with PostgreSQL shutting down unexpectedly. JammyDodger encouraged sharing full logs to diagnose the issue, while Firepup650 advised reviewing earlier error messages in the log. Ultimately, stokedcrf resolved the problem by performing a fresh install and restoring from a backup, confirming everything is now working. The thread highlights common troubleshooting steps for Docker-based Discourse installations encountering database migration or bootstrapping failures.
About a week ago my installation of Discourse may have updated. I’m not 100% sure, but all I know is whenever I would visit the site I’d get a 502 error issued by nginx.
This was your typical docker install.
I have since went in and ran “./launcher rebuild app” and it seemed to error out.
I then ran “./discourse-setup” and it errored out as well.
I’m no pro though and fairly new to discourse so I can post the results of the rebuild here if required.
After about a week of searching around and trying to find fix, I may just go ahead and do a complete fresh install on the VPS. That said, I’m not sure how to backup and restore the user accounts and databases.
Any advice would be amazing!
Thank you for your time!
While the rebuild log seems quite long, it seems this is around when it fails:
Tasks: TOP => db:migrate => db:load_config => environment
I, [2024-01-29T18:40:10.599024 #1] INFO -- :
I, [2024-01-29T18:40:10.627958 #1] INFO -- : Terminating async processes
I, [2024-01-29T18:40:10.629723 #1] INFO -- : Sending INT to HOME=/var/lib/postgresql USER=postgres exec chpst -u postgres:postgres:ssl-cert -U postgres:postgres:ssl-cert /usr/lib/postgresql/13/bin/postmaster -D /etc/postgresql/13/main pid: 42
2024-01-29 18:40:10.630 UTC [42] LOG: received fast shutdown request
2024-01-29 18:40:10.644 UTC [42] LOG: aborting any active transactions
2024-01-29 18:40:10.651 UTC [42] LOG: background worker "logical replication launcher" (PID 51) exited with exit code 1
2024-01-29 18:40:10.654 UTC [46] LOG: shutting down
2024-01-29 18:40:10.811 UTC [42] LOG: database system is shut down
FAILED
Pups::ExecError: cd /var/www/discourse && su discourse -c 'bundle exec rake db:migrate' failed with return #<Process::Status: pid 3290 exit 1>
Location of failure: /usr/local/lib/ruby/gems/3.2.0/gems/pups-1.2.1/lib/pups/exec_command.rb:132:in `spawn'
exec failed with the params {"cd"=>"$home", "hook"=>"db_migrate", "cmd"=>["su discourse -c 'bundle exec rake db:migrate'"]}
963d90233930c09a993e084bf1e858d7486ddb797bd5743e6073f4563db0777a
