Avatar generation with protocol independent URL
Hi all,
Not sure if anyone else is getting this at the moment. I upgraded my forum to v1.5.0.beta6 +188 and all the avatars coming from gravatar are broken. Error log is below. Have rebuilt the app and run rails console command for updating gravatars. The error log that I’m getting is below.
Any ideas for fix? I saw @sam has made a few commits in the last few hours for avatars. Feel free to tell me I’m an idiot if it is my fault.
Dan
/var/www/discourse/lib/file_helper.rb:10:in `download'
/var/www/discourse/app/controllers/user_avatars_controller.rb:127:in `proxy_avatar'
/var/www/discourse/app/controllers/user_avatars_controller.rb:105:in `show_in_site'
/var/www/discourse/app/controllers/user_avatars_controller.rb:66:in `block in show'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rails_multisite-1.0.3/lib/rails_multisite/connection_management.rb:44:in `with_hostname'
/var/www/discourse/app/controllers/user_avatars_controller.rb:65:in `show'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_controller/metal/implicit_render.rb:4:in `send_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/abstract_controller/base.rb:198:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_controller/metal/rendering.rb:10:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/abstract_controller/callbacks.rb:20:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:117:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:555:in `block (2 levels) in compile'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:505:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:92:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:778:in `_run_process_action_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:81:in `run_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/abstract_controller/callbacks.rb:19:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_controller/metal/rescue.rb:29:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_controller/metal/instrumentation.rb:32:in `block in process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/notifications.rb:164:in `block in instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/notifications/instrumenter.rb:20:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/notifications.rb:164:in `instrument'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_controller/metal/instrumentation.rb:30:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_controller/metal/params_wrapper.rb:250:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.4/lib/active_record/railties/controller_runtime.rb:18:in `process_action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/abstract_controller/base.rb:137:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionview-4.2.4/lib/action_view/rendering.rb:30:in `process'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.7/lib/mini_profiler/profiling_methods.rb:77:in `block in profile_method'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_controller/metal.rb:196:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_controller/metal/rack_delegation.rb:13:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_controller/metal.rb:237:in `block in action'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/routing/route_set.rb:76:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/routing/route_set.rb:76:in `dispatch'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/routing/route_set.rb:45:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/journey/router.rb:43:in `block in serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/journey/router.rb:30:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/journey/router.rb:30:in `serve'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/routing/route_set.rb:821:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-protection-1.5.3/lib/rack/protection/frame_options.rb:31:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:186:in `call!'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/strategy.rb:164:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/omniauth-1.2.2/lib/omniauth/builder.rb:59:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/conditionalget.rb:25:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/head.rb:13:in `call'
/var/www/discourse/lib/middleware/anonymous_cache.rb:127:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/params_parser.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/flash.rb:260:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:225:in `context'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/session/abstract/id.rb:220:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/cookies.rb:560:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.4/lib/active_record/query_cache.rb:36:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activerecord-4.2.4/lib/active_record/connection_adapters/abstract/connection_pool.rb:653:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/callbacks.rb:29:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:88:in `__run_callbacks__'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/activesupport-4.2.4/lib/active_support/callbacks.rb:778:in `_run_call_callbacks'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/callbacks.rb:27:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/remote_ip.rb:78:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/debug_exceptions.rb:17:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/show_exceptions.rb:30:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/logster-1.0.1/lib/logster/middleware/reporter.rb:31:in `call'
/var/www/discourse/config/initializers/100-silence_logger.rb:24:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/actionpack-4.2.4/lib/action_dispatch/middleware/request_id.rb:21:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/methodoverride.rb:22:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/runtime.rb:18:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/sendfile.rb:113:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-mini-profiler-0.9.7/lib/mini_profiler/profiler.rb:170:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/message_bus-1.1.1/lib/message_bus/rack/middleware.rb:60:in `call'
/var/www/discourse/lib/middleware/request_tracker.rb:73:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.4/lib/rails/engine.rb:518:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.4/lib/rails/application.rb:165:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.4/lib/rails/railtie.rb:194:in `public_send'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/railties-4.2.4/lib/rails/railtie.rb:194:in `method_missing'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:66:in `block in call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `each'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/rack-1.6.4/lib/rack/urlmap.rb:50:in `call'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:580:in `process_client'
/var/www/discourse/lib/scheduler/defer.rb:85:in `process_client'
/var/www/discourse/lib/middleware/unicorn_oobgc.rb:95:in `process_client'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:674:in `worker_loop'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:529:in `spawn_missing_workers'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/lib/unicorn/http_server.rb:140:in `start'
/var/www/discourse/vendor/bundle/ruby/2.0.0/gems/unicorn-4.9.0/bin/unicorn:126:in `<top (required)>'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `load'
/var/www/discourse/vendor/bundle/ruby/2.0.0/bin/unicorn:23:in `<main>'
Do you have S3 enabled?
We are also facing same issue. S3 is enabled in our case.
What is the exact error message you are getting, what do all the tabs show?
One possible reason may be that amazon starts blocking you from downloading if you try to download too much.
Not at all, thank you for the detailed report.
Here are our logs
Discourse::InvalidParameters (url)
/var/www/discourse/lib/file_helper.rb:10:in `download’
/var/www/discourse/lib/middleware/anonymous_cache.rb:129:in `call'
I think I see the issue … are you using //something as your S3 source (as opposed to https://) … I can fix it …
S3 is enabled, https set. Thanks for the replies.
Dan
This should fix it… let me know how you go:
Thanks @sam its working now :smile:
