Hi, will be installing discourse on vps 20gb space, but will be adding (mounting) an additional volume 10gb to store discourse data.
Question what is best file system to format new volume with?
Thanks
Thanks
I think ext4 is still a good way to go.
Note: I’d recommend that you just increase the VPS volume size if you can. Discourse stores its data in /var/discourse and also Discourse uses space to build and store docker volumes and images. On some services the additional filesystems are slower than the VPS one. I think it should work, though.
