Avatar of OP displayed on categories page
User mbajur reported a discrepancy on the categories page where desktop views display the Original Poster’s (OP) avatar instead of the recent poster’s avatar, unlike the mobile ‘Active’ view which correctly shows the recent poster. mbajur provided screenshots from their site and noted they are running version v1.7.0.beta3+19. cpradio initially could not reproduce the issue on Meta Discourse and suggested mbajur upgrade to the latest version, pointing out that several avatar-related commits exist since their current build. mbajur acknowledged the version discrepancy but stated they cannot install the latest version to test the fix, classifying the issue as non-critical. cpradio later identified a specific commit (55fad7) that addresses the latest-topic-list-item.hbs template, suggesting the issue would be resolved in future releases. sam added a note that multiple commits are required to ensure all related subtle issues are fixed.
Hey!
I’m not sure if that’s intended or not but i can’t find any info about that here on meta.discourse.org. Basically, when i’m visiting my forum on a mobile device, “Active” topics page shows me, on the left side of a topic, avatar of a user who posted recently. And that’s great.
But! On desktop version, when browsing categories page (with active topics on the right), i can see the avatars of OPs instead of recent poster avatars.
I would rather see it working as on mobile version but i’m not sure if it’s a bug nor which behaviour is intended. Or maybe is that possible to configure it in admin panel?
Here is a live site with such problem: https://forum.hard-core.pl
Thanks in advance.
Here on meta it seems to show the same avatars…
Desktop Categories View
Mobile Latest View
Or are you referring to something else?
Edit:
I see a few commits made from the version you are on that deal with avatars and the category list view, can you try going to /admin/upgrade, pulling down latest and verifying the issue still exists?
1 лайк
Here is how it looks on my side:
and mobile:
It’s not directly a difference between “Active” page on desktop and mobile but rather a difference between “Active” column on categories page and “Active” page itelf.
ps. I’m on the most recent version i think. Which is v1.7.0.beta3 +19
No, there are more. The link I provided in my post was showing you the commits that have occurred after +19. I just recently upgraded my sandbox and it reports +51 right now.
1 лайк
Ok, sorry. You’re right. I didn’t thought that there are any newer versions than discourse suggests me.
Anyway - i can’t see any commit related to my issue. I’m also not able to install the most recent version so i can’t check that manually. Anyway, that’s nothing critical to me, just thought that it’s a non-critical-but-still bug worth reporting.
If you think that’s gonna be fixed with the next beta release, that’s totally fine by me :wink:
I think it might? As meta (here) should be exhibiting the same behavior if the bug still exists and I can’t reproduce it here.
1 лайк
Seems to be this commit that fixed it
https://github.com/discourse/discourse/commit/55fad7b3391f4096ab89ffd8e2037157b2316580
Look at the changes for latest-topic-list-item.hbs
1 лайк
Note, you need all the following commits as well, lots of subtle issues
4 лайка
