That was it, my bad. I thought the padding was creating the margin on the left, but was definitely the cause. Thanks @awesomerobot.
Is there a way to allow users to select a theme without making it a public option? So only a person with the URL can use the theme?
A bit like how you can select the mobile view with:
http://discourse.org/?mobile_view=1 (switch off with this)
Thanks for posting this.
I used your css for .logo-small, but deleted the padding-left. When I delete the padding I see the other theme’s small logo overlaid on the new theme’s small logo. Did you run into that same problem? Did you update this css?
Thanks, I wanted a dark theme for a long time but the bosses prefer light themes as they don’t code. This solves that.
Can I set the default template for each user group (trust level) separately?
