Adding post count to user card
Hi there, I know that Discourse doesn’t emphasize a user’s post count and instead focuses on reading time. But for my large migrated traditional forum userbase, post count is an important metric. It would be good to have the total post count (topics + replies) displayed in the popup user card instead of needing to go into the user’s summary page.
I’m trying to use this as a model, which does work to show the user’s “last seen” time:
https://github.com/tshenry/discourse-last-seen-user-card-theme-component/blob/main/common/head_tag.html
But my version doesn’t work (I’m initially attempting to just show the the replies count):
Attempt 1:
<script type="text/x-handlebars" data-template-name="/connectors/user-card-metadata/post-count-metadata">
    {{#if user.summary.post_count}}
        <h3><span class='desc'>Count:</span> {{user.summary.post_count}}</h3>
    {{/if}}
</script>
Attempt 2:
    {{#if user.post_count}}
        <h3><span class='desc'>Count:</span> {{user.post_count}}</h3>
    {{/if}}
</script>
Attempt 3:
    {{#if user.stats.post_count}}
        <h3><span class='desc'>Count:</span> {{user.stats.post_count}}</h3>
    {{/if}}
</script>
It appears that the user stats model isn’t loaded for for that handlebar location and I don’t know how to access it. I found this:
And this:
Would I have to create a discourse-plugin script to access it and then create an HTML widget with api.createWidget ? Or is there an easier method to just use handlebars?
