Publicando un nuevo tema vía API
Hola,
Parece que no puedo hacer que la publicación funcione y, lamentablemente, no he encontrado mucha información ni en la documentación de la API ni en el foro.
¿Qué tipo de codificación o limpieza (si es necesaria) debo realizar para los campos de título y cuerpo sin procesar de la publicación? Estoy obteniendo extrañamente un error 404 al publicar en /posts.json con los campos {api_username, api_key, title, raw, created_at, archetype, skip_validations} usando el encabezado form-data (lo estoy intentando con Python, pero Postman da el mismo resultado). ¿Alguna pista sobre qué estoy haciendo mal?
Standard www-form encoding is all. Make sure you’re sending either (api_username, api_key) or (Cookie, X-CSRF-Token).
But am I supposed to receive 404 in any case? I do include api_username and api _key in the form…
Update: if I send the same request under admin user / master api_key it goes through, but I get 404 if I submit under another user but still with master api_key, bug or my mistake?
Can you provide more info and maybe a code snippet of your posting attempt?
Hello - I don’t want to create a new topic because I seem to be having the exact same issue; I’m using the latest discourse_api gem, and I have generated a master API key; I’m creating posts on behalf of existing users (fetching content they put elsewhere).
A normal call
c.create_topic category: category, title: new_title,
                   raw: new_content, api_username: username
Works on some users, and not on others; I get a {"status"=>404, "error"=>"Not Found"} response.
Only differences I can tell are:
  • The user for whom I can create is in staff (others aren’t)
  • The user for whom I can create has a user name identical to the name, and is lowercase (others don’t and aren’t)
Furthermore, if I go to the web interface, create the post, and transfer ownership, it works. So far I’m letting the automaton do its job with the ones that can be created, and give me the text to manually create the ones that can’t. But at over 1000 posts that won’t be created automatically, I despair a little :sweat_smile:
EDIT: verified name situation is not the issue… It may be related to the staff thing.
EDITEDIT: I worked around this by creating in a user’s name, then changing ownership to another user. The mere fact that this is possible on the same API key makes me lean towards the 404 behavior being a bug.
¿Ya lo resolviste?
Cómo enviar una imagen en la API de crear publicación. Porque en la documentación, en la solicitud de la API, no hay ninguna clave mencionada para la imagen.
https://docs.discourse.org/#tag/Posts/operation/createTopicPostPM
  "title": "string",
  "raw": "string",
  "topic_id": 0,
  "category": 0,
  "target_recipients": "blake,sam",
  "target_usernames": "string",
  "archetype": "private_message",
  "created_at": "string",
  "reply_to_post_number": 0,
  "embed_url": "string",
  "external_id": "string"
Debes usar el endpoint uploads: https://docs.discourse.org/#tag/Uploads
Luego, usa el valor short_url devuelto para insertarlo en tu publicación.
