I received this error in the error log.
I am running 2.6.0.beta2
The IPSpoofAttack text certainly is disconcerting but I can’t tell how serious this is.
Here are the info/backtrace/env
ActionDispatch::RemoteIp::IpSpoofAttackError (IP spoofing attack?! HTTP_CLIENT_IP="10.32.59.37" HTTP_X_FORWARDED_FOR="64.125.105.232")
app/controllers/topics_controller.rb:980:in `track_visit_to_topic'
app/controllers/topics_controller.rb:140:in `show'
app/controllers/application_controller.rb:340:in `block in with_resolved_locale'
app/controllers/application_controller.rb:340:in `with_resolved_locale'
lib/middleware/omniauth_bypass_middleware.rb:68:in `call'
lib/middleware/anonymous_cache.rb:334:in `call'
config/initializers/100-quiet_logger.rb:19:in `call'
config/initializers/100-silence_logger.rb:31:in `call'
lib/middleware/enforce_hostname.rb:22:in `call'
lib/middleware/request_tracker.rb:176:in `call'
backtrace:
actionpack (6.0.3.2) lib/action_dispatch/middleware/remote_ip.rb:136:in `calculate_ip'
actionpack (6.0.3.2) lib/action_dispatch/middleware/remote_ip.rb:155:in `to_s'
actionpack (6.0.3.2) lib/action_dispatch/http/request.rb:287:in `remote_ip'
actionpack (6.0.3.2) lib/action_controller/metal/basic_implicit_render.rb:6:in `send_action'
actionpack (6.0.3.2) lib/abstract_controller/base.rb:195:in `process_action'
actionpack (6.0.3.2) lib/action_controller/metal/rendering.rb:30:in `process_action'
actionpack (6.0.3.2) lib/abstract_controller/callbacks.rb:42:in `block in process_action'
activesupport (6.0.3.2) lib/active_support/callbacks.rb:112:in `block in run_callbacks'
i18n (1.8.5) lib/i18n.rb:313:in `with_locale'
activesupport (6.0.3.2) lib/active_support/callbacks.rb:121:in `block in run_callbacks'
activesupport (6.0.3.2) lib/active_support/callbacks.rb:139:in `run_callbacks'
actionpack (6.0.3.2) lib/abstract_controller/callbacks.rb:41:in `process_action'
actionpack (6.0.3.2) lib/action_controller/metal/rescue.rb:22:in `process_action'
actionpack (6.0.3.2) lib/action_controller/metal/instrumentation.rb:33:in `block in process_action'
activesupport (6.0.3.2) lib/active_support/notifications.rb:180:in `block in instrument'
activesupport (6.0.3.2) lib/active_support/notifications/instrumenter.rb:24:in `instrument'
activesupport (6.0.3.2) lib/active_support/notifications.rb:180:in `instrument'
actionpack (6.0.3.2) lib/action_controller/metal/instrumentation.rb:32:in `process_action'
actionpack (6.0.3.2) lib/action_controller/metal/params_wrapper.rb:245:in `process_action'
activerecord (6.0.3.2) lib/active_record/railties/controller_runtime.rb:27:in `process_action'
actionpack (6.0.3.2) lib/abstract_controller/base.rb:136:in `process'
actionview (6.0.3.2) lib/action_view/rendering.rb:39:in `process'
rack-mini-profiler (2.0.4) lib/mini_profiler/profiling_methods.rb:78:in `block in profile_method'
actionpack (6.0.3.2) lib/action_controller/metal.rb:190:in `dispatch'
actionpack (6.0.3.2) lib/action_controller/metal.rb:254:in `dispatch'
actionpack (6.0.3.2) lib/action_dispatch/routing/route_set.rb:50:in `dispatch'
actionpack (6.0.3.2) lib/action_dispatch/routing/route_set.rb:33:in `serve'
actionpack (6.0.3.2) lib/action_dispatch/journey/router.rb:49:in `block in serve'
actionpack (6.0.3.2) lib/action_dispatch/journey/router.rb:32:in `each'
actionpack (6.0.3.2) lib/action_dispatch/journey/router.rb:32:in `serve'
actionpack (6.0.3.2) lib/action_dispatch/routing/route_set.rb:834:in `call'
rack (2.2.3) lib/rack/tempfile_reaper.rb:15:in `call'
rack (2.2.3) lib/rack/conditional_get.rb:27:in `call'
rack (2.2.3) lib/rack/head.rb:12:in `call'
rack (2.2.3) lib/rack/session/abstract/id.rb:266:in `context'
rack (2.2.3) lib/rack/session/abstract/id.rb:260:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/cookies.rb:648:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/callbacks.rb:27:in `block in call'
activesupport (6.0.3.2) lib/active_support/callbacks.rb:101:in `run_callbacks'
actionpack (6.0.3.2) lib/action_dispatch/middleware/callbacks.rb:26:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/actionable_exceptions.rb:17:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/debug_exceptions.rb:32:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/show_exceptions.rb:33:in `call'
logster (2.9.3) lib/logster/middleware/reporter.rb:43:in `call'
railties (6.0.3.2) lib/rails/rack/logger.rb:37:in `call_app'
railties (6.0.3.2) lib/rails/rack/logger.rb:28:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/remote_ip.rb:81:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/request_id.rb:27:in `call'
rack (2.2.3) lib/rack/method_override.rb:24:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/executor.rb:14:in `call'
rack (2.2.3) lib/rack/sendfile.rb:110:in `call'
actionpack (6.0.3.2) lib/action_dispatch/middleware/host_authorization.rb:76:in `call'
rack-mini-profiler (2.0.4) lib/mini_profiler/profiler.rb:200:in `call'
message_bus (3.3.1) lib/message_bus/rack/middleware.rb:61:in `call'
railties (6.0.3.2) lib/rails/engine.rb:527:in `call'
railties (6.0.3.2) lib/rails/railtie.rb:190:in `public_send'
railties (6.0.3.2) lib/rails/railtie.rb:190:in `method_missing'
rack (2.2.3) lib/rack/urlmap.rb:74:in `block in call'
rack (2.2.3) lib/rack/urlmap.rb:58:in `each'
rack (2.2.3) lib/rack/urlmap.rb:58:in `call'
unicorn (5.6.0) lib/unicorn/http_server.rb:632:in `process_client'
unicorn (5.6.0) lib/unicorn/http_server.rb:728:in `worker_loop'
unicorn (5.6.0) lib/unicorn/http_server.rb:548:in `spawn_missing_workers'
unicorn (5.6.0) lib/unicorn/http_server.rb:144:in `start'
unicorn (5.6.0) bin/unicorn:128:in `<top (required)>'
vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `load'
vendor/bundle/ruby/2.6.0/bin/unicorn:23:in `<main>'
env
| hostname | forums-web-only |
| process_id | 30025 |
| application_version | b6dd3eca9a2785f02f4368447b1fbfc95b9a03e0 |
| HTTP_HOST | forums.paddling.com |
| REQUEST_URI | /t/4-dr-honda-civic-kayak-transportation/24997 |
| REQUEST_METHOD | GET |
| HTTP_USER_AGENT | Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/84.0.4147.135 Safari/537.36 |
| HTTP_ACCEPT | text/html,application/xhtml+xml,application/xml;q=0.9,image/webp,image/apng,/;q=0.8,application/signed-exchange;v=b3;q=0.9 |
| HTTP_REFERER | https://www.google.com/ |
| HTTP_X_FORWARDED_FOR | 64.125.105.232 |
| HTTP_X_REAL_IP | 64.125.105.232 |
| time | 8:25 am |
