I’m still not sure what happened, but basically after updating today, I found my server went down.
| staff_user | action | subject | created_at | details | context |
| mofosyne | custom_staff | 2018-03-08 23:12:34 UTC | “from_version: b040e11 \n repository: /var/www/discourse” | ||
| mofosyne | custom_staff | 2018-03-08 08:54:32 UTC | “from_version: 7570b37 \n repository: /var/www/discourse/plugins/docker_manager” | ||
| mofosyne | grant_admin | xxxx | 2018-02-03 11:00:08 UTC | ||
| mofosyne | change_trust_level | xxxx | 2018-02-03 10:48:57 UTC | “old trust level: 1 \n new trust level: 4” | |
| mofosyne | change_site_setting | force_https | 2018-01-22 11:08:38 UTC | ||
| mofosyne | custom_staff | 2018-01-20 05:16:21 UTC | “from_version: 727a451 \n repository: /var/www/discourse” | ||
| mofosyne. | custom_staff | 2018-01-20 05:08:42 UTC | “from_version: 59ed646 \n repository: /var/www/discourse/plugins/docker_manager” | ||
| … etc … |
When I did ./launcher stop app and ./launcher start app it gave this error
root@DesigningOpenDemocracy:/var/discourse# ./launcher start app
starting up existing container
+ /usr/bin/docker start app
Error response from daemon: driver failed programming external connectivity on endpoint app (e99d36a67d2dd83c7f9dd0e0c60452e183306fc03c864c509d905161f8a5ba24): Error starting userland proxy: listen tcp 0.0.0.0:80: bind: address already in use
Error: failed to start containers: app
Solution is to shutdown apache2 then run ./launcher start app. This is weird as this server is only hosting this single website. Not sure why apache2 is getting in the way.
root@DesigningOpenDemocracy:~# lsof -n -i
COMMAND PID USER FD TYPE DEVICE SIZE/OFF NODE NAME
systemd-n 429 systemd-network 13u IPv4 14595 0t0 UDP 45.76.126.24:bootpc
systemd-r 513 systemd-resolve 11u IPv4 16035 0t0 UDP *:hostmon
systemd-r 513 systemd-resolve 12u IPv4 16036 0t0 TCP *:hostmon (LISTEN)
systemd-r 513 systemd-resolve 13u IPv6 16038 0t0 UDP *:hostmon
systemd-r 513 systemd-resolve 14u IPv6 16039 0t0 TCP *:hostmon (LISTEN)
systemd-r 513 systemd-resolve 17u IPv4 16042 0t0 UDP 127.0.0.53:domain
sshd 758 root 3u IPv4 17570 0t0 TCP *:ssh (LISTEN)
sshd 758 root 4u IPv6 17578 0t0 TCP *:ssh (LISTEN)
apache2 787 root 4u IPv6 17624 0t0 TCP *:http (LISTEN)
apache2 788 www-data 4u IPv6 17624 0t0 TCP *:http (LISTEN)
apache2 789 www-data 4u IPv6 17624 0t0 TCP *:http (LISTEN)
sshd 1042 root 3u IPv4 18435 0t0 TCP 45.76.126.24:ssh->118.127.104.26:60332 (ESTABLISHED)
root@DesigningOpenDemocracy:~# cd /var/discourse/
root@DesigningOpenDemocracy:/var/discourse# sudo ./launcher start app
Error response from daemon: driver failed programming external connectivity on endpoint app (c9e149a0b9d61fb37b39131f1cc3dda51607b74a39a634c3a2c89cb9e95e998c): Error starting userland proxy: listen tcp 0.0.0.0:80: bind: address already in use
root@DesigningOpenDemocracy:/var/discourse# /etc/init.d/apache2 stop
[ ok ] Stopping apache2 (via systemctl): apache2.service.
root@DesigningOpenDemocracy:/var/discourse# lsof -n -i
app
root@DesigningOpenDemocracy:/var/discourse# docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
a1695959c956 local_discourse/app "/sbin/boot" 24 minutes ago Up 10 seconds 0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp app
This may just be some server weirdness, but it would be good to hear if anyone else had the same issue today.
