After initial setup of DigitalOcean droplet, get Refused to Connect error
AI 生成的摘要
Users are troubleshooting a “Refused to Connect” error after setting up Discourse on a DigitalOcean droplet. bolemk followed the official install guide but encountered the error when accessing the server via IP address. DeanMarkTaylor clarifies that the tutorial doesn’t include SSL setup and recommends using a domain name instead of an IP. lucasbasquerotto shares a related issue: exceeding Let’s Encrypt rate limits while repeatedly creating and destroying test servers, which caused certificate loading failures visible in ./launcher logs app. The error message indicated too many certificates issued for the same domain. Jack51 confirms this was their issue too and temporarily resolved it by commenting out SSL templates in the app config and rebuilding, planning to retry certificate issuance after the 7-day rate limit window.
I have followed the tutorial found below to set up discourse on a DigitalOcean Droplet.
discourse/docs/INSTALL-cloud.md at main · discourse/discourse · GitHub
But when I go the the corresponding IP address, I get
"""This site can’t be reached
192.241.***.*** refused to connect."""
What are the possible reasons for a refused to connect error? Could this be related to SSL certificates?
Thanks!
Ben
Those instructions don’t include SSL setup so unless you have done something extra - probably not an SSL issue.
The most common setup to complete is for a “domain name” not an IP address…
… I would suggest starting again following the instructions and using a domain name from a domain you control / own.
Just to point out something that happened to me. I used a testing server whose setup is entirely done by ansible, and after I use the site, I destroy it (ansible handles the destruction of the droplets, digital ocean spaces and so on, so that I’m not charged when not using).
What happened is that LetsEncrypt have rate limits, and my domain exceeded, so I started receiving the error that the page couldn’t be reached and it was a bit hard to track the reason to the rate limit of certificates (first I thought should be something about IPv6 or SSL + IPv6).
Running ./launcher logs app I saw a huge number of errors, basically saying:
nginx: [emerg] cannot load certificate "/shared/ssl/mydomain.com.cer": PEM_read_bio_X509_AUX() failed (SSL: error:0906D06C:PEM routines:PEM_read_bio:no start line:Expecting: TRUSTED CERTIFICATE)
lots and lots of times…
In the very beggining of the logs (thankfully the number of lines to be displayed in the terminal was not exceeded) there was the reason:
Create new order error. Le_OrderFinalize not found. {
  "type": "urn:ietf:params:acme:error:rateLimited",
  "detail": "Error creating new order :: too many certificates already issued for exact set of domains: mydomain.com: see https://letsencrypt.org/docs/rate-limits/",
  "status": 429
So for anyone that face it in the future, make sure to not exceed the rate limit (in my case, for these test sites that I create several times per week, I can just not use ssl to avoid this problem).
谢谢 Lucas,这帮了大忙。
通过注释掉应用配置文件中的两个 SSL 模板并重新构建“修复”了问题。仍需在 7 天后重新尝试获取新证书。
