~/Developer/localhost/discourse su master sudo gem install cppjieba_rb -v '0.3.3' --source 'https://rubygems.org/' alle 17:13:33
Password:
Compilazione delle estensioni native. Questo potrebbe richiedere del tempo...
ERRORE: Errore durante l'installazione di cppjieba_rb:
ERRORE: Creazione dell'estensione nativa del gem fallita.
directory corrente: /Library/Ruby/Gems/2.6.0/gems/cppjieba_rb-0.3.3/ext/cppjieba_rb
/System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/bin/ruby -I /System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/lib/ruby/2.6.0 -r ./siteconf20191021-73798-k500fk.rb extconf.rb
creazione del Makefile
make "DESTDIR=" clean
make "DESTDIR="
compilazione di cppjieba_rb.c
compilazione di internal.cc
In file incluso da internal.cc:1:
In file incluso da /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/include/ruby-2.6.0/ruby.h:33:
In file incluso da /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/include/ruby-2.6.0/ruby/ruby.h:24:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/include/ruby-2.6.0/universal-darwin19/ruby/config.h:413:31: errore: suffisso non valido per il letterale; C++11 richiede uno spazio tra il letterale e l'identificatore [-Wreserved-user-defined-literal]
#define RUBY_ARCH "universal-"RUBY_PLATFORM_OS
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/include/ruby-2.6.0/universal-darwin19/ruby/config.h:414:35: errore: suffisso non valido per il letterale; C++11 richiede uno spazio tra il letterale e l'identificatore [-Wreserved-user-defined-literal]
#define RUBY_PLATFORM "universal."RUBY_PLATFORM_CPU"-"RUBY_PLATFORM_OS
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/include/ruby-2.6.0/universal-darwin19/ruby/config.h:414:55: errore: suffisso non valido per il letterale; C++11 richiede uno spazio tra il letterale e l'identificatore [-Wreserved-user-defined-literal]
In file incluso da /Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/include/ruby-2.6.0/ruby/ruby.h:2111:
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/include/ruby-2.6.0/ruby/intern.h:56:19: avviso: lo specificatore di archiviazione 'register' è deprecato e incompatibile con C++17 [-Wdeprecated-register]
void rb_mem_clear(register VALUE*, register long);
/Applications/Xcode.app/Contents/Developer/Platforms/MacOSX.platform/Developer/SDKs/MacOSX10.15.sdk/System/Library/Frameworks/Ruby.framework/Versions/2.6/usr/include/ruby-2.6.0/ruby/intern.h:56:36: avviso: lo specificatore di archiviazione 'register' è deprecato e incompatibile con C++17 [-Wdeprecated-register]
In file incluso da internal.cc:8:
In file incluso da /Library/Ruby/Gems/2.6.0/gems/cppjieba_rb-0.3.3/ext/cppjieba_rb/../cppjieba/include/cppjieba/Jieba.hpp:4:
In file incluso da /Library/Ruby/Gems/2.6.0/gems/cppjieba_rb-0.3.3/ext/cppjieba_rb/../cppjieba/include/cppjieba/QuerySegment.hpp:8:
In file incluso da /Library/Ruby/Gems/2.6.0/gems/cppjieba_rb-0.3.3/ext/cppjieba_rb/../cppjieba/include/cppjieba/DictTrie.hpp:13:
/Library/Ruby/Gems/2.6.0/gems/cppjieba_rb-0.3.3/ext/cppjieba_rb/../cppjieba/deps/limonp/StringUtil.hpp:87:70: avviso: 'ptr_fun<unsigned int, bool>' è deprecato [-Wdeprecated-declarations]
s.erase(s.begin(), std::find_if(s.begin(), s.end(), std::not1(std::ptr_fun<unsigned, bool>(IsSpace))));
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/functional:1097:1: nota: 'ptr_fun<unsigned int, bool>' è stato esplicitamente marcato come deprecato qui
_LIBCPP_DEPRECATED_IN_CXX11 inline _LIBCPP_INLINE_VISIBILITY
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config:1101:39: nota: espanso dalla macro '_LIBCPP_DEPRECATED_IN_CXX11'
# define _LIBCPP_DEPRECATED_IN_CXX11 _LIBCPP_DEPRECATED
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/__config:1090:48: nota: espanso dalla macro '_LIBCPP_DEPRECATED'
# define _LIBCPP_DEPRECATED __attribute__ ((deprecated))
/Library/Ruby/Gems/2.6.0/gems/cppjieba_rb-0.3.3/ext/cppjieba_rb/../cppjieba/deps/limonp/StringUtil.hpp:92:61: avviso: 'ptr_fun<unsigned int, bool>' è deprecato [-Wdeprecated-declarations]
s.erase(std::find_if(s.rbegin(), s.rend(), std::not1(std::ptr_fun<unsigned, bool>(IsSpace))).base(), s.end());
/Library/Ruby/Gems/2.6.0/gems/cppjieba_rb-0.3.3/ext/cppjieba_rb/../cppjieba/deps/limonp/StringUtil.hpp:101:70: avviso: 'bind2nd<std::__1::equal_to<char>, char>' è deprecato [-Wdeprecated-declarations]
s.erase(s.begin(), std::find_if(s.begin(), s.end(), std::not1(std::bind2nd(std::equal_to<char>(), x))));
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../include/c++/v1/functional:1079:1: nota: 'bind2nd<std::__1::equal_to<char>, char>' è stato esplicitamente marcato come deprecato qui
/Library/Ruby/Gems/2.6.0/gems/cppjieba_rb-0.3.3/ext/cppjieba_rb/../cppjieba/deps/limonp/StringUtil.hpp:106:61: avviso: 'bind2nd<std::__1::equal_to<char>, char>' è deprecato [-Wdeprecated-declarations]
s.erase(std::find_if(s.rbegin(), s.rend(), std::not1(std::bind2nd(std::equal_to<char>(), x))).base(), s.end());
6 avvisi e 3 errori generati.
make: *** [internal.o] Errore 1
make fallito, codice di uscita 2
I file del gem rimarranno installati in /Library/Ruby/Gems/2.6.0/gems/cppjieba_rb-0.3.3 per l'ispezione.
I risultati sono stati registrati in /Library/Ruby/Gems/2.6.0/extensions/universal-darwin-19/2.6.0/cppjieba_rb-0.3.3/gem_make.out
Sei riuscito a risolverlo? Ho riscontrato lo stesso problema quando sono passato da bash a zsh e ho dimenticato di configurare rbenv. Non appena ho ricominciato a usare rbenv, tutto è tornato alla normalità.
Il Ruby di sistema su macOS sembra presentare problemi di tanto in tanto.
Non sono riuscito a risolvere il problema. Hai fatto altro oltre a installare rbenv come parte dello script di installazione delle dipendenze di Discourse? Io ho fatto solo quello, perché non ci sono altre istruzioni.
Il mio ambiente di sviluppo è stato configurato molto tempo fa, quindi non ne sono sicuro. Non credo di aver fatto altro in quel momento, ma forse qualcosa è cambiato in macOS da allora.
Immagino tu possa verificare se rbenv è configurato… se esegui nano ~/.bash_profile dovresti vedere qualcosa di simile a questo:
Puoi anche controllare rbenv versions per vedere quale versione è attualmente selezionata (è quella con l’asterisco accanto). Se è system, vorrai cambiarla… la 2.6.1 funziona bene per me. (rbenv install 2.6.1 e poi rbenv global 2.6.1)
