Hello there!
I’m using this plugin to sync user from a django site, but the avatar is sync only on creation. If user change it in django, it is not sync in discourse.
In fact, in Discourse managed_authenticator.rb, the retrieve_avatar return early if the user already have a custom avatar setup:
def retrieve_avatar(user, url)
return unless user && url
return if user.user_avatar.try(:custom_upload_id).present?
Jobs.enqueue(:download_avatar_from_url, url: url, user_id: user.id, override_gravatar: false)
Did I missed something or discourse-openid-connect can not update avatar on login?
I also have question for the “website”, “location” and “bio_raw”. DiscourseConnect sync it on login, can openidconnect also do it? All are supported in the oidc claims
cheers!
