كتل كود محاطة بـ AppleScript لم تعد تعمل في إصدار 1.5.x
After upgrading from 1.4.6 top 1.5.1, my AppleScript Fenced Code Blocks no longer display correctly:
tell application "Safari"
	if it is running then
	end if
end tell
AppleScript language is turned on for highlighting, and this used to display correctly, but now displays like a mangled mess:
Hopefully there is some switch or setting that has been messed up or not set automatically that I can correct this, otherwise large chunks of my site now display significantly differently from previously.
Have you tried using 3 backticks to close the code block instead of 4?
	end if
end tell
3 إعجابات
Thanks. Stupid error on my part - had me worried though.
I don’t suppose there is any way to search for other occurrences of four backticks?
You can use data explorer plugin for that
إعجابَين (2)
تم إغلاق هذا الموضوع تلقائيًا بعد 2976 يومًا. لم يعد الرد على هذا الموضوع مسموحًا به.
