Boolean site settings undefined
For some weird reason, certain site settings are coming out as undefined where I use the following call from within my plugin:
var siteSettings = api.container.lookup('site-settings:main');
console.log(siteSettings.myplugin_popup_permalink); // => undefined!
I’ve checked and double-checked (and even triple-checked) the syntax in my setting.yml file and everything looks just fine.
plugins:
  myplugin_popup_permalink:
    default: false
    client: false
Is there something obvious that I’ve overlooked or a known bug for this?
Thanks in advance for the help.
You’ve set client: false which means the site setting is not available in the client (Ember) app.
Jeez, I must look pretty stupid. I thought that that was the default value for the client, not whethet or not it’s available for the client. Wrong! Thanks for setting me on the right path again.
