Poging om de vertraging van 10 minuten te omzeilen
Lee_Ars is integrating the wp-discourse plugin on a weather forecasting site with high traffic during severe weather events. They want to eliminate the 10-minute delay between posting comments and them appearing on the WordPress homepage. After experimenting with plugins to bypass caching issues, they found a solution but are concerned about potential security or performance implications. RGJ questions the correctness of the plugin code, suggesting a mix-up between WordPress post IDs and Discourse topic IDs. angus advises verifying the comment webhook setup and enabling verbose logging. Lee_Ars confirms the webhook is working but still experiences caching issues. Further discussion involves troubleshooting caching solutions, including disabling certain settings and examining server configurations. Eventually, Lee_Ars discovers the issue was due to a spurious cache-control header in their nginx configuration, resolving the problem.
I’m planning on using the wp-discourse plugin on a gulf coast weather forecasting site that typically services ~10-20k pageviews/day, but occasionally during severe weather events will push 1.5-2MM PV/day to approx 500-700k visitors. The site + its hosting strategy have been battle-tested through several severe weather events and things work great under pressure, primarily thanks to careful design and a lot of help from Cloudflare.
The site’s users are used to a low-friction commenting experience via native Wordpress comments, so there will be some adjustment (like getting them used tgo clicking the “Continue the discussion at…” link) that the user-facing staff is ready to manage.
However, what they won’t tolerate is the variable 10-minute delay between posting comments and them being shown on the daily Wordpress post’s page. They will want new comments (up to the configured limit) immediately on the homepage upon posting, similar to how native WP comments are displayed immediately after posting.
After screwing around with the built-in options to try to make posts show up immediately without nginx’s fastcgi caching, wordpress, or browser caching interfering with new comments appearing on refresh after they’re posted, the I have added the following two mu-plugins to mitigate this and cause newly posted comments to show up on the Wordpress side on refresh:
wp-discourse-transient-killer.php
wp-discourse-cache-header-fix.php
This has solved my problem: new posts to Wordpress-created Discourse threads now appear below the wordpress posts instantly on refresh.
But I’m kind of at the edge of my competence here — what am I breaking/screwing up/undermining by doing this?
I don’t particularly care about creating additional load on my webhost by having the comment endpoint being hammered by visitors checking the daily weather forecast page (with its embedded Discourse comments) — that is a problem I can solve by throwing money at it. My primary requirement is avoiding 20,000+ users sending me emails asking me why their comments aren’t appearing instantly on the homepage when they post them.
Is this the right approach? Is what I’m doing wise? Does it create additional security or performance issues I haven’t anticipated? Basically, am I screwing things up by doing this?
Thanks :slight_smile:
Hmm I’m confused why this works, because
And your plugin
add_action( 'wpdc_after_webhook_post_update', function( $topic_ids ) {
    foreach ( (array)$topic_ids as $topic_id ) {
        delete_transient( 'wpdc_comment_html_' . $topic_id );
}, 11 );
Aren’t you mixing up the (Wordpress) $post_ids passed to the action with the (Discourse) topic_id that serves as the transient key ?
I would expect your plugin to look like this
add_action( 'wpdc_after_webhook_post_update', function( $post_ids) {
    foreach ( (array)$post_ids as $post_id ) {
        $topic_id = get_post_meta( $post_id, 'discourse_topic_id', true );
}, 11 );
OTOH you’re saying this works? :thinking:
Hey @Lee_Ars, can you first confirm that you have the comments webhook setup?
That works like so:
  1. There’s a new post in Discourse.
  2. A webhook payload is sent to Wordpress.
  3. WP discourse updates the comment count on the post and also sets a post custom field wpdc_sync_post_comments.
  4. If wpdc_sync_post_comments is set Discourse comments will sync when a Wordpress post is loaded, regardless of the sync period (i.e. the 10 minute delay).
Before we get into caching, I just want to be sure that is in place first. If it is, perhaps also just turn on “Verbose Webhook Logs” and verify you’re receiving webhook requests when a new post is made in Discourse.
Hi Angus! That’s affirmative, the “Sync Comment Data” webhook option is enabled on the WP side, and I created the webhook on the Discourse side and pings are successful. The WP plugin’s logging shows comment.INFO: sync_comments.success messages at the right timestamps:
[2025-07-07 14:16:38] connection.INFO: check_connection_status.successful_connection
[2025-07-07 14:16:38] connection.INFO: check_connection_status.valid_scopes
[2025-07-07 20:11:31] comment.INFO: sync_comments.success {"post_id":786}
[2025-07-07 20:25:03] comment.INFO: sync_comments.success {"post_id":786}
[2025-07-07 20:32:14] comment.INFO: sync_comments.success {"post_id":786}
[2025-07-07 20:44:15] comment.INFO: sync_comments.success {"post_id":786}
[2025-07-07 21:00:39] comment.INFO: sync_comments.success {"post_id":786}
[2025-07-07 21:01:42] comment.INFO: sync_comments.success {"post_id":786}
[2025-07-07 21:15:40] comment.INFO: sync_comments.success {"post_id":786}
It’s just that even with those success messages, existing visitors (or at least me, multiply testing on firefox/safari/chrome on a mac, firefox/chrome/edge on a win10 PC, and safari on ios) keep getting a cached /wp-json/wp-discourse/v1/discourse-comments endpoint, with cache-control headers set to a nonzero amount. If I do a ctrl-shift-f5 on Chrome (or the equivalent in other browsers) to force it to bypass local cache on refresh, everything works great and the new posts appear.
With the mu-plugins in place, that endpoint shows cache-control set to no-store no-cache etc, and the problem behavior doesn’t manifest—simply visiting the WP post or refreshing it with the regular refresh button shows new embedded comments.
I’ve turned on verbose webhook logging and posted a test post, and things appear OK when I create a new post:
webhook_topic.INFO: update_topic_content.update_post_metadata_success {"post_ids":"786"}
Everything seems to be working, but I still don’t really understand why the original problem behavior manifested, or if it’s arisen from some overlooked issue on my end. (Very possible!)
D’oh, sorry, I’m sure you’re right about me screwing that up — yesterday was a long day, and like I said, I’m kind of at the limit of my abilities here. It was definitely doing something, though now I’m wondering if the “fixed” behavior I’m seeing is just it being broken in a new way. (I’ve updated the “transient killer” plugin to use the right argument now, thank you!)
Thanks, so just one more thing to clarify. Is this WP Discourse setting (in “Commenting”) on?
Ik heb beide geprobeerd met de instelling Cache Comment HTML ingeschakeld of uitgeschakeld en het lijkt geen invloed te hebben op het probleemgedrag. Ik heb het momenteel uitgeschakeld ingeschakeld (sorry, ik had het mis, het is momenteel ingeschakeld terwijl ik er nog mee bezig ben), maar ik kan het instellen op wat nuttig zou zijn voor probleemoplossing.
Als de instelling is uitgeschakeld, merkt u de verwarring tussen topic_id / post_id niet op, aangezien die plugin in dat geval niets doet. Geen caching –> het maakt niet uit of u de verkeerde cache verwijdert.
Als de instelling is ingeschakeld, zou u moeten merken dat de plugin niet goed werkt.
D.w.z. als u wilt troubleshooten, moet u de instelling inschakelen.
Ok, so as a first measure for your case I’d suggest:
  1. keep Cache Comment HTML disabled; and
  2. remove the https://www.bigdinosaur.org/r/wp-discourse-transient-killer.txt plugin as it’s currently not doing, anything as Richard observes.
If that does not resolve the problem then the problem is to do with another form of caching. The next questions to answer are:
  1. What caching solutions do you (and / or your hosting provider) use for Wordpress?
  2. If https://www.bigdinosaur.org/r/wp-discourse-cache-header-fix.txt fixes the issue, how does it’s specific behaviour invalidate whatever cache(s) are being applied in 1?
Looking at wp-discourse-cache-header-fix I see that one of the fixes is for load-comments.js. Do you have this setting enabled?
This is self-hosted WP on nginx+php-fpm 8.3 with nginx fast-cgi caching for dynamic content and Redis object caching (with the object cache drop-in active). There are no other layers (no CDN, no CF, no on-box Varnish or other local cache beyond nginx’s fast-cgi cache). Dumping the nginx fast cgi cache (aggressively, by going rm -rf /etc/nginx/cache/*) has no effect on the problem behavior — stale results are served even after nuking the cache directory and restarting both nginx and php-fpm.
I do indeed have the Ajax comment loading enabled right now, yes, but again, toggling it off (and dumping nginx’s cache plus restarting nginx and php-fpm just in case) had no effect on the problem behavior. Browsers still got stale comments.
Option toggled, transient-killer removed. No change in problem behavior.
The effect it applies appears to be supplying a no-cache cache-control header instead of one with a cache time specified. WIthout it in place, my browser seems to very much want to serve a stale cached version of the wp-json/wp-discourse/v1/discourse-comments endpoint from its disk cache; as noted, i have to shift-ctrl-f5 (or the equivalent) to force a no-cache refresh.
The problem behavior seems to be on the browser end, rather than in a persistent server cache. It’s just every browser on every OS that I have access to that’s doing it.
Ok, voor de volledigheid, als je hebt:
  • geverifieerde werkende commentaar webhook
  • Cache Comment HTML uit
  • AJAX Loading uit
  • geen cdn
  • geen cloudfront
  • geen wordpress caching plugin
  • geen relevante waarschuwingen of fouten in de php logs
ben je er zeker van dat het niet werkt?
Als het niet werkt met die setup, weet ik het niet meer zonder het nader te bekijken en zou standaard overschakelen naar:
  • AJAX loading aan
  • Jouw wp-discourse-cache-header-fix.php fixes
wat ik vermoed dat voor jou werkte. Als die route werkt, dan moet je daarvoor gaan.
Here’s a quick imgur gallery of screenshots of my current plugin settings, for reference.
Confirm no CDN, no Cloudfront or Cloudflare either one, no caching plugins aside from the Nginx helper (to help WP invalidate nginx fast-cgi cache as needed).
Also confirm nothing relevant in either the php-fpm or the nginx error logs.
God, dude, i wish it were. I’ve been banging my head on this for about 30 hours at this point, with some time off to sleep. I might be going a little crosseyed, heh.
Ja, ik snap het. Neem een dag of zo pauze. Ik zal proberen het probleem morgen na te bootsen door jouw setup te kopiëren.
Als ik me niet een weg naar een oplossing worstel, en als je wilt, geef ik morgen of de dag daarna graag tijdelijke lokale toegang (tot de WP-blog, de discourse en/of de onderliggende hosts) voor probleemoplossing. Ik probeer zeker geen gratis werk te krijgen of zo. Ik zou graag betalen voor uw diensten als er daadwerkelijk tijd te besteden is.
Ter referentie, zowel de host die Wordpress host als de host die Discord draait, zijn t3a.large EC2-instanties die AWS’ Ubuntu 24.04 AMI draaien; geïnstalleerde software is minimaal (nginx + php8 + fpm + redis op de webhost, en niets anders dan git + docker + discourse op de discoursehost). Dit is mijn persoonlijke blog en ik test hier de commentaarintegratie voordat ik deze in productie rol op de veel grotere WP-site die in de OP wordt genoemd. (Ik onderhoud die site ook en deze heeft een vergelijkbare tech-stack, hoewel deze wordt gefronted door Cloudflare. Die brug steek ik over als ik erbij kom!)
Als u meer details nodig heeft/wilt over de onderliggende stack, geef ik die graag.
Ok, here’s a video of me trying (and failing) to repro your issue:
The next thing I want you to try is this filter.
Thanks @angus — failing repro actually makes me feel a lot better, because that means I’m doing something wrong rather than there actually being something wrong :smiley:
I will get that filter added today when I have a block of time for troubleshooting and report back :+1:
Replying a month and change later to close the loop—I’m still experiencing some weirdness on deployment to full production (prod site, example prod site post w/discourse embed, actual discourse forum), but it’s all manageable. I’m going to chalk any remaining latency/delay issues to the complex layer cake that is Wordpress + Discourse + Cloudflare, and my aggressive caching strategy to keep all of these things operational during traffic storms that result from actual storms.
Thank you for taking the time to respond, @angus <3
Apologies for bumping this again, but wanted to follow up and report that I found the cause of the issue! And it was my own damn fault, as usual.
Very briefly, i keep common php location block details in a snippet under /etc/nginx/snippets/ so I can include them in multiple vhost files without having to duplicate them every time. It’s been a looooong time (years, probably) since I checked that snippet, and sure enough, there was a spurious add_header Cache-Control "public, max-age=7200"; in there, which was being applied to everything coming out of that location block.
So I ripped it out, flushed all the cache layers, and lo and behold, the problem behavior vanished.
Thanks again for taking the time to work with me, @angus, even though this ended up being yet again another Discourse problem of my own making :people_hugging:
