Added custom initializer
Just to be certain, I’ve added a custom initializer file to the initializers folder, will this be picked up when the app starts?
Cheers
Have a look at
thanks, i’ve already created the plugin per the guide but it’s not clear where the initializer file should go?
somewhere like this…
plugins/my-plugin/config/initializers/initializer.rb
or would the code just simply go in an after_initialize block in the plugin.rb file?
Basically, i create a site_setting with the plugin and then straight away i need to be able to use that setting
much appreciated
I suggest you look at the source code of one of our plugins such as discourse-tagging for further examples if it’s not clear from the guides.
Adding a site setting is covered in part 3 and no initializer is required.
