Hey everyone! I’m trying to add custom HTML under the header outside of the main-outlet with the wrap class, as I want to avoid centering it to the middle.
Figma has something similar (Example)
Hi @AmericanGuy! ![]()
There’s an excellent theme component that let you see all the available outlets in which you can add custom HTML code:
After you have enabled the theme component in your theme, you can display or hide the outlets’ locations on your website by clicking the outlet icon next to the search icon: ![]()
You can see that there’s an outlet named “below-site-header” just below the header.
Now, you can put your custom HTML in this outlet by using this code in the Head tab of your theme or component:
<script type="text/x-handlebars" data-template-name="/connectors/below-site-header/my-custom-element">
test
</script>
(replace my-custom-element with a unique and more descriptive one)
Here’s how it will look (look at the top left of the image):
You can read more about outlets here: Developing Discourse Themes & Theme Components ![]()
