The database of our discourse instance is not a local container, instead we use a central database cluster. Recently the central postgresql was updated to version 18.3. I noticed that the discourse backup now fails:
[2026-05-19 03:37:37] [STARTED]
[2026-05-19 03:37:37] 'system' has started the backup!
[2026-05-19 03:37:37] Marking backup as running...
[2026-05-19 03:37:37] Making sure '/var/www/discourse/tmp/backups/default/2026-05-19-033737' exists...
[2026-05-19 03:37:37] Making sure '/var/www/discourse/public/backups/default' exists...
[2026-05-19 03:37:37] Updating metadata...
[2026-05-19 03:37:37] Dumping the public schema of the database...
[2026-05-19 03:37:37] pg_dump: error: aborting because of server version mismatch
[2026-05-19 03:37:37] pg_dump: detail: server version: 18.3 (Ubuntu 18.3-1.pgdg24.04+1); pg_dump version: 15.15 (Debian 15.15-1.pgdg12+1)
[2026-05-19 03:37:37] EXCEPTION: pg_dump failed
[2026-05-19 03:37:37] /var/www/discourse/lib/backup_restore/creator.rb:173:in 'BackupRestore::Creator#dump_public_schema'
/var/www/discourse/lib/backup_restore/creator.rb:36:in 'BackupRestore::Creator#run'
/var/www/discourse/lib/backup_restore.rb:13:in 'BackupRestore.backup!'
/var/www/discourse/app/jobs/regular/create_backup.rb:10:in 'Jobs::CreateBackup#execute'
Any ideas how to fix this?
