Assets only available to SCSS not JS
Hello,
For the last week or so I’ve been styling a Discourse setup for a brand which includes fixed fonts, logos and icons.
To begin with I noticed that any assets I imported (place in assets folder and import under the assets object of about.json) became immediately available to use as a SCSS variable but took a minute or two to show up in settings.theme_uploads.
Now however, they don’t show up at all in settings.theme_uploads which means I can’t use them in my JavaScript. If I remove an asset it also stays in the settings object. The SCSS usage stays unaffected.
Help would be greatly appreciated.
Yeah, I’m a bit confused by this too.
At what point is it safe to use a reference like return settings.theme_uploads.blah in javascript if ever?
I’m getting “undefined” for settings.theme_uploads in my computed property (initially at least).
What’s the right pattern here?
The settings.theme_uploads data was added to javascript relatively recently (after the OP was written, I think). It should be reliable - we use it in our own themes/components. Can you explain in more details what issues you’re seeing?
Ah, I was missing the assets folder in my path to the asset, so the broken link had “optimised out” the asset no doubt:
  "name": "Cool Theme Component",
  "about_url": "",
  "component": true,
  "assets": {
    "background": "background.png"
should have been:
  "about_url": "",
  "component": true,
  "assets": {
    "background": "assets/background.png"
Doh!
FYI I’m reference this in Javascript in an Ember Component, e.g.:
  @computed
  backgroundImage() {
    return settings.theme_uploads.background;
That would raise an undefined error when the path is incorrect!
Thanks for listening! @david, sorry to waste your time.
@hakonbja did you solve your issue?
