Fehler bei KI-Übersetzungen
Ich habe eine Reihe dieser Einträge in den Logs bemerkt:
Message (2 copies reported)
DiscourseAi::Translation: Failed to translate post 120 to da: Validation failed: Raw can't be blank, Cooked can't be blank
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5/lib/active_record/validations.rb:87:in 'ActiveRecord::Validations#raise_validation_error'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5/lib/active_record/validations.rb:54:in 'ActiveRecord::Validations#save!'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5/lib/active_record/transactions.rb:365:in 'block in ActiveRecord::Transactions#save!'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activerecord-8.0.5/lib/active_record/transactions.rb:417:in 'block (2 levels) in ActiveRecord::Transactions#with_transaction_returning_status'
Backtrace
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.5/lib/active_support/broadcast_logger.rb:218:in 'block in ActiveSupport::BroadcastLogger#dispatch'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.5/lib/active_support/broadcast_logger.rb:217:in 'Array#map'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.5/lib/active_support/broadcast_logger.rb:217:in 'ActiveSupport::BroadcastLogger#dispatch'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/activesupport-8.0.5/lib/active_support/broadcast_logger.rb:129:in 'ActiveSupport::BroadcastLogger#warn'
/var/www/discourse/plugins/discourse-ai/lib/translation/verbose_logger.rb:8:in 'DiscourseAi::Translation::VerboseLogger.log'
/var/www/discourse/plugins/discourse-ai/app/jobs/regular/localize_posts.rb:48:in 'block in Jobs::LocalizePosts#execute'
/var/www/discourse/plugins/discourse-ai/app/jobs/regular/localize_posts.rb:29:in 'Array#each'
/var/www/discourse/plugins/discourse-ai/app/jobs/regular/localize_posts.rb:29:in 'Jobs::LocalizePosts#execute'
/var/www/discourse/app/jobs/base.rb:318:in 'block (2 levels) in Jobs::Base#perform'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/rails_multisite-7.0.0/lib/rails_multisite/connection_management/null_instance.rb:49:in 'RailsMultisite::ConnectionManagement::NullInstance#with_connection'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/rails_multisite-7.0.0/lib/rails_multisite/connection_management.rb:17:in 'RailsMultisite::ConnectionManagement.with_connection'
/var/www/discourse/app/jobs/base.rb:305:in 'block in Jobs::Base#perform'
/var/www/discourse/app/jobs/base.rb:301:in 'Array#each'
/var/www/discourse/app/jobs/base.rb:301:in 'Jobs::Base#perform'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:220:in 'Sidekiq::Processor#execute_job'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:185:in 'block (4 levels) in Sidekiq::Processor#process'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:180:in 'Sidekiq::Middleware::Chain#traverse'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:183:in 'block in Sidekiq::Middleware::Chain#traverse'
/var/www/discourse/lib/sidekiq/suppress_user_email_errors.rb:6:in 'Sidekiq::SuppressUserEmailErrors#call'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:182:in 'Sidekiq::Middleware::Chain#traverse'
/var/www/discourse/lib/sidekiq/discourse_event.rb:6:in 'Sidekiq::DiscourseEvent#call'
/var/www/discourse/lib/sidekiq/pausable.rb:131:in 'Sidekiq::Pausable#call'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/job/interrupt_handler.rb:9:in 'Sidekiq::Job::InterruptHandler#call'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/metrics/tracking.rb:26:in 'Sidekiq::Metrics::ExecutionTracker#track'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/metrics/tracking.rb:134:in 'Sidekiq::Metrics::Middleware#call'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/middleware/chain.rb:173:in 'Sidekiq::Middleware::Chain#invoke'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:184:in 'block (3 levels) in Sidekiq::Processor#process'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:145:in 'block (6 levels) in Sidekiq::Processor#dispatch'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/job_retry.rb:118:in 'Sidekiq::JobRetry#local'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:144:in 'block (5 levels) in Sidekiq::Processor#dispatch'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/config.rb:39:in 'block in <class:Config>'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:139:in 'block (4 levels) in Sidekiq::Processor#dispatch'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:281:in 'Sidekiq::Processor#stats'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:134:in 'block (3 levels) in Sidekiq::Processor#dispatch'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/job_logger.rb:15:in 'Sidekiq::JobLogger#call'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:133:in 'block (2 levels) in Sidekiq::Processor#dispatch'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/job_retry.rb:85:in 'Sidekiq::JobRetry#global'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:132:in 'block in Sidekiq::Processor#dispatch'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/job_logger.rb:40:in 'Sidekiq::JobLogger#prepare'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:131:in 'Sidekiq::Processor#dispatch'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:183:in 'block (2 levels) in Sidekiq::Processor#process'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:182:in 'Thread.handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:182:in 'block in Sidekiq::Processor#process'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:181:in 'Thread.handle_interrupt'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:181:in 'Sidekiq::Processor#process'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:86:in 'Sidekiq::Processor#process_one'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/processor.rb:76:in 'Sidekiq::Processor#run'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/component.rb:10:in 'Sidekiq::Component#watchdog'
/var/www/discourse/vendor/bundle/ruby/3.4.0/gems/sidekiq-7.3.10/lib/sidekiq/component.rb:19:in 'block in Sidekiq::Component#safe_thread'
Dann müssen Sie prüfen, was der Beitrag 120 enthält (einfach zu /p/120 navigieren) und dann nachschauen, welche Antwort das LLM gab, als es versucht hat, dies zu übersetzen (prüfen Sie die Tabelle ai_api_audit_logs).
1 „Gefällt mir“
Wenn ich die Audit-Logs mit dieser Abfrage durchsehe:
SELECT
  feature_name,
  created_at,
  post_id,
  response_tokens
FROM
  ai_api_audit_logs
WHERE
  post_id IS NOT NULL
  AND created_at > :start_date
  AND (response_tokens IS NULL OR response_tokens != 1)
ORDER BY
  created_at DESC
Enthalten die Ergebnisse für diesen Post um den im Log angegebenen Zeitstempel herum nichts.
Gibt es noch etwas anderes, das ich prüfen sollte?
Ja, Sie entfernen den gesamten response_tokens-Abschnitt aus der WHERE-Klausel.
Okay, zunächst habe ich mich vorher vertippt, es ist keine PM. Ich habe bemerkt, dass du /p/120 erwähnt hast, ich aber /t/120 verwendet habe.
/p/120 verweist auf https://discussion.mcebuddy2x.com/t/63/1
Danach habe ich die aktualisierte Abfrage auf der Tabelle ausgeführt, aber ich sehe keinen Eintrag zum Zeitstempel aus den Logs → Do 23:25 Uhr
Ich sehe nur diese Einträge in der Tabelle, die dem Zeitstempel am nächsten liegen:
feature_name created_at post response_tokens
translation 2026-05-07T23:26:15.471Z https://discussion.mcebuddy2x.com/t/5897/1 2423
translation 2026-05-07T23:11:23.504Z https://discussion.mcebuddy2x.com/t/5896/2 425
Keine der obigen Post-IDs entspricht der Post-ID im Fehlerprotokoll.
Die einzige Referenz auf diese Post-ID sehe ich viel später in den Logs
translation 2026-05-08T03:10:18.214Z https://discussion.mcebuddy2x.com/t/63/1 0
Antwort-Token sind für das Debugging unbrauchbar, Sie müssen die Rohantwort anzeigen.
Das Problem ist, dass ich keine Antwort mit demselben Zeitstempel wie im Log und der Post-ID sehe.
Der nächste Daten-Dump, den ich für diese Post-ID sehe, ist etwa eine Stunde später und enthält Folgendes:
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" given","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":".\n\n","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":"Probably","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" keep","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" truncated","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":"Now","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" produce","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" final","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" JSON","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" with","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" \"","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":"output","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":"\":","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" translation","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" string","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":"Make","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" sure","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" to","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" preserve","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" line","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" breaks","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" exactly","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" as","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" original","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":"Let's","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
data: {"id":"chatcmpl-35a85986-7a6b-4169-893a-b43bcc22b1f2","object":"chat.completion.chunk","created":1778209824,"model":"openai/gpt-oss-120b","system_fingerprint":"fp_d66938db44","choices":[{"index":0,"delta":{"reasoning":" construct","channel":"analysis"},"logprobs":null,"finish_reason":null}]}
event: error
data: {"error":{"message":"Failed to generate JSON. Please adjust your prompt. See 'failed_generation' for more details.","type":"invalid_request_error","code":"json_validate_failed","failed_generation":"max completion tokens reached before generating a valid document","status_code":400}}
event: error
data: {"error":{"message":"Fehler beim Generieren von JSON. Bitte passen Sie Ihren Prompt an. Weitere Details finden Sie unter 'failed_generation'.","type":"invalid_request_error","code":"json_validate_failed","failed_generation":"max completion tokens reached before generating a valid document","status_code":400}}
Die Reasoning-Token verbrauchen alle Token am max_tokens-Abschlusslimit. Ein weiterer Grund, warum wir Reasoning nicht für Übersetzungen verwenden.
Wir hatten eine Site-Einstellung, um damit umzugehen
Aber wir haben sie entfernt in
2 „Gefällt mir“
Danke für das Update. Ich habe für Übersetzungen auf ein nicht schlussfolgerndes 3B-Modell umgestellt. Mal sehen, wie es läuft.
Nach dem Wechsel zum Ollama 3.1 3B-Modell, das kein Reasoning verwendet, sehe ich nun einen völlig anderen Fehler:
DiscourseAi::Completions::Endpoints::OpenAi: status: 400 - body: {“error”:{“message”:“Dieses Modell unterstützt das Antwortformat json_schema nicht. Unterstützte Modelle finden Sie unter Structured Outputs - GroqDocs”}}
Ich bin etwas ratlos, wie ich weiter vorgehen soll. Welches Modell eignet sich für Übersetzungen in Discourse?
Du benötigst ein Modell mit Unterstützung für strukturierte Ausgaben, was im Grunde jedes kürzlich veröffentlichte SotA-Modell ist.
1 „Gefällt mir“
