Alter order of columns in topic list?
The discussion is about altering the order of columns in the topic list. Pirat posted a screenshot of the desired design and asked how to achieve it. After some confusion, Drew_Warwick identified the differences between the default design and the screenshot: the topic metrics were moved.
Pirat clarified that they only want to change the order of the columns, specifically moving Replies, Views, and Activity to the left. Mittineague understood the goal and suggested that JavaScript might be needed, but wondered how Pirat achieved the desired layout in the browser’s dev tools.
Pirat revealed that they used the browser’s dev tools (F12) to move the columns manually. Mittineague asked for more details on the process, but Pirat didn’t think it was relevant. The conversation then turned to the possibility of creating a plugin to achieve the desired layout, with pfaffman suggesting that this would be the best approach. However, Pirat expressed uncertainty about how to create plugins.
How can I make such a design?
design Screenshot
That’s the default design isn’t it?
Yes, I have not changed anything
So what do you wish to do? What do you want to change?
What is shown in the screenshot
I’m confused man, that’s like endless information. Maybe start by playing with the colors in the settings?
I do not understand what you’re talking about
I need to replace the standard design on the one that you see in the screenshot
Ultimate is asking what the difference is between the default design and the screenshot.
So far I see:
  • Topic metrics moved
  • Font changed
Is there anything else?
I don’t understand either, I want to help you though.
You’re saying I don’t like the default design, I want to change it? I’m asking, what would you like to change it to?
the screenshot does not see?
Replies
Views
Activity
and all, nothing more is needed
I did not change the font, all standard
If I’m understanding, you want to change from this
<tr>
  <td>1</td>
  <td>2</td>
  <td>3</td>
  <td>4</td>
  <td>5</td>
  <td>6</td>
</tr>
to this
<tr>
  <td>4</td>
  <td>5</td>
  <td>6</td>
  <td>1</td>
  <td>2</td>
  <td>3</td>
</tr>
My first thought was that JavaScript would be needed.
You apparently managed to do something in your browsers dev tools to get the screenshot.
Do you remember what that was?
I’m legit trying to do this now. lol I don’t know much about CSS but I don’t think one can move the order of columns of a table using it… but if he did it in the screenshot, must be possible?
I did it manually using faerbag F12
Well, there is the idea
How can I do it?
How did you do it using Firebug?
Simply move each column separately
Does it matter?
and that if you make a dual repository which makes changes to the engine if from another git repository?
The best way is to make a plugin.
and there is a plugin that makes the plug-in?
I just do not know how to do plug-ins
