"Last Seen" User Card
tshenry introduced the “Last Seen” User Card theme component, enabling the display of user activity timestamps on profile cards. The tool, inspired by community requests, allows administrators to quickly assess member engagement without visiting full profiles. McBlu praised its utility for tracking new members. Following a poll, tshenry moved the “Last Seen” metadata to the first position in the card. Anatolia reported issues on mobile, prompting tshenry to release an update adding mobile support. Users like jrgong and rahim123 suggested integrating this feature into Discourse core. Roi noted a styling issue where the text appeared bold and large due to an <h3> tag; awesomerobot submitted a pull request to fix this. Later, Zomb experienced positioning issues after an update, which Don resolved with custom CSS, though Zomb ultimately fixed it by rebuilding the site. A subsequent update by tshenry caused the component to break for users on v3.4.6 and v3.5.0.beta5. tshenry released a compatibility fix to support older core versions, which rahim123 confirmed resolved the issue. Most recently, Denis_Advert reported a minor element indentation error.
This theme component will allow you to include the “last seen” user statistic in user profile cards.
Repo: GitHub - tshenry/discourse-last-seen-user-card-theme-component
Before
After
About
In addition to my own interest in having this stat added to user cards, there’s been some discussion on here that inspired this theme component’s creation:
Installation
Follow this guide here:
Please feel free to post if there are any questions, problems, or suggestions!
This is fantastic. I will use this function a lot as I assess new members’ engagement and chase particular people down who I work with closely.
This has had a minor update:
  • Reduced the amount of code by switching from a full template override to using the existing plugin outlet to achieve the same positioning.
For anyone that uses this or is interested in using it, there are four metadata positions on the user card. Currently, starting from the left it goes last post, date joined, last seen, and time read. Which position would you prefer the "last seen" metadata to be displayed?
  • First
  • Second
  • Third (where it is currently)
  • Fourth
0 voters
I imagine it’s not extremely important to most, but I’m curious if there is a preference that I can consider for a future update.
I don’t mind where it is so long as it is there.
I’ve update this to position “Last Seen” first in the list. Thanks to all that voiced their opinion :grin:
@tshenry Is it compatible with latest Discourse? It’s not working although installed.
I just checked and it’s working on the latest tests-passed. Did you make sure to refresh the page after adding the component to your main theme?
Did you check on mobile view as well?
Ah, good point! Fun fact - this component was created before mobile user cards existed! Because of that, it was only set up to work on desktop.
I’ve just pushed an update that should support both environments:
https://github.com/tshenry/discourse-last-seen-user-card-theme-component/commit/fdbdb65320d18ac3b466fb3c81e902add7499e0b
I’ve got the update, thanks.
Reviving this one: Just to confirm that it still works like a charm and is super useful!
This makes it super quick easy to check if the user is in fact still an active member. Before I always had to open full profile to decide if it’s worth the time so send a private message to the user.
Would love to see that in core!
Yes!! Should definitely be in core IMO. Until then thanks very much to @tshenry!
I noticed since my last Discourse update that the Last Seen text in the user card is much bigger than the rest and also bold. I checked and it is wrapped in <h3> so I undid this by putting
#user-card .last-seen-metadata h3 {
    font-size: unset;
    font-weight: unset;
in the theme css.
No idea if this is an intended effect, so I wanted to share my experience.
Probably not.
I’ve added a pull request for the component here to remove the heading tag to match the Discourse change:
https://github.com/tshenry/discourse-last-seen-user-card-theme-component/pull/2
Thank you very much for explanation and also for the PR! :slight_smile:
Thanks very much for this fix! Will it make it into the 3.3.x stable branch?
Theme component updates are completely separate from core updates, you can update them at any time from the admin UI regardless of the core updates.
Oops, sorry, I forgot that this is a theme component and not part of core.
Works great, but for some reason it’s showing last in the list (after cheers) for me.
