Aggiunta dell'intestazione CSP
I am trying to create a vary basic .rb plugin (based on the now obsolete in chrome) discourse-allowallwhich will merge the CSP header to the default ones but cant get it to work.
The below does not seem to do it.
Rails.application.config.action_dispatch.default_headers.merge!({'Content-Security-Policy' => "frame-ancestors 'http://mylocal.com.localhost'"})
I literally have 0 experience with ruby so need to know:
  1. If thats possible
  2. The correct syntax for defining the above header and merging it with the default ones
End goal is to make my discourse site frameable by 2 specific domains
My syntax was off and this is working fine now. Correct syntax is like:
Rails.application.config.action_dispatch.default_headers.merge!({'Content-Security-Policy' => "frame-ancestors mylocal.com.localhost"})
Il supporto per questa funzionalità è stato aggiunto nel core: Mitigate XSS Attacks with Content Security Policy - #37 by Falco
