About the Theme category
Themes are expansive customizations that change multiple elements of the style of your forum design, and often also include additional front-end features.
Larger and more encompassing than theme components, themes have the ability to significantly change the look and layout of your forum.
Depending on which elements are already included in a theme, it is also possible to combine other theme components with them to further individualize your site.
You can find more info on how to use, create, and share your own themes in:
Installing a theme or theme component
Beginner's guide to using Discourse Themes
Designer's Guide to getting started with themes in Discourse
Developing Discourse Themes & Theme Components
Only @theme_authors can create topics in this category, but if you’ve already developed a theme that you’d like to share, click on @theme_authors and request to join. Then we can add you to the group and you’ll be able to post your themes here. :slight_smile: :+1:
