Ruoli di Admin e Moderatore definiti in database esterno
Is there a way we can define admin roles & moderator roles outside the discourse.?
As like configuration in azure AD and while logging in using Oauth2, we can fetch the roles and show them as Admin, Moderator & User.?
Is there any feature related to that or some custom plugin.? OR We need to create that from scratch.?
Thanks for your help.! :slight_smile:
It is not currently possible using the OAuth2 plugin. A PR to add the functionality to the plugin would likely be accepted, or alternatively you could call the API from your main application to make the user a moderator/administrator.
Can you use sso instead of oauth?
I’ve been wanting to write a similar feature for some time. If / when I get around to it, I’ll happily feed it back.
