أفضل طريقة للربط ببحث 'داخل الفئة'؟
Hi,
We’d like to help our users search in our support forum by including a link or search field in a sticky message. I’ve tried using a link that contains the ‘category:’ filter, like:
http://forum.sketchfab.com/search?q=category%3Asupport
While this works, it also leaves the text ‘category:support’ in the search box and we feel like this may be confusing (many users may just delete that text and enter their query) :
Is there a way around this? Or even better, is there a way that we can embed the search field directly into a post?
Thanks!
I need to clean some internals up, but you have
https://meta.discourse.org/search?context=category&context_id=1&q=Test&skip_context=false
إعجاب واحد (1)
Brilliant, thanks! It worked (although finding the category ID was a bit of a challenge :wink:
تم إغلاق هذا الموضوع تلقائيًا بعد 3173 يومًا. لم يعد يُسمح بالردود الجديدة.
