Avatar Size and Shape
The Avatar Size and Shape is an official Discourse theme component that allows administrators to customize avatar dimensions and border radius across their site. It offers settings for topic avatars (default 45px), header avatars (default 32px), header height, margin top, and border radius (default 50% for rounded). Mobile avatars can be adjusted between 45px–80px. A recent update added mobile avatar size control dax. Users have requested additional features, including flair size adjustment ariznaf, support for topic-poster avatars on category pages orchardstreet, and smaller mobile avatar sizes below 45px Kartoon, Olle11. Some users reported issues: avatar hover states in headers appear misaligned when resized Denis_Heraud, and conflicts with the Quick Messages plugin’s CSS jrgong. The component doesn’t alter site colors dax, but hover behavior may require manual CSS fixes. Developers are considering adding unique markup to header elements for better targeting Denis_Heraud. There’s also a noted inconsistency where medium and large settings on the /latest page both render as 48x48px manuel. The component is available for installation via GitHub and previewable in the Discourse Theme Creator. Support, bug reports, UX feedback, and feature requests can be submitted in tagged Meta categories.
:discourse2: Summary Avatar Size and Shape will allow you to easily change the size and shape of the avatars on your site.
:eyeglasses: Preview Preview on Discourse Theme Creator
:hammer_and_wrench: Repository Link https://github.com/discourse/discourse-avatar-component
:open_book: New to Discourse Themes? Beginner’s guide to using Discourse Themes
Install this theme component
Features
Avatar Size and Shape allows you to easily customise the size and shape of avatars on your site in a variety of different locations.
Settings
Name Description
latest avatar size Choose the avatar size on latest. Default value is small (25px). To see the changes applied, refresh the page with ctrl+F5 or cmd+shift+R.
topic avatars size Choose the avatar size on topics. Default value is 45px. To see the changes applied, refresh the page with ctrl+F5 or cmd+shift+R.
header avatars size Choose the avatar size on header. Default value is 32px. To see the changes applied, refresh the page with ctrl+F5 or cmd+shift+R.
header height Choose the height of the header. The choice must be made based on the header_avatars_size + 10px. For example, if the header_avatars_size is set to 90px, the header should be 100px. Default value is 60px.
margin top Choose the distance in px from the header. Default value is 0px.
avatars border radius Choose the border-radius of the avatars on the site. The setting will be applied to all avatars, including the one on the header and the one on the user-card. 0% corresponds to a square shape, 50% to a rounded shape. Default value at 50%
mobile avatars size Choose the avatar size on topics on Mobile. Min value is 45px (default), max value is 80px. To see the changes applied, refresh the page with ctrl+F5 or cmd+shift+R.
Extra details:
  • latest avatar size changes the avatar size on the /latest page. All the avatars will be visible up to the medium size. From large onwards, only the avatar of the last user who wrote on the topic will be displayed.
  • header avatar size works well up to the 60px size. For avatars of a larger size, the height of the header must be increased (header height) and consequently, the margin-top that distances the header from the other elements of the page must also increase (margin top).
The position (in height) of the notification bubble (topics and PMs) has remained unchanged. These bubbles will only move horizontally following the avatar size.
Development History
This theme component was written taking inspiration from the guides
:discourse2: Hosted by us? Theme components are available to use on our Standard, Business, and Enterprise plans.
How would I go about changing the size of the topic avatar on mobile with this? 80px looks pretty good on desktop, but obnoxious on mobile. I tried changing .topic-avatar width but it just shifts the text and the avatar stays the same.
Great component, we were looking for it.
But it would be great to change the avatar flair size too, if you are using them in your site (as we do).
Thank you.
very cool
wish I could set the topic avatar size to 53 though :frowning:
Also does this apply to avatars in the topic-poster div found on some front page category arrangments? It doesn’t seem to but it would be cool if it did.
Did you found a way of doing this?
@dax I found a small issue which collides with the Quick Messages plugin.
The following CSS comes targets the badge notification of the quick messages plugin as well:
.d-header-icons .unread-private-messages {
    right: auto;
    left: -10%; /* <--- this is the culprit*/
May be add some #… element to the CSS selector
Did you find a solution for the mobile version?
No, never found a way to do it unfortunately.
I will take a look this week if I have time
There is a new setting to configure the size on mobile from 45px (default) to 80px.
Update the component to see the new setting.
Thank you Daniela, I have one more suggestion. It would be great if there was an option to either leave the reply avatars on for large or extra_large so I can reduce the size via css. Or an option to reduce the size of the reply avatars in the plugin. I’m trying to achieve this, but of course the larger avatar is blurry from upsizing the medium size avatar.
Great plugin! Thank you!
@Dax Only problem I’m seeing right now is in the header which is a darker color. The hover is set to white which works fine on the search button and on the hamburger menu, but when the avatar is set to a slightly larger size, the size of the hover is smaller than the avatar. How would I go about fixing that?
This component does not change the colors of the site in any way, it must be some other theme that you are using to overwrite the background colors.
Great component.
It makes it easy to control the size and aspecto of your avatar without changing CSS of you theme (that may give problems upgrading the theme).
No, there is no change in colors.
We are using it and are happy with it.
@dax Maybe I did not explain myself very well. It’s not about the color, it’s about the size of the container. If you hover over your own avatar icon in the upper right corner of the page here on meta, you get a colored square with a :hover property, and the square is bigger than the avatar.
Screen Shot 2020-04-09 at 7.51.04 AM
However, if I enlarge the avatar with this plugin, the size of the :hover square is now smaller than the avatar and looks a little wonky.
By changing the height of that div, the other two icons must also be repositioned. For this reason I had preferred not to. For now I only make the color of the div on hover transparent.
https://github.com/discourse/discourse-avatar-component/commit/9715ce5077c542863499d00bf1820e3f873bf49b
Would it not be possible to simply target
.header-dropdown-toggle #current-user
with CSS?
No, it’s not so simple.
I will take a look in the next hours
I’m trying to achieve this in CSS but since all header icons use the same class:
<li class="header-dropdown-toggle">
it seems like they are either all on or all off. How were you able to just get the avatar one to not activate on :hover?
As a side note, I was able to get a pretty good looking effect in CSS in terms of having a :hover state on the avatar (white border). Now if I could just get the background of the li element to not highlight with the rest of it…
Screen Shot 2020-04-09 at 6.45.24 PM
Screen Shot 2020-04-09 at 6.44.16 PM
